    Exclamation Delta Labs L2 North
    CRYO storage bins.
    Wat is de bedoeling dat je doet met het bedieningspaneel van de robot die de storage bins in en uit de muur kan halen. Zit hier beetje vast.
    Z!zZ's Avatar
    Malines
    Simply take down the crate in the upper-right slot, then put it back, but jump onto the crate before the arm lifts it. Once the crate is returned to slot #3 with you on top of it it'll be easy to jump onto the ledge nearby, pick up the plasma cells, and proceed into the vent next to them.
    Enjoy ; )
    Merci meestal blijkt het probleem simpel.
