Thread: MultiTES4: Multiplayer Oblivion
25-06-2006, 18:37 #1Member
- 15/11/03
- Tongeren
- 4,829
- 12 (100%)
- 4/24
http://csusap.csu.edu.au/~mloxto01/So what is MultiTES4?
MultiTES4 is my attempt at an Oblivion mod/add-on that, you guessed, adds multiplayer to this awesome game. I started the work on this project around the 7th of May, 2006. It's come a long way, and has a long way to go, but with perseverance and a little luck, it'll go a long way. At the moment, MultiTES4 consists of three components: A client application, a server application, and a Oblivion 'esp' modification file. All these combined with a little luck (and a whole heap of code) and voila, we have multiplayer!
What can MultiTES4 actually do?
The current version (being only an alpha) is pretty limited in it's capabilities. It supports only 2 people running around Cyrodiil. The other players in the game are represented as NPCs to each individual on their computer. The NPC will move and travel to match the players that are connected to the server.
What can't MultiTES4 do?
At the moment, the following haven't been implemented: time/day/year synchronisation, quest sharing, deathmatch, cell/world synchronisation, err pretty much everything else you can think of. Console commands aren't blocked, either is fast travel. Animations aren't shared, neither is inventories or attributes. I wasn't kidding when I said it was the basics.
Hopen dat deze mod iets cool word
25-06-2006, 18:53 #2Banned
- 05/11/03
- Poperinge
- 2,001
*Drewl*
25-06-2006, 22:22 #3
ziet er niet slecht uit maar kga nog even wachten om hem uit te proberen
want kga voor een paar maandjes stoppen met oblivion en kzal dan later weer een stuk of 15 uurtjes erin stoppen met talrijke nieuwe modsno votes
26-06-2006, 00:11 #4Member
- 08/06/06
- Breda
- 34
ik heb het al gezien, tis een zeer crappy versie :P En het happert als de tering :P Maar het begin is er.
Greetzzno votes
26-06-2006, 14:14 #5
Het principe is zeker en vast leuk
maar denk da het nie gemakkelijk is het te realiseren ook al gaat dat niet tegen werken met mods enzo of gaan die standaard afgezet worden, worden u lvl gegevens en heel die sirk wel bijgehouden op de server zoals bij mmorpg's of terug gewoon op u HDD = met al het gevolg van cheaters erbij enzo. Wrm brengt Bethesda Softworks geen expansion maken met multyplayer mogelijkheid
3l b4rt0no votes
26-06-2006, 17:58 #6Member
- 24/06/04
- Alken
- 1,716
- 6 (100%)
- 0/13
@elbarto , geen betalende hopelijk dan !
Wat is een closed beta en een Open beta ? wat is het verschil?
26-06-2006, 18:54 #7
Wel ja als het een expansion pack is waarbij je dan multiplayer kan gaan + een helehoop nieuwe queests, nieuwe mappen etc... Wrm nie dan die kleine plugins vind ik ook wel wat te duur
, maar zo'n expansion met veel nieuwe matreaal zie ik toch wel zitten.
3l b4rt0no votes
26-06-2006, 18:56 #8Member
- 03/11/03
- Hove
- 6,718
- 1/3
Look down at me and you see a fool; look up at me and you see a god; look straight at me and you see yourselfno votes
27-06-2006, 04:55 #9
lijkt me wel leuk om eens uit te probere
27-06-2006, 08:58 #10Member
- 01/05/04
- Assen, noord NL
- 303
bij een closed beta moet je een e-mail sturen naar de makers en dan kunnen die jou een uitnodiging sturenWat is een closed beta en een Open beta ? wat is het verschil?
en bij een open beta mag iedereen het spel gewoon downloaden zonder toestemming van de makers9Lives accepteert geen namechanges.
29-06-2006, 09:24 #11
oke ik gedownload en geinstaleerd voor via on thuis netwerk maar als ik het dan start staat er dit DATA SENDING FAILD
DATA SENDING FAILD
DATA SENDING FAILD
ienmand een idee hoe je dit wel werkend krijgtno votes
01-07-2006, 11:16 #12Approved 9-lifer
- 26/11/05
- Zulte
- 5,683
- 0/7
my litle place I call home!
