27-08-2005, 21:29 #1Member
- 12/06/05
- Dendermonde
- 1,344
- 41 (92%)
- 1/1
FS2004 Nick's Space Shuttle Landing Challenge FINAL RELEASE
Link :
http://library.avsim.net/download.php?DLID=72626
Daar de shuttle hier toch zo populair is.
Inhoud :
Featuring the Space Shuttle Discovery and celebrating NASA's return to space! This package contains the most up to date version of my Space Shuttle Landing Challenge (v1.2). I am providing it as a FINAL single installation package to eliminate the need for multiple update files. This package includes the Space Shuttle Discovery redesigned using actual NASA-Boeing mechanical/aeronautical engineering data, a panel, sounds and shuttle landing FX. The space shuttle in the sim (like the real shuttle) has the ability to water 'ditch' and belly land in an emergency or if improperly landed on the suspension system. You can select the sensitivity of the main landing gear struts (less crashes) for those who are novice to flying critical tolerances. This package includes a CHALLENGE FLIGHT ADVENTURE PACKAGE and features a reference list of the flights along with approach/landing procedure tips to the kneeboard (F-10) for you to refer to while in flight. The adventure pack will provide a set of 11 challenge flights spanning the globe for the space shuttle re-entry simulation. A Bonus PACK of CrashBar effects including smoke, fire, explosions and other nasty reminders of landing mistakes is included as an optional installation. The original .mdl file is by Matthew Moxon and a modified for FS9 panel byTom Kellner. Model repaint, flight dynamics, air file, sound.cfg, adventure flights and shuttle landing\crash FX by Nick Needham. Includes NASA's description of the entire landing process which you can now experience in Flight Simulator!no votes
27-08-2005, 21:55 #2Approved 9-lifer
- 28/08/02
- 3,966
- 26 (100%)
Amai dankuwel...
.no votes
27-08-2005, 22:59 #3Member
- 20/07/02
- Kinrooi
- 16,148
- 2/35
eens uittesten, want ik verveel me rot hier
"De wereld is soep en het denken meestal een vork: tot smakelijk eten leidt dat zelden."
Harry Mulisch.no votes
