    demon326's Avatar
    probleem met serious sam 2
    hello all,
    say i have a nasty problem with serious sam 2
    iam sitting in the lvl "shield generator" no the problem is every time the game saves or i save the game crashes somtime i can do control alt delete and then i can go back to my desktop.
    pc specs:
    motherboard: asus A7N8X E- deluxe REV 2.0 bios 1013 (latest drivers)
    cpu: amd athlon xp 3200+(2.2GHz)
    videocard: Leadtek 6800GT (AGP) 81.98 driver
    soundcard: Audigy 2 ZS (former beta drivers)
    ram: 2*512 Kingston pc 3200 CL 3.0
    HDD: maxtor 80GB
    ___________________________________
    serious sam 2 log:
    -------- start of log --------
    LOG: Core version: $Version: Serious Sam 2; 2.066.00:59775; 2005-PATCH-2-066-inc$
    LOG: Command: $
    LOG: Initializing timer.
    LOG: Timestamp: 2006/02/18 19:26:29
    LOG: Binary name: Sam2.exe
    LOG: Binary soft path: Bin/
    LOG: Binary hard path: C:\games\Serious Sam 2\Bin\
    LOG: Application directory: C:\games\Serious Sam 2\
    LOG: Loading group files...
    LOG: All_PC_01.gro: 1194 files
    LOG: All_PC_02.gro: 5213 files
    LOG: All_PC_03.gro: 3274 files
    LOG: Movies_PC_01.gro: 56 files
    LOG: Movies_PC_02.gro: 44 files
    LOG: --- Serious Engine Startup ---
    LOG:
    LOG: Examining underlying OS...
    LOG: Type: WinNT
    LOG: Version: 5.0, build 2195
    LOG: Misc:
    LOG:
    LOG: Detecting CPU...
    LOG: Vendor: AuthenticAMD
    LOG: Type: 0, Family: 6, Model: 10, Stepping: 0
    LOG: MMX: Yes
    LOG: SSE: Yes
    LOG: CMOV: Yes
    LOG: Clock: 2191 MHz
    LOG:
    LOG: Error loading ImmWraper.dll: Dynamic module "C:\games\Serious Sam 2\Bin\ImmWrapper.dll" not found!.
    LOG: IFeel disabled
    LOG: Config file 'Content/SeriousSam2/Config/boot.cfg' doesn't exist.
    LOG: Processing config file 'Content/SeriousSam2/Config/autoexec.cfg'.
    LOG: Processing config file 'Content/SeriousSam2/Config/user.cfg'.
    ERR: <memory stream>(4) : error : invalid expression part.
    ERR: Syntax error in command.
    LOG: Loading cvars from "Content/SeriousSam2/Sam2.ini".
    LOG:
    LOG: Desktop settings:
    LOG: Color depth: 32-bit
    LOG: Desktop resolution: 1280 x 1024
    LOG: Virtual screen: 1280 x 1024
    LOG: Monitors attached: 1
    LOG: (Direct3D) Context created successfully.
    INF:
    INF: Sound API: DirectSound
    INF: Device: SB Audigy 2 ZS Audio [9400]
    INF: Mixer frequency: 44100 Hz
    INF: Hardware voices: 60
    INF: Max sounds: 30 (5 same)
    INF: Environment FX: enabled
    INF: Current environment: Padded cell
    LOG: Winsock opened ok.
    LOG: Module 'Bin/CodecOGG.module' loaded in '0.14' seconds.
    INF:
    INF: Resolution: 1280 x 1024
    INF: Graphics API: Direct3D
    INF: Vendor: MS DirectX
    INF: Renderer: NVIDIA GeForce 6800 GT
    INF: Version: 6.14.10.8198
    LOG: Module 'Bin/Shaders.module' loaded in '0.54' seconds.
    LOG: Module 'Bin/Shaders.module' loaded in '0.00' seconds.
    LOG: Module 'Bin/ProcRender.module' loaded in '0.01' seconds.
    LOG: Module 'Bin/Sam2Game.module' loaded in '1.43' seconds.
    TRC: Boot stage completed.
    LOG: resFreeUnusedProxies() released '6' proxy object.
    LOG: resFreeUnusedStockTrivial() released 1 files in 0.00 seconds.
    LOG: resFreeUnusedProxies() released '20' proxy object.
    LOG: Timestamp: 2006/02/18 19:27:09
    LOG: Stopping simulation.
    LOG: Stopping world ''.
    LOG: resFreeUnusedProxies() released '0' proxy object.
    LOG: '0' resources were reverted to resource proxy objects.
    LOG: resFreeUnusedStock() released 0 files in 0.02 seconds (0.000 freeing), after 1 passes
    LOG: World stopped in 0.02sec.
    LOG: resFreeUnusedProxies() released '31' proxy object.
    LOG: resFreeUnusedStock() released 27 files in 0.03 seconds (0.001 freeing), after 2 passes
    LOG: Saving cvars to "Content/SeriousSam2/Sam2.ini".
    LOG: Number of handles used: 60
    LOG: Timestamp: 2006/02/18 19:27:10
    LOG: Core is shutting down
    now because that the game crasht the error is not reported in the log file
    i hope sombody can help me with this problem
    sorry voor dat het in het engels is maar heb geen goesting om alles in het nederlands te zetten
    en ja mijn engels suckt
    Hell$pawn's Avatar
    Sint Niklaas
    36 (97%)
    Me dunkt is er een foutje met je dvd, imo mist hij een .dll -file, dus mss je dvd es nakijken op kraseen, en es afkuisen.
    demon326's Avatar
    Quote Originally Posted by Hell$pawn
    ik ben niet de enige die die file mist... op het forum van croteam zelf hebben ook mensen die de file niet hebben...
    Hell$pawn's Avatar
    Sint Niklaas
    36 (97%)
    Ge kunt mss uw dvd es browesen, en kijken of je de desbetreffende .dll -file kunt terugvinden, anders mss game terugdragen naar winkel en uitleg doen.
    demon326's Avatar
    probleem is opgelost,ik loade mijn auto save en sins toen geen problemen meer gehad dus alles lijkt goed te werken
