    Maikel.v's Avatar
    FPS probleem nr zoveel :s
    Goedendag,
    Bedankt al dat u het toch over uw hart hebt gekregen om alweer een fps thread te openen .
    specs :
    Intel pentium IV
    ATI radeon 9800pro sapphire (nieuwste catalyst drivers)
    1024mb RAM
    Nu , mijn probleem is dat ik maar 15-30 fps krijg, zelfs met alle details op low, res op 800x600,vsync uit en fps max op 200.
    Ik zou het zeer op prijs stellen als iemand wist hoe ik mijn fps boven de 45 krijg.
    Dank bij voorbaat
    Edit : PC wordt regelmatig (1a2x per week) gescanned, met spybot s&d, adaware,AVG,hijackthis,register wordt 1x per maand volledig schoongemaakt
    NapalmBenny.'s Avatar
    Anti-Aliasing volledig afzetten.
    Screw you all.
    Maikel.v's Avatar
    staat al af
    Outside^'s Avatar
    zet dit in je autoexec.cfg:
    Code:
    // NETSETTINGS
    cl_cmdrate 			"100"
    cl_interp 			"0.01"
    cl_interpolate 			"0"
    cl_lagcomp_errorcheck 		"1"
    cl_lagcompensation 		"1"
    cl_updaterate 			"100"
    cl_smooth 			"1"
    rate 				"25000"
    // VIOLENCE SETTINGS
    violence_ablood 		"1"
    violence_agibs 			"1"
    violence_hblood 		"1"
    violence_hgibs 			"1"
    // GRAPHICAL SETTINGS
    cl_ejectbrass 			"0"
    cl_phys_props_enable 		"0"
    cl_phys_props_max 		"0"
    cl_ragdoll_collide 		"0"
    cl_ragdoll_physics_enable 	"0"
    cl_show_splashes 		"0"
    fog_enable 			"0"
    fog_enable_water_fog 		"0"
    mat_antialias 			"0"
    mat_bloom			"0"
    mat_bumpmap 			"0"
    mat_clipz 			"0"
    mat_debugdepth 			"0"
    mat_debugdepthmode 		"0"
    mat_diffuse 			"1"
    mat_fastspecular 		"0"
    mat_fastnobump 			"1"
    mat_filterlightmaps 		"0"
    mat_forceaniso 			"0"
    mat_forcehardwaresync 		"0"
    mat_mipmaptextures		"0"
    mat_picmip 			"4"
    mat_showlightmapcomponent 	"1"
    mat_specular 			"0"
    mat_texture_limit 		"-1"
    mat_trilinear 			"0"
    mat_vsync 			"0"
    mp_decals			"50"
    jpeg_quality 			"100"
    r_avglight 			"0"
    r_cheapwaterend 		"1"
    r_cheapwaterstart	 	"1"
    r_decal_cullsize 		"2"
    r_decals 			"50"
    r_dopixelvisibility 		"0"
    r_drawlights 			"1"
    r_drawdetailprops 		"0"
    r_drawmodeldecals 		"0"
    r_drawrain 			"0"
    r_dynamic 			"0"
    r_eyes 				"0"
    r_lightaverage 			"1"
    r_lightinterp 			"1"
    r_lod				"5"
    r_modellodscale 		"0.1"
    r_propsmaxdist 			"0"
    r_RainSimulate 			"0"
    r_rootlod			"2"
    r_shadows 			"1"
    r_waterforceexpensive 		"0"
    texture_budget_panel_height 	"64"
    texture_budget_panel_width 	"64"
    // PROCESSING SETTINGS
    r_3dnow 			"1"
    r_mmx 				"1"
    r_sse 				"1"
    r_sse2 				"1"
    // SOUND SETTINGS
    cl_downloadfilter 		"nosounds"
    dsp_enhance_stereo 		"1"
    snd_mixahead 			"0.1"
    soundscape_flush
    soundscape_fadetime 		"9999"
    sv_voiceenable 			"1"
    voice_enable 			"1"
    voice_modenable 		"1"
    volume 				"0.4"
    // CUSTOM SETTINGS
    con_enable 			"1"
    cl_autowepswitch 		"0"
    cl_radartype 			"1"
    cl_righthand 			"0"
    cl_observercrosshair 		"0"
    cl_showfps 			"1"
    crosshair 			"1"
    fps_max 			"101"
    hud_centerid 			"1"
    hud_fastswitch 			"1"
    hud_saytext_time 		"5"
    hud_deathnotice_time 		"5"
    hud_drawhistory_time 		"1"
    showhitlocation 		"1"
    sv_forcepreload			"1"
    Heb deze cfg overlangst esgeprobeert en kvind hem wel nog goed.
    Let op ZEER LOW gfx!!
    Grtz
    ze luv
    Maikel.v's Avatar
    mja, is het wel normaal dat ik al zo drastisch slecht graphics moet nemen met het systeem dat ik heb ?
    bull`'s Avatar
    pc uitkuisen :P
    Maikel.v's Avatar
    waarom close ? ik heb de faq heus wel gelezen en uitgevoerd hoor, ik heb ook de search gebruikt, maar die werkt precies niet voor de volle 100%
    PC is volledig schoon is ook een verse format van begin deze maand.
    Specs zijn +- de mijne (op de cpu na). Op steam forums staat er ook zo'n thread waar juist de cpu het onderwerp van gesprek is. Alle users die het probleem hadden zaten op p4. Nu misschien eens nakijken of al je drivers ok zijn ofzo?
    En laat steam je game cache controleren. Rechtse klik op csource in games menu, en dan ergens onder properties ofzo. Onlangs was daar iemand mee geholpen... gl
    Maikel.v's Avatar
    Quote Originally Posted by naga
    Heeft u misschien een linkje naar dat topic op de steam forums ? ik heb al wat gezocht maar er staat daar zo een overvloed aan threads dat ik het eerlijk gezegd heb opgegeven.
    Bedankt voor de info alvast Naga, en de anderen.
    nieldeckx's Avatar
    Turnhout
    Je moet zeker hoger fps kunnen halen. pProbeer mat_dxlevel 50 of 60 of 70 eens. Meestal haalt dat je fps wel omhoog.
    // Qck //
    Fraggie's Avatar
    Welke CPU heb je juist? (speed)
    Maikel.v's Avatar
    2.10 ghz
    CK_'s Avatar
    das normaal met zo'n processor, met mijn 3.0GHz P4 en 9800PRO had ik ook maar max 60fps ofzo en keiveel drops naar 30fps.
    tweaken is de boodschap, ofwel upgraden
    .(")_(")
    Maikel.v's Avatar
    Quote Originally Posted by CK_
    dat is net het probleem , ik héb al getweaked en nog altijd maar die lage fps
    DGEN's Avatar
    Nieuw Vennep
    gl_picmip 'x'
    desktop :: asus p6t deluxe v2 :: i7 920 :: ocz 6gb 1600 :: hd4890 :: 2x1tb wd raid0 :: cm 620m :: antec p182
    mba late 2011
    anidb :: lastfm :: youtube :: twitter
