Thread: Escaper demo release!
18-09-2005, 17:56 #1
Na 3 dagen werk is het eindelijk zover, de Escaper demo is gereleased!
Hopelijk liggen de verwachtingen niet te hoog, veel plezier er mee.
Screenshot: http://xs46.xs.to/pics/05375/Escaper.jpg
Ik wil de beta testers enorm bedanken voor hun inzet en natuurlijk alle mensen die leuke reacties hebben gepost op het aankondiging topicje.ESCAPER GAME © V1.00 (demo) HTML homebrew game for PSP firmware v2.00
A Zerostudios production made by Kevin Haelterman (aka Betelgeuze)
EXPLANATION:
Try to escape the piramide of Ka and find your way trough the labyrint.
Use the analog stick or the directional buttons to navigate.
This demo version has only 2 levels (1 easy level and 1 normal level).
New levels will be available in the future.
The game is made with Adobe Photoshop, Adobe Imageready and its only based on HTML code.
INSTALLATION:
-You need PSP 2.0
-You need 7 MB on your PSP memory stick.
-Unrar the rar file to the ROOT of your PSP's memory stick its the topmost folder,
it has no name, it houses everything on the stick.
-Once unrared, you should see a "escaper" folder in the root directory, along with this readme.
-You can delete this readme.
-To run this game, go into your Web Browser and type: file:escaper/start.html
Add this adress to your bookmarks so you can use the bookmark to start the game the next time.
FULL RELEASE FEATURES:
-New levels with new textures.
-Mouse-Over intergration, for small animations.
-In-game link to the main menu.
-Unlock function for new levels.
-Online version so you dont have to place it on your memory Stick if you have internet connection on your PSP.
CREDIT:
-Project manager:
Kevin Haelterman
-Designer:
Kevin Haelterman
-Logo design:
Davy Boone
-Beta testers:
Mandy Haelterman
Davy Boone
Benjamin Rogiers
Jesse Sampermans
-Special thanks:
Sony PSP
Telenet-games
CONTACT:
E-mail Kevin Haelterman: zerogames@hotmail.com
In dit topicje zal ik binnekort ook wat uitleg geven over hoe je zelf levels kan ontwerpen en hoe creatieve gamers me kunnen helpen om een mooie full version klaar te stomen.
Opmerkingen en tips zijn altijd meer dan welkom, ik zal met zoveel mogelijk van jullie reactie rekening houden om de volgende release zo goed mogelijk te maken.
Download mirror 1 (5,5MB):
http://edraket.cheapass.be/Escapergame_PSP2.00(1).rar
(met dank aan edraket)
Download mirror 2 (5,5MB)
http://brecht.cheapass.be/escaper/Es...PSP2.00(1).rar
(met dank aan bt belgium )
Download mirror 3 (5,5MB)
http://users.pandora.be/mistabeen/e...ame_PSP2.00.rar
(met dank aan Davy Boone)
Download mirror 4 (5,5MB)
http://files.pspupdates.com/cgi-bin/...,1,0,0,12,1324
(met dank aan pspupdates.com)
Download mirror 5 (5,5MB)
http://users.pandora.be/rastaplace/...ame_PSP2.00.rar
(met dank aan OwA.Free)Last edited by edraket; 20-09-2005 at 18:21.
Co-Founder & Designer @ LuGus Studiosno votes
18-09-2005, 18:15 #2Approved 9-lifer
- 20/09/03
- Ruiselede / Gent
- 2,514
- 4 (100%)
- 0/12
ga et direct eens testen
(y)
18-09-2005, 18:28 #3Approved 9-lifer
- 09/08/04
- Genk
- 37,077
- 165 (100%)
- 5 Post(s)
- 263/1420
het ziet er best knap uit
mooi gedaan
18-09-2005, 18:35 #4Approved 9liver
- 21/08/02
- Roeselare
- 4,474
- 15 (100%)
- 2/35
idd, zeer verzorgd
spelconcept is simpel maar wel keer leukno votes
18-09-2005, 18:37 #5Approved 9-lifer
- 20/09/03
- Ruiselede / Gent
- 2,514
- 4 (100%)
- 0/12
tis echt wel leuk
alle twee de levels uitgespeeld
heb net ook ff een plannetje getekend van level 2
tzit echt wel goed in mekaar
Heb het voor de gemakkelijkheid ook op mijn webspace gezet als ge et nie wilt haal ek et wel weer weg
http://brecht.cheapass.be/escaper/Es...PSP2.00(1).rarLast edited by Bertold; 18-09-2005 at 18:44.
18-09-2005, 18:49 #6
uitgespeeld, en ik kan niet wachten tot de volgende game
mss kun je rpg elementen en gevechten in stoppen
dan zou het helemaal zot worden ^^no votes
18-09-2005, 19:00 #7
ik unrar Escapergame_PSP2.00 mapje in MP_ROOT folder, ga naar browers en typ file:escaper/start.html in de adresbalk maar ik krijg als foutmelding dat de inhoud niet kan weergegeven worden, hoe los ik dit op?
Heksarno votes
18-09-2005, 19:06 #8Crew Member
- 15/11/03
- Brugge
- 28,881
- 158 (100%)
- 9 Post(s)
- 1485/1564
18-09-2005, 19:08 #9Member
- 05/11/03
- Nazareth
- 1,908
ja, ook niet in de map "PSP" gewoon in 't eerste mapje dat dus van zijn eigen opent, ('k zat hier ook eff fout)
18-09-2005, 19:10 #10
wow zoveel positieve reacties!
Bedankt voor de download link bt belgium!
Het spelconcept is idd erg simpel en rpg elementen en gevechten zullen jammer genoeg onmogelijk zijn in html. Toch wil ik in de nieuwe levels wat meer met schakelaartjes werken, om het ietsje moeilijker te maken.
Ik werk momenteel aan de volledige versie van het spel en een 'Space background pack' voor PSP, maar ik heb ook wat leuke ideen voor nieuwe games en nieuwe technieken zodat ik meer mogelijkheden heb en niet gebonden zijn aan de beperkingen van html.
edit: in de volgende release zal ik in de readme wat duidelijker uitleggen hoe je hem op je PSP plaatst om problemen te voorkomen! Als je het spel van je PSP wilt doen delete je gewoon de escape map op je PSP. Pas wel op dat je geen andere maps en files delete.Co-Founder & Designer @ LuGus Studiosno votes
18-09-2005, 19:34 #11Approved 9-lifer
- 17/08/03
- Zele
- 4,855
- 8 (100%)
- 0/3
http://users.pandora.be/mistabeen/es...me_PSP2.00.rar voila
heb em op mijn pandora gesmete
[22:33] * @yenneman twiddles a bit with monkfish's asshole
18-09-2005, 19:37 #12no votes
18-09-2005, 19:40 #13Approved 9-lifer
- 20/09/03
- Ruiselede / Gent
- 2,514
- 4 (100%)
- 0/12
cheapass servers zijn (weer eens) down
18-09-2005, 19:49 #14
Ja er zijn heel wat mensen die downloaden van jullie server het kan daardoor zijn dat hij down is, gelukkig is er nu ook een extra download link van Mistabeen.
@Morf:
Plaats het mapje 'escaper' die je kan vinden in de rar in je eerste folder(mijn computer > verwisselbare schijf)Co-Founder & Designer @ LuGus Studiosno votes
18-09-2005, 20:03 #15
oké bedankt,
mooi gedaan BetelgeuzeHeksarno votes
