    brammes's Avatar
    [BF2] 1.03 patch readme
    van EA ftp!
    Patch v1.03
    NEW FEATURES
    - Wake Island Map
    Included a remade version of this popular BF1942 map.
    Battlefield 2 version includes a 64 player layout and is
    configured for multiplayer only.
    - Server Favorites / History
    There is a new tab in the MULTIPLAYER menu that holds a list of
    the last 20 internet servers you have connected to, plus a list
    of servers you have selected as favorites.
    * Added a button to the other multiplayer tabs that adds the
    currently highlighted server to your favorites list.
    * Added buttons in the in-game server info menu (press TAB to
    access) that will add or remove the server you are currently
    playing on to / from your favorites list.
    - Account Login Welcome Screen
    After you login to an online account, a message appears that
    contains BF2 news and information which updates periodically.
    - Stat Compare
    By clicking the COMPARE button in BFHQ, you can search for another
    players name and load their current stats into BFHQ. Using the
    arrow buttons next to the name in the top-left corner of the menu,
    you can toggle between your stats and their stats.
    You can also load a player's stats by double-clicking on their
    name in any leaderboard.
    - Nickname Prefix
    You can add a 6-character prefix (such as a clan tag) to your
    account nickname which will be displayed in-game next to your
    nametag in the score menu, in game messages, and above your player
    in the game world.
    * This prefix does not change your account name or statistic
    information (e.g. the prefix does not appear next to your name
    on the leaderboards).
    * You can change this prefix at any time at the account login
    menu.
    - Server Reserved Slots
    You can define a list of player nicknames that will act as a
    "reservation list" for your server.
    * The list is located in mods\bf2\settings\ReservedSlots.con
    * You can add player names to the list by editing the file and
    adding the following text for each player :
    reservedSlots.addNick <account name>
    where <account name> is the player's registered account name,
    not including a nickname prefix (see above).
    * You can define the number of slots to set aside for reserved
    players in the dedicated server launcher, or with the setting
    sv.numReservedSlots <number> in your serverSettings.con file.
    * The number of players on the list and the number of reserved
    slots does not necessarily have to be the same.
    - Mod Support
    There are several new changes that improve support for mods.
    * When connecting to a server that is running a mod that you have
    installed but not activated, it will be automatically activated
    and you will load into the server.
    * Added a filter on the server browser for servers running the
    currently activated mod.
    * Fixed dedicated server launcher to properly handle launching mods.
    * Improved support for mods sharing archives with bf2
    - Improvements to in-game HUD / Map
    * The viewable area of the spawn menu / commander map is now scaled
    based on the out-of-bounds area so that only the playable area
    takes up the majority of viewable map space.
    * The names of CPs are now displayed on the spawn menu / commander
    map and minimap
    * The minimap zoom level now changes dynamically depending on the
    type of vehicle you are in. If you zoom in or out manually, that
    zoom level is remembered for that vehicle type next time you use
    it.
    * The names of players in your vehicle are displayed in the HUD
    when someone enters the vehicle or switches positions.
    * There is a new element in vehicle HUDs that displays the reload
    time for countermeasures (smoke and flares).
    * Flags for each team are now displayed below their ticket count
    on the minimap to make it easier to tell what team you are assigned to.
    GAMEPLAY CHANGES
    - Many criteria for ranks and awards have changed. If you are immediately
    eligible for a new promotion, unlock, badge, award, or ribbon, it will
    be awarded the next time you receive points on a ranked server.
    - Only 1 player in a vehicle will get credit for or speed up capturing
    a flag at a CP. The other passengers must exit the vehicle to increase
    the speed of capture or receive capture score.
    - Commanders no longer accrue a TK when artillery hits
    teammates.
    - The commander's supply drop now has an icon on the minimap and a 3D-
    map icon in the world.
    - Auto team balance no longer moves players to the other team if they
    are a team commander or a squad leader.
    - The wrench repair rate on helicopters has been decreased.
    - You now receive 1 support point for destroying an enemy commander's
    artillery, UAV or Radar station.
    - If you have received a point for healing, repairing, or resupplying
    a teammate, you will not receive another point from them for the same
    action for a set period of time.
    - Singleplayer enemies use the knife more effectively.
    - New engine sounds for the T98 tank.
    - New engine sounds for the China/MEC light jeep.
    - New cannon sounds on APCs.
    BUG FIXES
    - Fixed physics of vehicles against soldiers so that soldiers are not
    killed so easily by moving vehicles.
    - Fixed a physics issue that can cause you to be stuck when falling into
    shallow water
    - Fixed an issue with soldier armor when spawning on a squad leader in a
    vehicle
    - Fixed some objects that caused vehicles to take massive collision damage
    - Fixed erroneous message stating that you punished a TK when auto-
    punish is OFF on the server.
    - When a vehicle explodes due to external forces, the driver is no longer
    mis-credited for the kills.
    - Added turret movement sounds to several vehicles.
    - Fixed an issue that caused crosshairs to stay on the screen when
    switching camera views.
    - Fixed an issue that caused the time limit status of the server not to be
    sent to clients when it is changed by the server.
    - Fixed server setting sv.allowExternalViews. Setting this to 0 will
    disallow external views.
    - Added setting for interfaceIP to the server launcher
    - Changed automatic TK banning to ban by cd-key instead of IP address
    - Improved the stability of secondary position turrets to reduce jerkiness
    during movement.
    - Fixed spawning on squad leaders to prevent players from spawning where
    they should not.
    - Fixed issue with auto team balance not sending new players to the team
    with less players.
    - Set T90 top hatch armor to "Front Armor".
    - Set some wheels on jets and helpcopters to stronger armor to prevent
    them from being destroyed instantly by AT missiles.
    - Adjusted wheeled vehicle engines on hills to improve climbing.
    - Changed the Commo-rose behavior so that player does not leave crouch
    when using it.
    - Passwords entered to join password protected servers are now cleared
    after use.
    - Improved PLAY NOW functionality.
    - Fixed some memory usage issues in the front end.
    - Fixed an issue allowing color changes in player name text.
    - When you click on a server in the server browser, the information
    from that server is updated to be more accurate.
    - Fixed a crash in the Ranked Linux server when communication with stats
    back-end ceased.
    - Improved the behavior of AA missiles when locked on an enemy.
    - Fixed an issue where parachuting soldiers could not be healed.
    - Added the server port to the SERVER INFO tab.
    - Removed the SERVER INFO tab when playing singleplayer
    - Fixed an issue causing some soldier & vehicle control keys to be used
    for in-game menus.
    - Added new soldier artwork in BFHQ
    - Added name of video director to credits
    bron http://largedownloads.ea.com/pub/pat..._changelog.txt
    XR3I's Avatar
    Evergem
    18 (95%)
    khoop da mijn crashprobleem opgelost zal zijn...tis bij het enigste spel dak probs heb
    -DickHead-'s Avatar
    Merci!! Ik zie het al zitten
    50Euro's Avatar
    Moorsele
    Wa filmkes van Wake...
    Komen van IGN..
    Nintendo ID & PSN & Xbox Live & Steam: FiFtyEuro
    hendrik1's Avatar
    En waar is de fix voor de raketten die je losdoor voertuigen schiet? soit, ik zal er wel overgelezen hebben
    Littl' one's Avatar
    ik zie ook geen fix dat je machinegun soms geen dmg meer doet nadat je van tvguided naar machinegun omschakelt...
    Anub!s's Avatar
    Muizen
    Tis te hopen da ze da probleem me die dual core processors hebben aangepakt ja.
    Ik krijg ni anders dan disconnects. En na een week zoeken en googlen heb ik eindelijk gevonden da da wel is een probleem kan zijn met dual core machines (het had ook te maken met een bug in windows XP). Nu heb ik mij toevallig toch wel net zo eentje aangeschaft zeker. En sindsdien ben ik ook die problemen met disconnects tegengekomen.Ervoor op men voeige pc (die gecrashed is waardoor ik dus nieuw moest kopen) had ik geen problemen what so ever.
    Ik heb nu ondertussen ook al men pb geupdate, men firewall geconfigureerd (da is nu een kaas met gaten btw door al die poorten), men drivers allemaal geupdate naar laatste versies, battlefield uninstall en reinstall, netwerkkaartconfiguratie aangepast, ... Ben ik nog iets vergeten? Niets hielp.
    De enige oplossing zou zijn: wachten tot patch 1.03 en hopen dat die het oplost of anders wachten tot SP3 (wa nog ni direct zal zijn). Voorlopig zit ik dus nog hoopvol te downloaden maar als dit niet werkt moet ik experimentele updates aanvragen bij Microsoft.
    Echt wel dik gescheten dus. Zijn er hier trouwens nog die die problemen hebben dat je altijd gedisconnect wordt van server met de boodschap "Your connection to the server has been lost"?
    P.S.: Anders wel zonde van het geld want het is wel een goede game op de vele bugs na dan maar daar heb ik nooit geen problemen mee gehad op vorige PC.
