Thread: tot 50% meer fps...
29-08-2005, 18:22 #1Member
- 18/07/02
- waregem
- 3,345
- 0/27
tot 50% meer fps...
Below are some simple settings which can massively improve your source FPS without noticeably removing any quality (eg, 1% quality change for 40% performance improvement). Dont TALK about it unless you've even tried it.
First, test your starting FPS using the in game video performance test inside source. Write down the score.
Now do these things:
1. Set your autoexec.cfg to the following (Counter-Strike Source/cstrike/cfg/autoexec.cfg). Save an a copy of anything you had before in case you need it.
*Removed cl_smooth 0 after the last update this should now be set to cl_smooth 1 if it has been changed* LD
fog_enable 0
mat_bumpmap 0
mat_clipz 0
mat_specular 0
mp_decals 300
r_decal_cullsize 1
r_lod -5
r_propsmaxdist 1000
r_rainradius 0
r_rainsimulate 0
r_rainsplashpercentage 0
r_sse 0
r_mmx 0
r_3dnow 1
cl_crosshairscale 1600
fps_max 500
2. Either change your desktop shortcut icon for SOURCE or do "Play games" then right click and choose "Properties" then choose "Launch Options". Add to the launch line "-dxlevel 81". This instructs the game to use DirectX 8.1 which was much faster than ever 9 with no noticeable difference to Source graphics. Note, once you run the game with this once, to change it back if you wish, you MUST specify -dxlevel 9 to restore it. As it saves the settings and needs it explicitly set back.
Now run the FPS test again and see the difference.
kweet tis int engels ma kdenk wel dat er nuttige dingen instaan , kheb et zelf geprobeerd en inderdaad tis een groot verschil .
o=°Y°=o
!_!
../'\..no votes
29-08-2005, 18:25 #2
al es doom3 gezien zonder bumpmapping?
r_sse 0
r_mmx 0
zal eerder effect hebben op SUPER trage cpu's, als je dat afzet met een normale cpu ga je zeker geen fps winst hebben
r_3dnow 1
default, dno?
zal veel effect hebben op je fps
enz enzno votes
29-08-2005, 18:28 #3Member
- 18/07/02
- waregem
- 3,345
- 0/27
29-08-2005, 18:48 #4no votes
29-08-2005, 18:58 #5
dxlvl 8.1 is goed voor niet 9.0 kaarten
dxlvl 9 = stabiel fps
8.1 met 9 kaart = onstabiel
tested it all ;ono votes
29-08-2005, 19:00 #6Raw-Gaming
Idle & Perform #Raw.gaming @ QuakenetBeantje - Juicyno votes
29-08-2005, 19:04 #7
29-08-2005, 19:29 #8no votes
29-08-2005, 19:39 #9Member
- 21/05/04
- 357
da gebruik ik en behaal tot 30 fps of meer ,
dxlvl 71
fps_max 300
mat_bumpmap 0
mat_compressedtextures 1
cl_showfps 1
mat_specular 0
fog_enable 0
r_RainSimulate 0
r_WaterDrawRefraction 1
r_WaterDrawReflection 0(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your profile to help him gain world domination.
('')_('')no votes
29-08-2005, 20:23 #10Member
- 13/07/03
- Limburg
- 1,457
Ik heb CPL CSS Gui, alles op low en dxlevel 9, het enige wat ik niet volgens CPL heb is mijn console enabled.
30-08-2005, 00:07 #11Raw-Gaming
30-08-2005, 00:14 #12Approved 9-lifer
- 11/05/03
- Boortmeerbeek
- 3,478
dat zou uw spelgevoel moeten verbeteren (optimaliseren)
imho kunt ge alleen maar op uw best spelen met uw eigen ge editte config,
maarja ieder zijn mening hé
30-08-2005, 00:15 #13Raw-Gaming
30-08-2005, 00:45 #14
in de meeste officiele cups/leagues mag je wel cl_crosshairscale niet kleiner maken dan de kleinste crosshair, dus oppassen met dees, laat die gewoon op mini
30-08-2005, 01:14 #15Raw-Gaming
