Thread: Priest Changes Leaked?
24-01-2006, 22:56 #1Approved 9liver
- 24/09/04
- Reet
- 2,501
- 81 (100%)
Van Curse-Gaming
Waarschijnlijk zal (zoals ze zegge) ma een 50% of minder waar zijn, maar moest blizz het toch doen, dan ga ik Shadow met mijn priest en reroll ik een andere class.-New Spell: Disease Resistance (Level 20) - Increases the targets chance of resisting disease debuffs by 10%. Lasts 3 minutes. (Dwarf only)
-Desperate Prayer - Amount healed and cooldown decreased slightly. This ability has been expanded to allow targeted casting. (Dwarf and Human only)
-New Spell: Spiritual Clarity (Level 20) - The target is infused with spritual force, removing the weakened soul debuff. 15 minute cooldown. (Human only)
-New Spell: Elune's Serenity (Level 20) - Enters the caster into a regenerative state, restoring 1100 mana and 600 health over 30 seconds. Must be used out of combat. 5 minute cooldown. (Night Elf only)
-Starshards - Damage slightly increased, range decreased slightly. This spell was incorrectly avoiding range checks during channeling, this issue has been fixed.
-Devouring Plague - Damage slightly decreased, mana cost slightly increased. The amount healed by this spell has been reduced to 40% of the damage done to the target and has been expanded to heal all party members.
-Touch of Weakness - Target damage reduction significantly increased, damage significantly increased, cooldown added. The damage reducing ability of this spell will now affect all party members. This spell can now be triggered through spellcasting.
-New Spell: Dark Presence (Level 40) - When active, mana will be drained from the target equal to 5% of all damage done over the next 30 seconds. 3 Minute cooldown. (Troll only)
-Hex of Weakness - In addition to the damage reduction modifier, the target will now have all spell resistance values reduced significantly. This change should make Hex of Weakness a more attractive option for Troll priests.
-Inner Fire - The attack power and armor bonuses for this ability have been removed and replaced with a moderate increase in all spell resistances and a 5% increase in wand damage. These changes should make this ability more favorable to priests.
-Greater Heal - The dynamic of Greater Heal has been completely readjusted to make it a channeled heal over time. It now functions similar to channeled damage spells (blizzard etc.) except that it heals the target player progressively throughout the 4 second cast. As with other channeled damage spells, the full mana cost of the spell will be lost if the cast is stopped or interrupted at any point.
-Power Word:Shield - Power Word:Shield can now be modified by a small percentage of + healing gear based upon the skill points used in the new discipline talent, Inner Resolve.
-Fade - In PvP combat, use of the fade ability now causes any unit that has the caster targeted to lose target, much like if the caster were to stealth. The caster can be aquired again by retargeting, as is intended.
-Prayer of Fortitude - Mana cost slightly reduced.
-Holy Fire - Damage slightly increased.
-Mana Burn - Range slightly reduced.
-Psychic Scream - A new system of checks has been instituted now allowing for a percent chance that psychic fear will not be canceled by other abilities. The percentage chance is dependent upon the targets shadow resistance and level.
-Abolish Disease - Range slightly reduced.
-Divine Spirit - Mana cost reduced.
-Focused Casting - Duration decreased to 6 seconds.
-Mind Soothe - Mana cost increased. Maximum rank of targets affected reduced to 65.
-Mind flay - Target movement speed is now reduced to 60% of the normal value.
-Fear Ward - This spell is no longer a dwarven racial ability. This talent can now be found at 31 points in the discipline tree.
-Levitation - An appropriate error message now appears if the caster attempts to use it while submerged.
-All +mana/5 second regenerative items have now been changed to function within the normal passive tick system that spirit operates in. This change should fix numerous lingering issues regarding incorrect threat gain. The Prophetic Aura will also now enter this passive state.
-Starshards - The animation has been changed to prevent the reversed fall issue.
-Updated various spell tooltips to be more clear (grammatical errors etc.).
-Mana Burn - Mana Burn now correctly interrupts the capture of a flag.
-Mind Flay - Spell animation altered to fix an issue with no display during repeated casts.
-Power Word:Shield - Fixed an issue with animation display while in shadowform. The shield animation should now display as intended. Polymorph now removes the weakened soul effect.
-Mind Control - Mind Control now functions correctly if canceled while the targeted unit is attacking a friendly NPC.
Buiten de greater heal, fade en psychic scream trekke ze op niks!
Fear ward vind ik de moeite ni om 31 puntjes aan te geven!
Ik hoop da ze de racial spells wegdoen...
Hoeveel spirit ge ook hebt, het veranderd eigelijk ni veel!
Wa vinde jullie op het eerste zicht van deze 'fake?' changes?PSN: spritske_beno votes
24-01-2006, 23:01 #2Member
- 24/07/02
- Edegem
- 3,369
- 25 (100%)
- 2/22
24-01-2006, 23:02 #3Approved 9liver
- 24/09/04
- Reet
- 2,501
- 81 (100%)
24-01-2006, 23:03 #4Approved 9-lifer
- 11/02/05
- Dendermonde
- 9,360
- 41 (100%)
- 0/30
das wel hard-Fade - In PvP combat, use of the fade ability now causes any unit that has the caster targeted to lose target, much like if the caster were to stealth. The caster can be aquired again by retargeting, as is intended.
rofl xD-New Spell: Elune's Serenity (Level 20) - Enters the caster into a regenerative state, restoring 1100 mana and 600 health over 30 seconds. Must be used out of combat. 5 minute cooldown. (Night Elf only) iMac 27" late 2015, HP zbook 14" - Xperia Z3 16GB Black
Sony A35 + Tamron 17-50mm 2.8no votes
24-01-2006, 23:08 #5no votes
24-01-2006, 23:09 #6Approved 9liver
- 13/11/03
- Rio De Janeiro
- 16,311
- 10/235
lol ik zie wel als ze er echt zijn ^^
24-01-2006, 23:11 #7
idd al die zever da ge leest
24-01-2006, 23:12 #8
Dit zal wel niet waar zijn, ik zie niet veel verbeteringen eigenlijk ivm healing ed.
Als deze waar blijken te zijn stap ik definitief over op andere mmorpg
Nothing to see here, please, continue elsewhere...no votes
24-01-2006, 23:19 #9Approved 9liver
- 12/01/03
- Winksele (Herent)
- 9,782
- 40 (100%)
- 13/63
nerf devouring plague = i quit >_<
Education costs money, but then so does ignorance.no votes
24-01-2006, 23:24 #10
Fake.
Maar Blizzard gaat wel iets in de aard van Greater healing doen wat ik wel goed idee vind , maar ik wacht tot iets officieels
24-01-2006, 23:28 #11Member
- 13/07/04
- Hamme
- 1,465
ja en de
-blabla
-blabla
kladblok stijl van het allemaal samen te stellen is ook niet zoals blizz zn notes samensteld. En de helft dat er staat is zever dus...no votes
25-01-2006, 00:40 #12Approved 9liver
- 12/01/03
- Winksele (Herent)
- 9,782
- 40 (100%)
- 13/63
& die greater heal oplossing werkt nogaltijd niet weg dat flash heal ong.
even goed healt over zelfde tijd..
ze moeten healing echt boosten imo, dat klein beetje beter dan een andere
healing class imo.. vo mij moge ze dan shadow zo laten of zelfs een beetje nerfe..Education costs money, but then so does ignorance.no votes
25-01-2006, 01:07 #13Member
- 4,323
- 27 (100%)
- 13/21
zal wel fake zijn, maar kvind;
zeker geen slecht idee..
das een lev20 spell eh, @l60 zal dat wel iets gelijkwaardig zijn van een crystal mana drink.. dus 4400mana/30sec..
ksnap wel nie waarom ge weer out of combat moet zijn (jaja anders kunne we evengoe mage rolle, i get the point half & half), da maakt de NE spell weer compleet useless..
waarom zoude als NE priest u nie gewoon neerzette, drinken & shadowmeld gaan? oh nee we gaan m'n racial gebruik & me ondertusse late ambushe door ne rogue..// Mine i7 6700k @ 4.6Ghz 1.25v - EKWB Cooled // Asus Maximus VIII Formula // 32GB Corsair DDR4 3000 // EVGA 3080 FTW3 Ultra //
2x Samsung EVO 1TB SSD // Corsair AX860i // LG 34GN850 + Acer XB271HU // In Win 909
// Vriendin i7 7700k @ 4.8Ghz 1.28v - Noctua D15S // Asus Maximus VIII Hero // 16GB Corsair DDR4 3000 // MSI 1080 GTX Gaming X //
Samsung Evo 512GB - WD Livebook 4TB // Corsair AX750 // Dell S2716DG 144hz 1440p Gsync // Corsair 750Dno votes
25-01-2006, 01:15 #14Approved 9-lifer
- 30/11/03
- Zemst/Mechelen
- 12,443
- 1/69
Staat nog niet eens ne note bij in de aard van "all talentpoints will be refunded"
Vorige nick: "conquerpoy_123"no votes
25-01-2006, 01:32 #15
uhm fear ward wordt 31 punt in discipline en divine spirit mana kost gaat omlaag... maar waar staat divine spirit dan?
kusjeno votes
Headphones on, world off
