    Chunk's Avatar
    Beerse
    Priest PVP/Solo build
    Heb het forum even doorzocht met search maar niet echt thread gevonden over wat ik wil vragen.
    Mijn huidige shadow build kan je vinden in mij sig maar nu op lvl 45 denk ik dat ik wat foutjes gemaakt heb daarmee mijn vraag of deze build beter is :
    Discipline Talents (5 points)
    # Unbreakable Will - 3/5 points
    Increases your chance to resist Stun, Fear, and Silence effects by 9%.
    # Silent Resolve - 2/5 points
    Reduces the threat generated by your damage spells by 8%.
    Holy Talents (0 points)
    # None
    Shadow Talents (31 points)
    # Blackout - 5/5 points
    Gives your Shadow damage spells a 10% chance to stun the target for 3 seconds.
    # Improved Shadow Word: Pain - 2/2 points
    Increases the duration of your Shadow Word: Pain spell by 6 seconds.
    # Shadow Focus - 5/5 points
    Reduces your target's chance to resist your Shadow spells by 10%.
    # Improved Mind Blast - 5/5 points
    Reduces the cooldown of your Mind Blast spell by 2.5 seconds.
    # Mind Flay - 1/1 point
    Assault the target's mind with Shadow energy, causing 75 damage over 3 seconds and slowing the target to 50% of their movement speed.
    Level 28: 126 damage over 3 seconds
    Level 36: 186 damage over 3 seconds
    Level 44: 261 damage over 3 seconds
    Level 52: 330 damage over 3 seconds
    Level 60: 426 damage over 3 seconds
    # Improved Psychic Scream - 2/2 points
    Reduces the cooldown of your Psychic Scream spell by 4 seconds.
    # Shadow Weaving - 5/5 points
    Your Shadow damage spells have a 100% chance to cause your target to be vulnerable to Shadow damage. This vulnerability increases the Shadow damage dealt to your target by 3% and lasts 15 seconds. Stacks up to 5 times.
    # Vampiric Embrace - 1/1 point
    Afflicts your target with Shadow energy that causes all party members to be healed for 20% of any Shadow damage you deal for 1 minute.
    # Silence - 1/1 point
    Silence the target, preventing them from casting spells for 5 seconds.
    # Darkness - 3/5 points
    Increases your Shadow spell damage by 6%.
    # Shadowform - 1/1 point
    Assume a Shadowform, increasing your Shadow damage by 15% and reducing Physical damage done to you by 15%. However, you may not cast Holy spells while in this form.
    Extra:
    - Ik heb speciaal "spirit tap" eruit gelaten omdat ik da vrij weinig zie opspringen, werkt niet in pvp en in parties hebben praktisch nooit de final blow
    - Ook "shadow reach" weggelaten omdat mobs zo snel bij mij zijn dat die 20% distance increase nie veel uitmaakt volgens mij
    - Heb op dit moment ook 1 point gewaste aan renew
    Graag wat reactie/hulp bij men pvp-solo build poging. En laat aub de commentaar van "weer een build thread" en van mensen die geen priest spelen achterwege aub.
    Thnx
    << Insert coin(s) >>
    Shelob's Avatar
    Kessel-Lo
    Waarom Silent resolve in PvP ? Zou da nie beter in unbreakable will of Darkness staan ?
    Chunk's Avatar
    Beerse
    Om het aggro krijgen als ik in party moest zitten toch iets te verminderen.
    Of geen goed idee ?
    Nookiedog's Avatar
    Herzele
    niet als ge bovenaan schrijft, pvp solo built
    aGeaL's Avatar
    Willebroek
    om geen nieuwe topic te starten, ben nu eind lvl 54 en straks dus 55 en ben van plan te respeccen naar holy voor high lvl instances, alleen geraak ik er maar niet aan uit welke talents ik bij holy moet pakken en welke niet echt nodig heb,
    psn: ageal
    Chunk's Avatar
    Beerse
    Quote Originally Posted by Nookiedog
    Ik wou zowiezo 5 points in discipline daarmee dat ik da zo gesplits heb maar kan evengoed 5 punten op unbr. will zetten das waar
    ?therapy?'s Avatar
    Rio De Janeiro
    allé jong :| spirit tap dat owned dus wel zwaar ze
    Shelob's Avatar
    Kessel-Lo
    Ja, Spirit Tap is zeer nodig als je solo gaat gaan. Blackout daartegenover vindt ik persoonlijk niet goed genoeg.
    Chunk's Avatar
    Beerse
    Quote Originally Posted by ?therapy?
    Is da nu ironisch bedoelt ? Da springt praktisch nooit aan, en met ne mana pool van rond de 4000 doet da bijzonder weinig als uw mana balkske leeg is. Beter rap wa moonberry juice of zo in men kas gieten.
    bloodoo's Avatar
    Laarne
    spirit tap mag je weglaten imo als je deftig gaat solo/grinden heb je toch water bij.
    en shadow reach en blackout zijn echt handig in pvp. 10% kans op 3sec blackout lijkt weinig maar komt opmerkelijk vaak voor
    en van een 30 yard spell een 35 maken is 5 punten waard
    Help a fellow person/rider, he needs our support http://www.stephenmurrayfamilyfund.com/
    Check ya girl's tits for my signature.we could make this world a greater place to live
    Shelob's Avatar
    Kessel-Lo
    Na lvl 55 zal ik die "Tap" ook wel wegdoen maar nu heb ik praktisch gene downtime bij het grinden en solo questen.
    Shadow reach kan een verschil maken, maar voor Blackout zal je me toch moeten overtuigen zenne. 3 sec is niet zoveel hé
    ?therapy?'s Avatar
    Rio De Janeiro
    Quote Originally Posted by Chunk
    Praktisch nooit? da staat ier op 100% na een kill zeer handig om meerdere kills tegelijk te killen hebde nen betere mana regen da is gewoon must bij grinden
    Chunk's Avatar
    Beerse
    Ik grind praktisch nooit, enkel voor quest alsek 10 dingen moet killen of zo voor de rest niks. En ik heb vooral gefocused op int + stam dus mijn spirit is nie zo hoog waardoor spirit tap nog nie echt veel effect heeft. Soit is persoonlijke mening, kzal er nog is over nadenken. En ik heb altijd massa's nectar, moonberry juice of water van mages bij.
    En die blackout komt idd vaker voor dan je zou denken, gisteren in BG praktisch elke keer op flag carrier alsem wegliep had ik hem 3 sec gestunned. Dikke 3/0 overwinning, 59 kills en geen enkele keer dood.
    @ Shelob : In BG is 3 sec stunned een wereld van verschil, tegen mobs maakt het idd nie zoveel maar als ge ne flag carrier kunt stunnen en dit het verschil maakt dat uw maten hem juist wel kunnen killen is zalig. Doe daarbij nog is mind flay en hij geeft de vlag uit miserie zo al terug af
    Shelob's Avatar
    Kessel-Lo
    Dan zal ik moeten respeccen als in aan BG's begin :-)
    didemo's Avatar
    Edegem
    Hoy,
    Na wat zoekwerk is dit de beste pvp shadowpriest build lvl 60 :
    Shadow 33 punten :
    ________________
    Blackout 5/5
    Improved Shadow Word: Pain 2/2
    Shadow Focus 3/5
    Improved Psychic Scream 2/2
    Improved Mind Blast 4/5
    Mind Flay 1/1
    Shadow Reach 3/3
    Silence 1/1
    Shadow Weaving 5/5
    Vampiric Embrace 1/1
    Darkness 5/5
    Shadowform 1/1
    Discipline 18 :
    __________
    Unbreakable Will 5/5
    Martyrdom 2/2
    Improved Power Word: Shield 3/3
    Improved Power Word: Fortitude 2/2
    Focused Casting 1/1
    Mental Agility 2/5
    Improved Inner Fire 3/3
    This build is based around being in Shadowform and being able to stay alive why putting out above average DPS. You can always jump out of Shadowform, but with this type of build you are fighting in Shadowform to gain the most benefit. You get the most out of the shadow tree, excluding Mindblast 5/5 and Shadow Focus 5/5. This is a very aggressive build with the intent to kill more than help team mates. Also one of the best shadow builds to survive and probably one of the best for 1v1 battles.
    bron: http://forums.worldofwarcraft.com/th...t&t=289247&p=1
