18-08-2005, 00:46 #1Member
- 18/07/05
- 6
Punkbuster probleem in Enemy Territory!!!
yo,
Ik heb nl het volgende probleem:
Als ik Enemy Territory online speel, dan wordt ik na een bepaalde tijd gekickt voor 0 min.
De ene keer is het na 2 uur en de andere keer al na 30 min.
Als ik dan op reconnect duw dan wordt ik direct gekickt van zodra ik in het spel kom...
De foutmelding die ik krijg is :
Kicked (0 min)
Restriction: Blocked o/s Privileges: 507
wie kan er dit oplossen voor mij????
alvast bedankt aan de barmhartige samaritaan....no votes
18-08-2005, 04:58 #2
Eigenlijk wilde ik google Adviseren maargoed
ik zal je helpen
dit komt uit de FAQ van PB
Why does PunkBuster now require players to run the game as an administrator under WinXP/2K?
Because some cheats/hacks cannot be detected otherwise.
I keep getting kicked by PunkBuster for "Blocked O/S Privileges"?
Please temporarily disable other security type programs you have running such as anti-virus, process guard, SDProtector, etc. to find out which of them is blocking PB's access to resources on your computer. You either need to run PB without the blocking program(s) or play on non-PB servers. Also make sure you run the game under an Administrator or equivalent account under Windows. If you do have access an admin account, you can right click on the application you want to run and select "Run As". This will allow you to give admin access to that program and should allow you to play with a limited user.
I keep getting kicked by PunkBuster for "Insufficient O/S Privileges"?
Download and run this file from any location, it will check for adware that stops you from being able to play on PB servers. The VX2 adware edits your user rights when it infects your computer, and many programs do not repair this when they remove it.
http://www.greyknight17.com/spy/VX2Finder(126).exe
Click the "Find VX2.betterinternet info" button to make sure that you don't have this adware. If there are no files listed, go on to the last step. If you find the adware files, (it is usually 3 random named dll files) Select all the files found.
Press 'Delete These Files'. The program will delete all files but one that will be deleted on reboot. Allow program to reboot. Once Restarted:
Press 'Guardian.reg'.
Press 'User Agent'.
Press 'Restore Policy'.
Clicking on "find vx2.BetterInternet info" again should show all fields blank.
If you have no adware files, just click on the "Restore Policy" Button
Zo afgaande op et bovenste houd je Firewall/Virusscan of wat anders iets tegen waardoor je gekicked word
je hebt iets wat er voor zorgt dat PB je systeem nie scannen kan Bijvoorbeeld
ik zou zeggen doe bijde stappen en dan zou et probleem gefixed moeten zijn
Greetz RevengeLast edited by Revenge2004; 18-08-2005 at 05:02.
18-08-2005, 05:52 #3
Is niet echt een probleemoplosser, maar is wel handig. De Punkbuster Updater, als je dit opent, verschijnt een kadertje. Mijne is dus van America's Army. Weet niet zeker, maar denk dat het zich sowieso aanpast aan het spel. Zolang je maar de juiste doelmap ingeeft.
Als je dit opent en update voor je het spel opstart kun je PB-ingame-updates (die soms lange minuten duren) vermijden.
HIER moet je zijn om te downloaden.no votes
19-08-2005, 01:17 #4Member
- 18/07/05
- 6
Bedankt Revenge2004 maar helaas heeft dat nog niet geholpen.
Weet er nog iemand anders raad????
alvast bedanktno votes
19-08-2005, 03:05 #5
Nope want dat is de oorzaak
1 of andere proces van je Pc houdt PB tegen
je moet tog echt zoveel mogelijk uitschakelen en testenno votes
23-08-2005, 01:21 #6Member
- 18/07/05
- 6
voorlopig lukt nog niets
heeft nog iemand voorstellen?no votes
13-09-2005, 19:01 #7
gebruik je de patching tool van ET ?
Deze gaf bij mij dezelfde fout , ik heb gewoon is ne clean install gedana en officiele patches opgezet en het werkt terug zeer goed bij mij .no votes
