Thread: 2h dmg warrior build
10-12-2005, 23:04 #1
Arms Talents (31 points)
# Improved Rend - 3/3 points
Increases the bleed damage done by your Rend ability by 35%.
# Deflection - 2/5 points
Increases your Parry chance by 2%.
# Tactical Mastery - 5/5 points
You retain up to 25 of your rage points when you change stances.
# Improved Charge - 2/2 points
Increases the rage generated by your Charge ability by 6.
# Improved Overpower - 2/2 points
Increases the critical strike chance of your Overpower ability by 50%.
# Deep Wounds - 3/3 points
Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 seconds.
# Impale - 2/2 points
Increases the critical strike damage bonus of your abilities in Battle, Defensive, and Berserker stance by 20%.
# Two-Handed Weapon Specialization - 5/5 points
Increases the damage you deal with two-handed weapons melee weapons by 5%.
# Axe Specialization - 5/5 points
Increases your chance to get a critical strike with Axes by 5%.
# Sweeping Strikes - 1/1 point
Your next 5 melee attacks strike an additional nearby apponent.
# Mortal Strike - 1/1 point
A vicious strike that deals weapon damage plus 85 and wounds the target, reducing the effectiveness of any healing by 50% for 10 seconds.
Level 48: Damage plus 110
Level 54: Damage plus 135
Level 60: Damage plus 160
Fury Talents (20 points)
# Cruelty - 5/5 points
Increases your chance to get a critical strike with melee weapons by 5%.
# Unbridled Wrath - 5/5 points
Gives you a 40% chance to generate an additional Rage point when you deal melee damage with a weapon.
# Improved Cleave - 3/3 points
Increases the bonus damage done by your Cleave ability by 120%.
# Piercing Howl - 1/1 point
Causes all enemies near the warrior to be dazed for 6 seconds.
# Blood Craze - 1/3 point
Regenerates 1% of your total health over 6 seconds after being the victim of a critical strike.
# Improved Execute - 2/2 points
Reduces the Rage cost of your Execute ability by 5.
# Enrage - 3/5 points
Gives you a 24% melee damage bonus for 12 seconds up to a maximum of 12 swings after being the victim of a critical strike.
Protection Talents (0 points)
# None
nog iets aan veranderen?
Lust brings Envy..no votes
11-12-2005, 00:59 #2
hmm ik zou zelf bij arms toch nog anger management nemen
dan bij fury zou ik zeker geen unbridled wrath neme
da is puur als ge gaat dual wielden goe , het geeft 1 rage bij en bij een 2h gade zeer traag slage dus...
blood craze is imo ook ni de moeite
imo beter improved battle shout 4/5
en dan 5/5 in enrageno votes
11-12-2005, 01:10 #3
okay
bedankt voor commentaar
bij nader inzien, is idd wel beter, had wat beter moeten nadenken toen ik het maakte
11-12-2005, 01:29 #4
komt dus eigenlijk gewoon op cookie cutter uit
trouwens , wat bedoel je precies met 2k dmg? das bijna alleen mogelijk als jij ashkandi hebt en tegenstander geen armor (unbuffed dan) had'k gelezen
behalve met execute dan, maar dat telt niet
kusjeno votes
11-12-2005, 02:20 #5
em, ofwel ben ik blind.. ofwel zie jij spoken, wie zei er iets van 2k dmg?
11-12-2005, 03:52 #6Member
- 24/07/02
- Edegem
- 3,369
- 25 (100%)
- 2/22
dump enrage, bloodcraze & unbridled wrath
neem imp BS, booming voice en anger managementIl y a des gens qui parlent beaucoup, mais ne disent rien du tout
You ever notice how people who believe in creationism look really unevolved?
11-12-2005, 05:37 #7Member
- 09/06/03
- Overpelt
- 2,746
- 2 (75%)
///Corsair R500 Black Case - Corsair TX750M PSU - Gigabyte Z68XP-UD4 - Intel i5 2500k – Corsair Vengeance 2 x 4 GB DDR3 - Gigabyte GeForce 560 Ti - 120 GB OCZ Vertex 2 SSD – 3 TB HDDno votes
11-12-2005, 11:56 #8Member
- 19/11/03
- sinnekloas
- 4,419
- 5 (100%)
- 3/189
11-12-2005, 12:02 #9Banned
- 23/02/04
- Brugge
- 27,225
- 33 (97%)
- 18/145
11-12-2005, 12:10 #10Banned
- 12/02/04
- San Andreas
- 2,910
kunde met OEB ook ze ... (mits enrage
11-12-2005, 12:42 #11no votes
11-12-2005, 12:44 #12no votes
11-12-2005, 12:58 #13Member
- 19/11/03
- sinnekloas
- 4,419
- 5 (100%)
- 3/189
11-12-2005, 16:45 #14Approved 9liver
- 27/06/03
- Waregem
- 3,311
- 1/3
Ligt da aan mij of is op die screen precies uitgezoomed geweest?
|| OriginID: Sunaa_beno votes
12-12-2005, 01:06 #15Member
- 06/05/03
- Vosselaar & Turnhout
- 461
- 17 (95%)
jazeker
wa dacht ge van:
Impale - 2/2 points
Two-Handed Weapon Specialization - 2/5 points
Increases the damage you deal with two-handed weapons melee weapons by 2%.
Sword Specialization - 5/5 points
Gives you a 6% chance to get an extra attack on the same target after dealing damage with your Sword.
Improved Hamstring - 3/3 points
Gives your Hamstring ability a 15% chance to immobilize the target for 5 seconds.
Booming Voice - 5/5 points
Increases the area of effect and duration of your Battle Shout and Demoralizing Shout by 50%.
Unbridled Wrath - 1/5 point
Gives you a 8% chance to generate an additional Rage point when you deal melee damage with a weapon.
Blood Craze - 3/3 points
Regenerates 3% of your total health over 6 seconds after being the victim of a critical strike.
Enrage - 5/5 points
Gives you a 40% melee damage bonus for 12 seconds up to a maximum of 12 swings after being the victim of a critical strike.
None
waarom zo en nie zoals van u
reken uit Sword spec > Axe spec dus zoek maar goei zwaard ( beter als reaper dus...)
das wel boeiend 1 extra rage punt, niet dus, nutteloos# Unbridled Wrath - 5/5 points
wtf? weet gij hoeveel damage da schilt ?# Improved Cleave - 3/3 points
cleave rank 5 = +50 dmg dus da +120% ( 60 ) = 110 dmg + weapon damage whoopie, nutteloos
weer totaal nutteloos 1 rage is 15 extra damage dus 75 extra damage jeuj je kan beter in enrage steken# Improved Execute - 2/2 points
dus da schilt 3% damage me mijn build is dus ook 10x niks imp hamstring ftw# Two-Handed Weapon Specialization - 5/5 points
en waarom ik
erbij zet, simpelBooming Voice - 5/5 points
Als een rogue of druid in stealth zit of vanished en je doet demo shout verbreek je de stealth en dus zie je hem en is hij d00d
zeg maar wa ge er van vind...
greetz Parmenion
PS: Dit is een goeie talent tree, je bent vrij om hem te gebruiken maar dat betekend niet dat je ineens beter gaat spelen, dat ligt puur aan je skills of je nu goed of slecht bent in PvP..
Ik ga niemand gameplay tips geven, toch teminste niet onvrijwillig
Last edited by Parmenion; 12-12-2005 at 01:35. Reason: iets er vergeten bij te zetten
#9lives.Sc
Mist.Parmenionno votes
