    yannick's Avatar
    (Mijn :p) Oplossing Datacache error (=Looping crash sound)
    Dus, sinds ik echt te zot werd van die datacache error en dus ook de looping sound crash ben ik gaan speuren.
    Na een lange zoektocht (1.5 maand, wegens TE lui ) ben ik terecht gekomen bij een post in het steam forum:
    Forum Thread.
    Dat heb ik dus voor 3/5 door gelezen en heb enkele oplossingen gevonden.
    1. De PCI tool: Pci download
    Uitleg van Steam Forum:
    This tweak is an important one, and one well worth checking into. Apparently, newer high-end video cards hog PCI latency for no known reason. This makes other components wait for access and causes stutters and thus lower frame rates. If you adjust the latency this might benefit you, users are reporting big improvements.
    You can download this small utility program that allows you set your PCI latency. Adjust the PCI latency from for example 248 to 64, and there's a very good chance of stutter free performance & sound.
    STEP 1. open the pci latency tool
    STEP 2. Rightclick on your graphics card and click change setting(s)
    STEP 3. change to desired setting and hit ok
    Step 4. click settings and select apply at startup so it has a tick next to it
    STEP 5. click settings and select save so everything you have just done is saved
    STEP 6. right click on your video card and click quickset latency (if you want to set it straight away).
    My Evga booklet for my 6800nu unlocked 16/6 states u should set youre pci latency to 128... but most peoples is set at 248... try 128 then if thats not good enough.. try 64 or 32... if u want more explanations on this go to guru3d forums and search pci latency with a huge sticky that well explain it to a T..
    2. Molexkabel(power) checken die naar GFX kaart gaat
    Uitleg van Steamforum
    1. open up your case and look at the molex connectors (power)
    2. My guess is that you have molex connected to your gcard and then branching off into your hard drive, so make sure that only ONE cable goes into your graphics card.
    3. Have the other seperate molex connectors hooking up to the rest of your devices ie hard-drive and dvd drives etc. BUT make sure that x850(geld voor alle gfx kaarten) just has a molex for itself only!
    Anyway check that out and let me know how it goes. If you had it set up as described in step 2, this could cause a voltage drop causing your comp to reboot all the time. lol... u can try that out too
    3. Ram checken
    Hier was ook een uitleg van in dezelfde thread (Forum Thread) maar deze ik vind het niet meer.
    Ze zeggen dus gewoon, probeer andere ram of als je 2*512mb hebt, probeer er 1 uit te nemen en dan te testen(lukt het niet, probeer andere stick).
    Zelf heb ik andere ram gepakt (2*512 GEIL ram ipv 2* 512 TwinX corsair ultra high performance)
    4. Fastwrites afzetten (in bios)
    Dit heb ik zelf NIET geprobeerd, maar het blijkt bij veel mensen te werken .
    In deze thread staan nog meer mogelijke oplossingen die eventueel kunnen helpen.
    Ik weet dat dit lijkt op weer meer zever, dat dacht ik ook eerst (ik heb ook werkelijk ALLES geprobeerd) en deze drie dingen werken dus werkelijk .
    Ik weet enkel niet welke van de drie .
    Zo ik heb geprobeerd jullie een helpende hand toe te steken, ik hoop dat dit veel mensen gaat helpen .
    Kheb allesinds een poging gedaan !
    Veel Succes!
    yannick's Avatar
    duss, werkte da voor iemand ?
