IK heb hier een oude kopie liggen van down patrol, de vereisten zijn:
555K Conventional Memory en 2,2 MB EMS Memory.
Ik krijg echter mijn geheugen maar op 538 K.
Ik gebruik DOS 6.22(Den originelen, geen emulatorke).
Heeft iemand soms nog dit probleem voorgehad met oude spelletjes?
Code:
Modules using memory below 1 MB:
Name Total = Conventional + Upper Memory
MSDOS 15.549 (15K) 15.549 (15K) 0 (0K)
HIMEM 1.120 (1K) 1.120 (1K) 0 (0K)
EMM386 4.144 (4K) 4.144 (4K) 0 (0K)
CD1 28.880 (28K) 28.880 (28K) 0 (0K)
COMMAND 2.928 (3K) 2.928 (3K) 0 (0K)
SMARTDRV 29.024 (28K) 29.024 (28K) 0 (0K)
KEYB 6.944 (7K) 6.944 (7K) 0 (0K)
MSCDEX 27.952 (27K) 27.952 (27K) 0 (0K)
SETVER 512 (1K) 0 (0K) 512 (1K)
DISPLAY 8.336 (8K) 0 (0K) 8.336 (8K)
Free 549.184 (536K) 538.752 (526K) 10.432 (10K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 655.360 116.608 538.752
Upper 19.280 8.848 10.432
Reserved 0 0 0
Extended (XMS)* 32.421.040 2.634.928 29.786.112
Total memory 33.095.680 2.760.384 30.335.296
Total under 1 MB 674.640 125.456 549.184
Total Expanded (EMS) 32.768.000 (32.000K
Free Expanded (EMS)* 30.031.872 (29.328K
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 538.656 (526K)
Largest free upper memory block 7.552 (7K)
MS-DOS is resident in the high memory area.
AUTOEXEC.BAT
Code:
C:\DOS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
MODE CON CODEPAGE PREPARE=((850) C:\DOS\EGA.CPI)
MODE CON CODEPAGE SELECT=850
KEYB BE,,C:\DOS\KEYBOARD.SYS
MSCDEX.EXE /D:ENETDRV /L:E
CONFIG.SYS
Code:
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=10,0
FILES=20
DOS=UMB
LASTDRIVE=Z
FCBS=4,0
DEVICEHIGH=C:\DOS\SETVER.EXE
DOS=HIGH
COUNTRY=032,,C:\DOS\COUNTRY.SYS
DEVICEHIGH /L:2,15792 =C:\DOS\DISPLAY.SYS CON=(EGA,,1)
DEVICEHIGH=cd1.SYS /D:ENETDRV
LASTDRIVE=Z
