Page 1 of 4 1234 Last
Thread: low fps
    CoBalT's Avatar
    Stekene
    19 (100%)
    low fps
    ik zit dus vaak met fps rond de 30
    terwilj mijn pc clean is zonder brol enzo en ik heb het volgend script staan :
    Code:
    // _Set netcode settings_
    // _adjusts hitboxes and netcode settings for optimal registration_
    //cl_cmdrate 101
    //cl_interp 0.01
    //cl_interpolate 1
    //cl_lagcomp_errorcheck 1
    //cl_lagcompensation 1
    //cl_updaterate 101
    //cl_smooth 1
    //rate 25000
    // _Set graphics settings_
    // _adjusts graphics settings to boost framerate_
    cl_ejectbrass 0 // _disables shells flying out of guns_
    cl_forcepreload 1
    cl_phys_props_enable 0 // _disables trash and cans etc_
    cl_phys_props_max 0 // _disables trash and cans etc_
    cl_radartype 1 // _solid radar_
    cl_ragdoll_physics_enable 0 // _disables dead bodies_
    cl_show_splashes 0 // _disables splashes when in water_
    fps_max 101 // _caps FPS_
    mat_bloomscale 0
    mat_bumpmap 0 // _disables bumpmapping_
    mat_clipz 0 // _lowers water quality_
    mat_fastnobump 1 // _faster bump mapping_
    mat_fastspecular 1 // _fast specular lighting_
    mat_mipmaptextures 1 // _texture quality decreases with distance_
    mat_hdr_enabled 0 // _disables high dynamic range lighting_
    mat_hdr_level 0 // _disables high dynamic range lighting_
    mat_picmip 2 // _lower texture quality--set between 0 and 2_
    mat_specular 0 // _disables specular lighting_
    mat_trilinear 0 // _disables trilinear filtering_
    mat_wateroverlaysize 16 // _lowers water quality_
    mat_vsync 0 // _disables vertical synchronization_
    mp_decals 50 // _how many bullets etc will be shown_
    muzzleflash_light 0 // _disables muzzleflash_
    r_avglight 0 // _disables average lighting_
    r_cheapwaterend 1 // _worse water rendering_
    r_cheapwaterstart 1 // _worse water rendering_
    r_decal_cullsize 2 // _lower texture quality at distance_
    r_decals 0 // _disables player sprays_
    r_drawdetailprops 0
    r_drawflecks 0// _disables bullet impacts_
    r_drawmodeldecals 0 // _disables decals on models_
    r_dynamic 0
    r_eyes 0 // _removes eyes from player models_
    r_lightaverage 0 // _disables average lighting_
    r_lightinterp 0
    r_lod 3 // _adjusts model quality--set between -5 and 5_
    r_occlusion 0 // _disables occlusion--lowers image quality but gains FPS_
    r_propsmaxdist 100 // _lower object fading distance_
    r_renderoverlayfragment 0
    r_rootlod 2 // _lower overall game detail level_
    r_shadows 1 // _set to 0 to disable shadows (not recommended)_
    r_teeth 0 // _removes teeth from player models_
    r_waterforceexpensive 0 // _disables high-quality water_
    rope_averagelight 0 // _disables average lighting on ropes_
    rope_smooth 0 // _disables antialiasing on ropes_
    rope_subdiv 0
    rope_wind_dist 0 // _disables wind effects on ropes_
    // _Set processing settings_
    // _transfers load from GPU to CPU to boost performance_
    r_3dnow 1
    r_mmx 1
    r_sse 1
    r_sse2 1
    // _Set audio settings_
    // _corrects audio synchronization_
    snd_mixahead // _adjust in intervals of .1 to reduce stuttering_
    // _Set violence settings_
    // _increases blood to help you see hits better_
    violence_ablood 1
    violence_agibs 1
    violence_hblood 1
    violence_hgibs 1
    // _Other settings_
    budget_show_history 0
    cl_crosshairalpha 999
    cl_crosshairusealpha 5
    jpeg_quality 100
    sv_forcepreload 1
    clear
    echo "_casey's config loaded_"
    maar toch blijf ik vaak die lage fps hebben
    wat kan ik nog meer doen ?
    CK_'s Avatar
    post es uw specs
    .(")_(")
    Menthal Kip'tje's Avatar
    KeaNu's leete css-config, sinds ik die gebruik vallen mijn fps ook redelijk mee.
    <@LGC|pGii> ik dunk u mama.
    <@LGC|cpM`> die past ni door zo een ringske
    <@LGC|pGii> nee ma mijne dunker past wel in haar ringske
    De SkeEvN's Avatar
    waarmaarde
    100 (100%)
    ik ebbier al verschillende fps scripts gebruikt mor genee helpt er als in zwaar battle zit schokt da tog -_-
    Shooters speelde op pc me muis en keyboard . uit
    Vraag het op 9lives, wij googlen het wel voor je!
    nieldeckx's Avatar
    Turnhout
    Inderdaad de meeste fps-tweak-scripts helpen niet echt veel. Er is 1 command waarmee ik wel meer fps krijg en dat is: mat_dxlevel70
    Ik kan source op hoogste draaien en haal dan ongeveer 100 fps. Aangezien ik voor de gameplay ga, laat ik al die nieuwtjes achterwegen. Zet dus alles op low en de twee bovenstande commands gebruik ik ook. Dan haal ik 197fps wat toch een groot verschil is vind ik
    Lagere gfx helpen vaak ook. Alles wordt eenvoudiger, en dus makkelijker om de spelers te onderscheiden van de omgeving (op grote afstanden).
    // Qck //
    Fraggie's Avatar
    Het cfg dat je hier post, is niet altijd van toepassing op alle hardware.
    + er staan veel standaard cmd's en overbodige (eerst bumpmapping uitschakelen, en dan de snelle bump aan zetten ). Ik zou gewoon een eigen cfg maken, of zoals nieldeckx zegt, even je DX level verlagen en zien of het genoeg effect heeft.
    Quote Originally Posted by nieldeckx
    Heb je dan nog schaduw?
    De SkeEvN's Avatar
    waarmaarde
    100 (100%)
    Quote Originally Posted by naga
    mss kunde die command es proberen dan wetet -_-
    CK_'s Avatar
    ik denk van niet
    .(")_(")
    [BIG_JIM]'s Avatar
    Alveringem
    17 (100%)
    hhmm, hij heeft dit script van mij mr ik heb er een vraagje over.
    Wrm zie ik geen bloed meer aan de muren?
    wat moet ik er daarvoor in aanpassen?
    Tielt
    same here
    geregeld 20-30 fps
    mijn specs : P4 3.0 Ghz | X800 Pro AGP 256 MB Sapphire | 1.5 gig corsair ddr
    casey's & keano's config al beide geprobeerd ma helpt maar weinig.
    mat_dxlevel zelfde probleem
    Kan niet raden aan wat het probleem kan ligge, ket al op de steampowered forums gepost ook zonder resultaat.
    PS: driver cleaner enzo helpt ook nie
    Simon zegt:
    ik zo: "nog eentje wa"
    gij: "bjaaaak"
    Kozzmozz
    Api3's Avatar
    Nevele
    format c
    wireke's Avatar
    Antwerpen-Stad
    Quote Originally Posted by Liepen
    same here
    geregeld 20-30 fps
    Ik draai ook rond de 20-30 fps nu. 5 Dagen geleje draaide ik nog vlot aan 80 fps met keanu css cfg
    Don't try to live up to others, but make your own adventure. Regret is only good for telling yourself what you will never do again. Once you know which things you will never do again, regret turns into wisdom, and wisdom builds character.
    Questro's Avatar
    lol ik blijf rond 120 zitten ze
    heb ook paar weken terug rond 60 - 70 ma toen wa met cfg geprulled en
    cva terug 120
    QsT
    Retro.Johnson's Avatar
    same here
    geregeld 20-30 fps
    da zijn gwn fps drops vermoed ik ? Denk da da een algemeen probleem is hoor,
    mijn spel draait bijna constant aan 60 - 70 fps, met nodige tweaks natuurlijk, maar wat ik ook doe, alles low, reso verlagen, der blijven drops komen van 20 - 30 fps. Ik zit ook met een ATI kaart, en ik denk dat het gwn iets te maken heeft met die ATI kaartjes...
    't onlogische deraan bij mij is, da hoe lager ik ga van settings, hoe minder fps ik deruit krijg, en hoe stroever het dus ook loopt. Ma als ik dan door selectie wa dingen op max probeer te krijgen, krijg ik echt niks van fps meer. Kmoet dus zo een beetje de gulden middeweg vinden voor alles " goed " te laten lopen, ondanks die drops die ik er ni uitkrijg.
    Aan ram ligt het dus ook ni, zoals ik bij mij dacht ( 512mb ), want liepen zit met 1.5gb ...
    abbi !
