    lommel
    error 005 zonder oplossing
    euh, need a quick reply on this
    ik kan me men poppekes overal binne behalve battle islands
    menne ele zit in ascalon, en als hij na battle island gaat load et gewoon ni, en elk ander ding wel
    WTF
    ik krijg error 005
    ma fw staat af en al...
    en ik heb ook geen router...
    don't hate the player, hate the game!
    Devastate's Avatar
    19 (100%)
    dit vond ik erover ...
    Quote Originally Posted by GW-Staff
    We're sorry that you are experiencing network difficulties. The error you are reporting, Code=005 (NET_ERR_CONNECT_FAILED), is indicative of a mis-configured network setting or network interference. Please use the following information in order to assist you in troubleshooting this issue:
    1. Make sure GW.EXE or GWSETUP.EXE is added to your firewall's exception list. If you have already allowed Guild Wars in the past, please double check the exceptions. Often times firewalls will decide to block Guild Wars after it has patched. If adding an exception does not help, please try completely uninstalling the firewall software.
    2. If you are using a router, please open and/or forward both TCP port 6112 and TCP port 80 within their settings. If you are connecting to Guild Wars while on a campus or business network, please consult your network's administrator to verify that these ports are available. If you are using a NETGEAR® router please review the following article:
    Why am I unable to connect to Guild Wars while using my Netgear router?
    If you are using a wireless router, try connecting your computer directly to the router using an Ethernet cable instead.
    3. Try temporarily disabling any Internet Security or Anti-virus/spyware applications. If this resolves the connection issue, then you will need to properly configure these applications in order to enable them while you play Guild Wars. Please contact the author of the software if you do not know how to make these adjustments.
    4. If your Internet Service Provider is America Online and you are unable to use Internet applications outside of the AOL client (such as Internet Explorer), please contact their Customer Support regarding this issue at http://www.aol.com/support/help.adp .
    If the above information did not resolve this issue, please contact our Technical Support team by using the 'Ask a Question' tab. Please provide them with the following information so that they may better assist you with this issue:
    * Are you connecting through a Router or Hub? If so, what is the name and model number?
    * Are you on a Home, Campus, or Business Network?
    * Are you using a Firewall application? If so which one?
    * Do you use any Internet Security Applications (ISA) such as CYBERsitter, "Net-Nanny", ZoneAlarm®, McAfee® or Norton™?
    * Who is your Internet provider?
    * What type of connection do you have (cable, DSL, dial-up)?
    * Where are you located?
    Please provide as much relevant information as possible; this will help them swiftly resolve your issue.
    A "racist rapist" sounds worse than a regular rapist when u first hear it, but it's actually better 'cause less people get raped.
    lommel
    weet ik
    ma ik heb geen router en fw staat af
    kheb em ook al opgezet en dan bij uitzondering, ma et werkt ni
    ik kan in elke stat binne
    dus connecte gaat
    behalve HOH and de GH
    wouterkiller's Avatar
    Heb je al support persoonlijk gecontacteerd?
    (\__/)
    ('')_('')Healer Rabbit Queen
    lommel
    nee,
    bedoelde er heen belle ofzo?
    Mailen man....
    (\__/)
    lommel
    hmm, kheb er net ne mail hene gestuurd
    ik hoop wel da ze antwoorde voor morge deze tijd...
    maja, we zien wel.
    kvin et tog raar oe da opeens komt
    Renegade ++RIP++'s Avatar
    Beringen
    http://www.guildwarsguru.com/forum/s....php?t=3017396
    meerdere personen hebben het, waarschijnlijk een servererror of zo. Ik heb het 2 dagen geleden of zo ook gehad.
    Shogun Walhalla W/Me 20
    Shogun Walkyre Mo/N 20
    Shogun Artemis R/Me 20
    Elementally Wally E/Me 20
    nothing to worry about i guess....
    (\__/)
    lommel
    deze morge ff getest ent werkte
    wel raar, maja
    im happy once again
    Heat-'s Avatar
    Dergelijke foutmeldingen verhelpt Anet echt wel snel.. Nog maar heeeel weinig games tegengekomen met een support als die van Anet.. echt sterk van die mannen =)
    Moesten ze nu es Error7 eruit halen ben'k helemaal content
    o_OA Bunch of Nutcases O_O website O_o
    .:: PvE Character ::.:: lev 20 Monk/Necro: Angel Of Enchanting ::.
    .:: PvP Character ::.:: Monk/X: I Mhenlos Homeboy I ::. air guitars rule
    18 (100%)
    ik vind ook wel dat ze iets zouden mogen doen aan err7 (minder gevoelig maken of mogelijkheid tot reconnect)
    Drez's Avatar
    gent
    61 (100%)
    wat voor error is dat dan?
    kan me niet herinneren dat ooit gehad te hebben.
    Ik ben een lekker wijf.
    www.dexyd.nl / www.dexyd.be
    18 (100%)
    dat krijg je als je connectie onderbroken wordt (test maar eens met je verbinding uit te schakelen )
    op een draadloos netwerk kan het gebeuren dat je efkes connectie kwijt bent (maar direct terughebt) en het is dan vrij vervelend als je uit een missie gegooid wordt
