    SephirothSnake's Avatar
    Sint Truiden
    44 (100%)
    admin worden in mani_admin_plugin via smartFTP
    adminlist.txt
    This is where you place all your admins that you wish to have access to the administration features. The default file explains how to setup your admins.
    Edit the file $BASE/cstrike/cfg/mani_admin_plugin/adminlist.txt
    NOTE : The flags represent what you DON’T want administrators to have access to, if you want access to ALL functions then don’t add flags.
    For reference here is an example extract: -
    // Add your IP's Steam addresses, Names and Passwords
    // in this file for admins
    // e.g STEAM_0:0:21233123
    // 213.44.33.47
    // ADDING FLAGS MEANS YOUR ARE STOPPING ADMINS FROM USING
    // THOSE OPTIONS UNLESS YOU HAVE mani_reverse_admin_flags set to 1
    // in your autoexec.cfg
    // Restriction options are :-
    // k = restrict admin from kicking players
    // r = restrict admin from executing rcon commands via ma_rcon
    // q = restrict admin from executing rcon commands from the menu
    // e = restrict admin from the adminexplode command
    // m = restrict admin from slaying players
    // b = restrict admin from banning players
    // s = restrict admin from running ma_say
    // o = restrict admin from running ma_chat
    // a = restrict admin from running ma_psay
    // c = restrict admin from changing maps
    // p = restrict admin from playing sounds
    // w = restrict admin from restricting weapons
    // z = restrict admin from plug-in config menu
    // x = restrict admin from running admincexec commands
    // y = restrict admin from running admincexec from the menu
    // i = restrict admin from running blind commands
    // l = restrict admin from running slap commands
    // f = restrict admin from running freeze commands
    // t = restrict admin from running teleport commands
    // d = restrict admin from running drug commands
    // g = restrict admin from running ma_teamswap and ma_balance commands
    // j = restrict admin from running gimp commands
    // R = restrict admin from running rcon vote
    // v = restrict admin from running random vote map
    // V = restrict admin from running vote map
    // Q = restrict admin from running question vote
    // C = restrict admin from running Cancel Vote
    // A = restrict admin from being able to accept/refuse a vote they started
    // B = restrict admin from running a menu rcon vote
    // D = restrict admin from running a question menu vote
    // E = restrict admin from using ma_rates
    // F = restrict admin from running burn commands
    // G = restrict admin from running noclip command
    // H = restrict admin from running ma_war command
    // I = restrict admin from running ma_mute command
    // J = restrict admin from resetting all the player ranks
    // K = restrict admin from setting player cash
    // L = restrict admin from using rconsay commands setup as type R in commandlist.txt
    // M = restrict admin from having custom skins to choose
    // N = restrict admin from being able to set a players skin
    // O = restrict admin from running ma_dropc4 command
    // P = restrict admin from running ma_setadminflag command
    // T = restrict admin from running ma_timebomb command
    // U = restrict admin from running ma_firebomb command
    // W = restrict admin from running ma_freezebomb command
    // X = restrict admin from running ma_sethealth and derived commands
    // Y = restrict admin from running ma_beacon command
    // S = restrict admin from running ma_setcolour or ma_setcolor
    // Z = restrict admin from running ma_give and ma_giveammo
    // An example would be if you wanted to prevent admin
    // with steam id STEAM_0:0:2388333
    // from being able to play sounds and rcon command
    // STEAM_0:0:2388333 rp // Admin can't rcon and play sound !!
    // Another example
    // STEAM_0:0:3389333 kmc // Admin can't kick, slay or change maps
    // You can also use admin groups instead of flags, you setup admin groups
    // in the admingroups.txt file then use them in this file.
    // For example if you setup a group called "Clan Member" and "Kick Only" you would set it per
    // player like this:-
    // STEAM_0:0:1234234 Clan Member // Fred
    // STEAM_0:0:234884 Kick Only // Jim
    // If you wanted an admin to be created by IP Address you
    // set your entry to be in the format
    // ;IP Address flag
    // Example
    // ;213.133.76.58 rp // Admin can't rcon and play sound !!
    // ;113.124.36.2 kmc // Admin can't kick, slay or change maps
    // If you want to have an Admin created by both steam ID and IP address you
    // use the format STEAM_ID;IP_ADDRESS flags
    // Example
    // STEAM_0:1:877489;231.192.67.5 rp // Admin can't rcon and play sound !!
    // IMPORTANT NOTES !!!!
    // If you only use an IP Address, the character ';' MUST be directly in
    // front of it.
    // There must be a space between the steam ID/IP Address and restriction flags
    // or the plug-in will assume that it is part of the Steam ID/IP Address
    // Another alternative to using a steam id is a name and password
    // The format of this is ;;"name";password flags
    // For example I would use
    // ;;"Mani";maniadminplugin rp // Admin can't rcon or playsound
    // In order to use the password, put
    // setinfo _password mypassword
    // in your config.cfg file in your client installation.
    STEAM_*:*:***** // nickname <- kan alle commands uitvoeren
    STEAM_*:*:***** pzxydgjRvQCBD // nickname <- beperkte cmd
    (dit weglaten alles hierbovenstaat is goed voor in een adminlist.txt te plaatsten)
    ksnappet ook nie goe lol
    candycrash's Avatar
    St.-Niklaas
    mijn foutje
    heb zijn post aangepost naar zijn vraag, hopelijk was het goed
    vraag was waar hij de id's moest zetten
    maar had geen zin om alles te c/p
