    grinzo's Avatar
    Beveren
    Question CS1.6/CZ - LAG > Help!!! Hoe krijg ik hoge ping weg?
    Niet meer nodig
    't Wonder is geschiet ...
    wireke's Avatar
    Antwerpen-Stad
    je rates goed zetten kan eventueel helpen.
    cl_cmdrate 101
    cl_updaterate 101
    rate 20000 in console
    Don't try to live up to others, but make your own adventure. Regret is only good for telling yourself what you will never do again. Once you know which things you will never do again, regret turns into wisdom, and wisdom builds character.
    flyingdutchman's Avatar
    MSK
    15 (94%)
    ophouden met prono te downloaden
