    Mono's Avatar
    UT2k4 AMD 64bit Patch
    Epic Games has released an AMD 64bit patch for the retail version of Unreal Tournament 2004, which allows players to squeeze a bit more performance out of the popular FPS. This patch is only meant for WinXP and an AMD 64bit CPU. Click here to download or hit more for further information.
    "This is a native, 64-bit version of Unreal Tournament 2004 for Win64 (or "Windows XP 64-bit Edition", or "Windows for x64", etc).
    To install:
    - Install the retail version of UT2004 on Win64 from the retail disc(s). The free demo version will not be sufficient for this. The installer on the disc is a 32-bit program, but it will run fine on Win64.
    - Patch the installation to version 3355 (available from http://www.unrealtournament.com/). The update program is also 32-bit but, again, will run fine on win64.
    - Unpack this .zip file into the directory where you installed the game, so that "ut2004-win64.exe" ends up in the game's "System" directory, "ut2004-win64Logo.bmp" ends up in "Help", etc...
    - Run the ut2004-win64.exe from the game's "System" directory.
    Minimum System Specs for 64-Bit Version:
    Supported OS: Windows® XP, Windows® XP Professional x64 Edition
    Processor: AMD Athlon™ 64 processor 2800+ or equivalent
    RAM: 128MB
    Video Card: 64MB DirectX® 9.0 compatible graphics card
    Sound Card: DirectX 9.0 compatible PCI card
    DirectX Version: DirectX 9.0 included with 64-bit OS
    CD-ROM: 6X DVD or 16X CD-ROM
    Hard Drive Space: 5.6 GB Free (for both retail version & 64-bit version)
    Multiplay: 33.6 Kps modem for LAN/Internet play
    Recommended System Specs for 64-Bit Version:
    Processor: AMD Athlon™ 64 processor 3400+ or equivalent
    RAM: 256MB
    Video Card: 128MB DirectX 9.0 compatible graphics card
    Sound Card: Sound Blaster® Audigy series recommended
    CD-ROM: 24X DVD or 24X CD-ROM
    Multiplay: Broadband Internet connection recommended
    * Note: Please see retail box for 32-bit OS system recommendations.
    Other notes:
    The Win64 version includes both a Direct3D9 and OpenGL renderer. The Direct3D 8 renderer (the default on win32) is not available, nor is the Pixomatic software renderer.
    The 32-bit version is still available on your system, and should not be affected by the existance of the 64-bit version. They even use seperate .ini files by default.
    ucc-win64.exe is the 64-bit version of the dedicated server.
    There is no support available for the 64-bit version of the game. Please do not contact Atari tech support about the Win64 version.
    Enjoy!
    --Epic Games."
    bron: cb ( http://www.clanbase.com/news.php?nid=189506&mid=0&lid=0 )
    Alleen installen als je winXP en een AMD 64bit CPU hebt natuurlijk
    sapere aude
    MetalG's Avatar
    Dendermonde
    41 (100%)
    tnx for sharing <o/
     iMac 27" late 2015, HP zbook 14" - Xperia Z3 16GB Black
    Sony A35 + Tamron 17-50mm 2.8
    DoEsYm@n's Avatar
    21 (86%)
    Kunde da nu zonder windows xp 64bit of met windows xp 64bit?
    In die "system specs" staat dus "Supported OS: Windows® XP, Windows® XP Professional x64 Edition". Nu kan ik ni volgen .
    Mono's Avatar
    wel ... in de readme staan er nogal wat contradicties:
    en
    "Minimum System Specs for 64-Bit Version:
    ik heb gewoon winXP en het werkt hier wel mooi niet
    sapere aude
    Antwerpen/Leuven
    6 (88%)
    w00t!!
    maja, wie heeft er nu xp 64bit
    #occ-outpost ut2kx **TDM
    Mono's Avatar
    inderdaad, ik ken zelfs niemand ... go go epic -_-
    sapere aude
    |M°B|Morbuus's Avatar
    Hopla-land
    gogo AMD
    tis lijk die farcry patch enkel voor AMD
    intel heeft dus ook 64 bit.
    Daar zit dus altijd duidelijk iet tussen.
    [BGT]IceCube's Avatar
    Stom, ik heb geen xp 64 bit. Geen flauw idee waar ik dat zou moeten halen .
    QUOTE=Brambo^ 'wat ben jij mooi icecube rules '
    Dark^Fact's Avatar
    Harelbeke
    -1 (0%)
    xp 64 bit ebde ni nodig, enkel nen amd 64bit processor
    ik heb die!!!&&!
    helaas speel ik nog zodanig veel ut2k4 dak het ni echt nodig vindt om dees te installen
    turnhout
    15 (94%)
    waarom ni? ge speelt toch zoveel zegde ???!!!!
    In a thousand years, there will be no men and women, just wankers, and that's fine by me.
    PissedNumlock's Avatar
    sterrebeek
    em wilt u ook nog een kans geven om te winnen malice, daarmee dat em zijne config nie optimaliseerd
    [20:23] <Raptor|2k4`rcou> wenn he shoot he hit me
    [20:23] <Raptor|2k4`rcou> this can not be fair2
    (17:19:54)(@QcK\Glenn`) twas gwn ne te grote
    DoEsYm@n's Avatar
    21 (86%)
    Hoe? Da werkt ook men nen gewone windows xp ofwa?
    COOLKILLer's Avatar
    kuch... nee...
    dan bolt et niemeer, aangezien ge 64bit OS nodig hebt (windows xp 64-bit)
    botchla's Avatar
    Winksele (Herent)
    40 (100%)
    Der staat juist in van nie :P
    Education costs money, but then so does ignorance.
    Bontus's Avatar
    Waasmunster
    ik heb nen 3500+ dus ik zal dit wel eens installeren
    merci eh
