    SithCloud's Avatar
    murp
    Handige ab macro.
    De post is in het engels, omdat ik het op ons guildforum had gezet... Ik denk dat vele dit wel zullen apprcieren....
    I finally found out how to anounce an incoming player to /RS and the raid by simply pressing a button...
    Just do /macro.. give it a nice name and picture and copy paste the below code:
    /script CT_RA_AddMessage("MS " .. UnitClass("target") .. " : %t Incoming at ".. GetMinimapZoneText())
    /script SendChatMessage(UnitClass("target").." : %t Incoming at "..GetMinimapZoneText(),"RAID")
    This will sent the incoming class and name to /rs.
    For example:
    "Mage: Aeoronic Incoming at Stables"
    "Warrior: Aekie Incoming at Gold mine"
    If you delete the %t he will just show:
    "Mage: Incoming at Stables"
    "Warrior: Incoming at Gold mine"
    Mind you, you need to have the player targetted while clicking, or else he will give an error
    This will save you a lot of problems.
    Rogues can change this macro for example into:
    /script CT_RA_AddMessage("MS " .. "I'm going to ninja: ".. GetMinimapZoneText())
    /script SendChatMessage("I'm going to ninja: "..GetMinimapZoneText(),"RAID")
    This doesn't require a target of course ^^ it's a lot easier to click some macro 3 times to get attention rather than typing it all the time.
    Anyway, hf, I hope it gets in handy..
    Oh yea, it shows the position on the map (like the little text above your minimap in top right corner), so sometimes it might just say "arathi bassin" because you are not near the blacksmith, stables, etc .....
    So it's mainly good for defenders, or ninja'ers
    When in trouble, fear or doubt, run in circles, scream and shout
    SideShow's Avatar
    Roeselare
    nice nice, eens doen zie
    No Fun At All's Avatar
    [A]-Brasschaat
    heel handig inderdaad , danku
    BeeLz's Avatar
    een nuttige post van shitcloud
    nice
    Recedite, Plebes
    FLuoKaBouTeR's Avatar
    Nice
    SithCloud's Avatar
    murp
    De lui op het ui-forum van wow-europe hebben mijn script geoptimaliseerd... het ziet er nu als volgt uit :
    /script txt="Incoming at "..GetMinimapZoneText();if(UnitName("target")) then txt=UnitClass("target")..": "..UnitName("target").." "..txt;end;CT_RA_AddMessage("MS "..txt);SendChatMessage(txt,"RAID");
    Hiervoor moet je geen target hebben en ga je geen error krijgen (dus hij zal zowiezo iets zeggen)
    aeronic & aekie :P
    gij speelt dus op Bladefist
    SithCloud's Avatar
    murp
    nog ene dat het ontdekt heeft^^ liye heeft het al mogen voelen dat ik op bladefist zit !
    <3 xxxx next time, tyrs hand
    Bouftou's Avatar
    Dilb33k
    ow nice macro's direct keer maken ze en hop naar ab
    Zeroboy's Avatar
    aeronic en aeki,als ge tege die hun raids outkomt met een PuG ist in minder dan 10 minuten gedaan altijd
    Ot: nice marco ruchia
    Zeroboy - 60 warrior
    Isdilïen - 60 mage
    Proserphone - 39 priest
    langun's Avatar
    Oostkamp
    nice macro, ziet er wel moeilijk uit thank god for copy/paste
