Thread: castlevania 2de boss
30-06-2006, 00:10 #1Approved 9-lifer
- 02/03/05
- Duffel
- 4,317
- 22 (96%)
Ik zit vast in castlevania dawn of sorrow bij de tweede boss. dat is die ene met zijn hele grote straalaanval en met zijn grote vuisten enzo...
wie kan me tips geven om dit monster te verslaan?Steam: The VendeTTa Lord
NES-SNES-ATARI2600-GAMECUBE-XBOX-WII-XBOX360-DS-3DS-PSVITA-WIIU
Radeon HD7970, Core™ i5-3570K, 120G-SSD, Fatal1ty Z77 Performance, 1TB HD103SJ, 8 GB DDR3-1600 Kit, Mugen 2-coolerno votes
30-06-2006, 11:55 #2Member
- Sint-Niklaas
- 608
- 41 (98%)
- 1/2
A lot of health potions kopen bij den Hammer ;°) .
Eenvoudig om alle bosses zo te verslaan in elke 2d castlevania.
Mijn blog: pxlplayer.be • Twitter: @pxlplayer
PSN: Score2 • XBL: Scoretwo • 3DS: Scoretwo • Steam: Scoretwo • Oculus Rift: Scoretwo • Battlenet: Scoretwo#2807 • IOS: Scoretwono votes
30-06-2006, 12:12 #3
gevonden op gamefaqs : http://db.gamefaqs.com/portable/ds/f...a_dos_boss.txt
Hier is het stuk voor uw boss :
The giant that smashed Giant Bat in the Aria of Sorrow
Arena is back. When you enter the fight, immediately run
up to his face and duck. I recommend you take an overhead-
swinging weapon with you (you should have the Claymore),
to avoid having to jump and attack. Keep swinging while
ducked next to him. If he brings his fist towards the floor,
slide out of the way to avoid his punch. It'll deal some
heavy damage, and push you up to the ceiling. His next skill
is similar, although this time, he'll bring his hand towards
his body. At first he'll punch forward, and it shouldn't
hit you unless you're standing up or jumping. After he
finishes this punch, he'll do it again along the ground.
You'll either clear his swipe completely, or catch a ride
on it. Either way, you won't take damage. His third is an
eye laser,which you saw while walking up to the crystal
blocks at the entrance to the room. He's pretty obvious to
warn you whenhe's going to use it, as you'll hear a
charging noise and see his eye glow. If you're not ducking,
do so. It'll passright over your head. Stay ducked and
keep attacking, he'll go down eventually. When you're done,
break the crystal blocks to your right with the stylus.no votes
01-07-2006, 17:02 #4Member
- 25/01/03
- Mechelen
- 1,215
- 23 (96%)
is niet zo moeilijk. lees hierboven anders eens. de moeilijksten boss voor zover ik mij kan herinneren was the puppetmaster (dacht dat hij zo noemde).
Wicked!no votes
02-07-2006, 19:49 #5Approved 9-lifer
- 02/03/05
- Duffel
- 4,317
- 22 (96%)
pfff, het lukt echt ni. trouwens, op welke knop moet ik drukken als ik wil praten me die hammer?
