Thread: Probleem in 1.6
    Joepie's Avatar
    Waarschoot
    Probleem in 1.6
    IK heb het volgende systeem: 4200dual core, a8n sli deluxe, 7800gtx, 2gig ram, 160gig sata.
    Alle drivers zijn up to date.
    Alleen bij 1.6 zit ik dus met lag, ik hang om de min wel ne keer.
    .: Shaved Pussy's 0wn:.
    candycrash's Avatar
    St.-Niklaas
    hardware forum
    update bios en download amd drivers voor cpu handelingen
    AMD Athlon™ 64 X2 Dual Core Processor Driver for Windows XP and Windows Server 2003 Version (exe) 1.2.2.2 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64 X2 Dual Core processors on Windows XP SP2 and Windows 2003 SP1.
