03-12-2005, 18:52 #1
60FPS cap in quake4 online + gampad vraagje.
Is er enige manier om het framerate wat op te krikken?
Want 60fps is een beetje laag of nie?
85FPS zou nice zijn btw...
Nog een ander vraagje:
Is het mogelijk een gamepad te gebruiken in quake4?P75mhz + modem14.4k and playing multiplayer doom and quake1 shareware version online.
03-12-2005, 19:05 #2Approved 9-lifer
- 30/09/02
- Kasterlee
- 6,160
- 11 (100%)
- 8/25
03-12-2005, 19:07 #3P75mhz + modem14.4k and playing multiplayer doom and quake1 shareware version online.
03-12-2005, 19:32 #4Member
- Ottenburg
- 4,220
- 1/33
Gaat niet. Is zelfs niet server-related. Tis hard coded in de engine.
03-12-2005, 19:35 #5
Don't forget, Quake 4 is capped at 60 frames per second* just like Doom 3, so the aim in your tweaking will be to get as constant a 60 as often as possible, as with the speed of the movement in the game, you really will notice the lower frame rates.
*You CAN remove this limit, but unlike Quake III Arena where the framerate was tied to game physics, Quake 4 doesn't have this issue. However should you wish to remove the cap, add this to your autoexec -
set com_fixedTic "-1"
Chances are removing the cap is not going to improve your game performance, so there is little point in changing this. Default setting is 0.
...0 is default en aan ,het kan ook 1 zijn ipv -1
verder om je maxrefresh aan te passen
com_maxrefresh(rate) "refresh uw monitor" is standaard 60no votes
03-12-2005, 19:53 #6
Ok dus niet meer dan 60fps.
IK wil wel graag mijn gamepad doen werken in q4 maar hoe?
In Q3 was dat geen probleem...P75mhz + modem14.4k and playing multiplayer doom and quake1 shareware version online.
07-12-2005, 01:48 #7
com_maxrefresh "100"
doet nix - da blijft op 63 fps steke ?no votes
07-12-2005, 04:52 #8Approved 9liver
- 19/07/02
- 3,495
- 0/102
waarom in godsnaam zoude met gamepad willen werken ?
07-12-2005, 10:00 #9Member
- 30/09/02
- Antwaarpe
- 729
- 3 (80%)
snap ni wrom da iedereen persé meer fps wilt ... vroeger ware alle quakers fpshoeren gewoon omdagge daar voordeel uithaalde ...
Nu maaktet genne zak meer uit mor toch wille ze meer dan 60fps
Dus zeg mij ne keer wrom gij meer dan 60 fps wilt, toch ni omdattet dan vlotter draait zekers? want das dus dikke zever
Every day of my life I'm forced to add another name to list of people who piss me offno votes
07-12-2005, 11:36 #10
waarom is ne ferrari mooier dan ne corsa ? - voor dezelfde reden dat een 100 fps game mooier is dan een 60 fps game
07-12-2005, 12:16 #11Member
- 30/09/02
- Antwaarpe
- 729
- 3 (80%)
Das een domme vergelijking ... want kwa snelheid zit er geen verschil tussen die 60 fps en 100 fps ... kwa physics dan
Derbij , der zijn misschiens mense die ne corsa mooier vinden dan ne ferrari
07-12-2005, 13:37 #12Member
- 14/01/04
- Oostnieuwkerke
- 676
Om nog es over da gamepad te hebben.
Welk gamepad is dat wel dat je het voor Q4 wilt gebruiken?
Kpeis dat ge ferm geowned zult worden zunne als gij met een normaal gamepad gaat spele.no votes
07-12-2005, 13:54 #13Member
- Wilrijk
- 1,994
- 0/16
Ge ziet zeker het verschil tussen 60 en 100 fps, misschiens hebt gij daar geen last van maar de meeste mensen merken dat welDus zeg mij ne keer wrom gij meer dan 60 fps wilt, toch ni omdattet dan vlotter draait zekers? want das dus dikke zever
60fps is gewoon fixed omdat ze te lui waren om hun physics code fatsoenlijk te schrijven, was ook al zo bij Q3
voor Q3 hadden CPMA en OSP uiteindelijk fps-independent physics, dus nu Arqon QMAX aan het doen is zullen we hopelijk ook na een tijdje fps-independent physics in Q4 hebben.
com_fixedTic veranderen gaat trouwens op dit moment nooit betere resultaten opleverenno votes
07-12-2005, 14:04 #14
tis precies alsof ik een antiek spelleke ben aant spele
07-12-2005, 14:18 #15
let op het woord "mooier"
niet "sneller"
- en ja er zijn mss wel mensen die ne corsa mooier vinden, mr al stel ik dat er wereldvrede zou moeten zijn of dat de honger de wereld uit zou moeten worden geholpen - er gaat altijd ergens wel een dipshit zijn die wel zou afkomen met een reden waarom het niet zo zou moeten zijn - maar er wordt wel algemeen aangenomen dat een ferrari een grotere estetische waarde heeft dan een corsa
60 of 100 - ik denk dat de meesten wel liever 100 fps hebben, zeker als je al jaren 100 fps games hebt gespeeld & dan ineens deze shit voorgeschoteld krijgt
