    Axel's Avatar
    gent
    check my rogue build plz
    hier is men rogue build, gelieve er ff naar te kijken en commentaar te geven aub,
    zelf vin ik da ik er zeer goed mee kan spele (kan in 1vs1 nen mob aan die 2lvls hoger is dan ik)
    Code:
    Assassination
    Improved Eviscerate
    Rank 3/3
    Increases the damage done by your Eviscerate ability by 15%.
    Malice
    Rank 5/5
    Increases your critical strike chance by 5%.
    Ruthlessness
    Rank 3/3
    Gives your finishing moves a 60% chance to add a combo point to your target.
    Relentless Strikes
    Rank 1/1
    Instant
    Your finishing moves have a 20% chance per combo point to restore 25 energy.
    Lethality
    Rank 5/5
    Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ghostly Strike, and Hemorrhage abilites by 30%.
    Assassination Total: 17
    Combat
    Improved Sinister Strike
    Rank 2/2
    Reduces the Energy cost of your Sinister Strike ability by 5.
    Lightning Reflexes
    Rank 3/5
    Increases your Dodge chance by 3%.
    Deflection
    Rank 5/5
    Increases your Parry chance by 5%.
    Precision
    Rank 5/5
    Increases your chance to hit with melee weapons by 5%.
    Dagger Specialization
    Rank 5/5
    Increases your chance to get a critical strike with Daggers by 5%.
    Dual Wield Specialization
    Rank 5/5
    Increases the damage done by your offhand weapon by 50%.
    Combat Total: 25
    Subtlety
    Camouflage
    Rank 5/5
    Increases your speed while stealthed by 15%.
    Opportunity
    Rank 4/5
    Increases the damage dealt when striking from behind with your Backstab, Garrote, or Ambush abilities by 16%.
    Subtlety Total: 9
    Total
    Total Points Spent: 51
    Level Required: 60
    zoals je kunt zien heb ik maar 4 punten in opportunity, zou het de moeite zijn om ergens anders een punt weg te laten en da daar in te steken??
    greetz
    If you are reading this then you are wasting 5 seconds of your life
    oya's Avatar
    San Andreas
    camouflage? weg imo
    geen cold blood?
    dagger of sword/mace spec?
    Desperadoooo's Avatar
    Koersel !
    -1 (0%)
    Euh geen coldblood, geen adrenalinerush, geen prep, geen riposte maar toch 5/5 deflection.
    Vind het maar een rare build, ge laat al de waardevolle abilities blijkbaar liggen. En dno 2 lvls hoger, moet da nie normaal 4 lvls zijn oO
    Axel's Avatar
    gent
    Quote Originally Posted by Axel
    Rank 5/5
    ik denk daggers
    en als ik camouflage wegdoet kan ik niet verderdoen met opportunity
    tenzij ik iets anders zou pakken in subtlety
    enige voorstellen??
    scel's Avatar
    sterf
    ik denk daggers
    enige voorstellen??
    master of deception
    kusje
    VV@rl()rd's Avatar
    Waregem
    jup zeker mod pakken. en wat ben je met die parry en dodge talents. zijn toch betere hoor .
    ?therapy?'s Avatar
    Rio De Janeiro
    Ambush/Backstab Build
    Assassination Talents (21 points)
    Improved Eviscerate - 3/3 points
    Malice - 5/5 points
    Remorseless Attacks - 1/5 point
    Murder - 2/2 points
    Ruthlessness - 3/3 points
    Relentless Strikes - 1/1 point
    Lethality - 5/5 points
    Cold Blood - 1/1 point
    Combat Talents (8 points)
    Improved Gouge - 3/3 points
    Lightning Reflexes - 2/5 points
    Improved Backstab - 3/3 points
    Subtlety Talents (22 points)
    Master of Deception - 5/5 points
    Opportunity - 5/5 points
    Improved Ambush - 3/3 points
    Initiative - 5/5 points
    Improved Sap - 3/3 points
    Preparation - 1/1 point
    da is mijn build voor daggers
    VV@rl()rd's Avatar
    Waregem
    das de build die alle ordinaire rogues emme . ikzelf heb hem niet want wil toch beetje unqiue blijve =)
    ?therapy?'s Avatar
    Rio De Janeiro
    Quote Originally Posted by VV@rl()rd
    Weljah kheb die gewoon copy/paste gedaan uit een rogue build thread hier kheb hem ondertussen ook al wat veranderd enzo ze
    Maar is zeker een goeie om mee te beginnen
    Cakeman's Avatar
    Mol / Bree
    Als je Night Elf bent, is die MoD niet noodzakelijk aangezien Night Elves een betere stealth hebben (die komt overeen met 3 ranks in MoD).
    Dan is Camouflage een prima alternatief als je toch tier 2 of 3 skills uit de Subtlety tree wil.
    bounce\'s Avatar
    54 (100%)
    welke class ni ?
    nTo*Apoq: NEE GEEN INSTA
    nTo*Apoq: dit is echt zon pannekoekenmod
    Last.FM
    VV@rl()rd's Avatar
    Waregem
    Quote Originally Posted by Cakeman
    bwa ja iedere rogue heeft 5 in mod dus zit ik weer in het nadeel en heb ze beide in me talent tree dusja .
    Li0n's Avatar
    Wilamette Mall
    Lol @ build.
    Geen improved backstab of ambush , waarom dan punten in oportunity?
    Dagger spec en dual wiels spec is nutteloos.
    serieus , ik hoop dat ge nog ni gerespect hebt naar deze build
    Enkele dagger builds
    21/8/22
    http://www.wow-europe.com/en/info/ba...55003003100000
    31/8/12 mijn build
    http://www.wow-europe.com/en/info/ba...50002000000000
    Rider's Avatar
    dagger build is imo toch zowieso builden naar Prep & CB.
    Voor de rest, in hoge instances, gaat ge wellicht 3/3 sap nodig hebben, met zowieso zoals bovenvermeld die 2 skills in combat (imp gouge, backstab)
    Hetgeen daartussen zit is imo nogal smaak gebonden. SNeller lopen in stealth (camouflage) is imo de betere PVP keuze, terwijl MOD 5/5 dan weer PVE gerichter zal zijn.
    ik persoonlijk heb zowa identiek de build die hierboven vermeld staat [21/8/22]
    noi viviamo sommersi nel fondo d'un pelago d'aria
    -E. Toricelli
    HCTerrorist's Avatar
    Bilzen
    Ik heb ook 21/8/22. Ik had deze dus zelf samengesteld, geloof het of niet, en deze bleek echt veel gebruikt te worden. Maar ik had deze nl. al toen de meeste Rogues Sword waren(begin van WoW) en heb nog niet eens Swordskill geleerd .
    Heb veel getwijfeld om niet Seal Fate te nemen voor MC, Vigor geef ik die extra punt niet an, dan moet ik imp backstab/ambush 1tje laten vallen, en daar dat doe ik echt niet. Warom ik Seal fate niet genomen heb onderandere: Initiative voor de fast kills, 75% voor extra combo bij opening + Preparation. Maar met imp backstab en hoge critchance is Seal fate wel ubervet voor bv MC.
    Maar build is iets persoonlijk, wat zoeken en tasten
    Reservation at Dorsia
