Thread: homebrew op 2.0
    chosen1's Avatar
    homebrew op 2.0
    voor de geïnteresseerden:
    7/28/05: Firmware 2.0 JavaScript Homebrew Portal
    Makarman has released an offline portal for firmware version 2.0 allowing one to play some simple JavaScript homebrew games and applications:
    Games:
    – p4wn chess game: Play the classic strategy game of chess against your PSP!
    – Blackjack: Play Blackjack, a well-known card game, right here on your PSP.
    – Tetris: Play classic Tetris anywhere from your PSP.
    – Battleship: Play Battleship against your PSP.
    – Minesweeper: Play the classic Windows game, Minesweeper, on your PSP.
    – Pong: Play the arcade game that started it all, Pong.
    IM & Email:
    – WebAIM - Chat with your buddies on AOL Instant Messenger!
    *Requires an Internet connection.
    **Optimized for better use on PSP.
    – MSN eMessenger - Communicate with friends, family, and colleagues on MSN Messenger!
    – Mail2Web - Check your email from your PSP!
    Applications
    – Calendar: Record all your important dates and take them with you on your PSP!
    – Memo Pad: Type and save notes and tasks on your PSP!
    – Address Book: Type your contacts and their information and save it onto your PSP.
    Update Feature - The portal can be updated to a new version without even having to connect the PSP to a PC.
    Installation
    Step 1. Extract the CONTENTS of the portal folder to the PSP's root directory.
    ( For example, while in USB mode, if your PSP appeared as the F: drive, the path of index.html path would look like this – F:/index.html )
    Step 2. Change your web browser's homepage to file:/index.html
    Step 3. Exit USB mode, and you're ready to start using simple homebrew on your 2.0 PSP!
    Remember, this portal is offline. It is downloaded to your PSP. In order to use it, the user simply must navigate the firmware 2.0 browser to file:/index.html
    You will only need to connect to a router if you want to use the applications that require Internet connections.
    Download it here
    chosen1's Avatar
    amai geen reactie hier op! das toch wel iets handig bij mijn weten!
    scorpion007's Avatar
    sinaai
    net getest , wel fijn , alleen heef het schaken verdomt veel vertraging en werkt de distance meter ofzo nie me mij
    Mistabeen's Avatar
    Zele
    Had het al gelezen op PSPupdates en vind het nu ook weer nie superieur ze
    tis gewoon een mottige portal da pijn doet aan de ogen
    ik maak wel zelf een eigen portal voor mezelf me javascripts op
    [22:33] * @yenneman twiddles a bit with monkfish's asshole
    nevaro's Avatar
    leuven
    werkt msn dan wel op je psp?
    sinaai
    ik kan nie inlogge me msn , zegt altij da men pass verkeerd is , terwijl het zeker jusit is offc
    nevaro's Avatar
    leuven
    kan iemnd me uitleggen hoe je het moet op je psp zetten?
    mij lukt het niet
    MrPhunKee's Avatar
    Tis maar een browserken.. Geen halve pc.. Msn gaat dus gewoon via emessenger. Niet via applicaties ofzo. Pas als r Linux op komt zal je Amsn er kunnen opzetten
    ...XboX Specialist....
    Teknohol1c's Avatar
    gentbrugge
    30 (100%)
    Quote Originally Posted by nevaro
    mij lukt het niet
    Same here....
    heb die zipfile dus unzipt in m'n psp en daar heb ik al vanalles geprobeert ma toch lukt het niet...
    Heb de folder "portal" al in de folder psp gezet, al in de folder PSP/SYSTEM, al in de folder PSP/SYSTEM/BROWSER en al in de folder MP-ROOT (dit zal 't zeker wel ni zijn denk ik)
    Heb dan ook geprobeert om enkel de inhoud van de folder PORTAL in alle boven vermelde folders es te zetten (dus zonder folder portal).
    Kga dan telkens naar de browser, ik typ dan bij adres: file:/index.html en iedere keer komt er op: "De inhoud kan niet worden weergegeven"
    't zal waarschijnlijk weer iets doms of simpels zijn, ma ik vind 't in ieder geval niet hoor...
    Critical killing is an art unto itself... And I am Rembrandt, sucker!
    PSN: teknohol1c
    Mistabeen's Avatar
    Zele
    ALS linux er ooit op komt
    Teknohol1c's Avatar
    gentbrugge
    30 (100%)
    Quote Originally Posted by stony_v
    Same here....
    Is er nou niemand die me kan helpen??
    PSN: teknohol1c
    Teknohol1c's Avatar
    gentbrugge
    30 (100%)
    jupla, ookal gevonden met beetje dank aan mistabeen, die me daarnet nog es heeft aangezet om nog es een poging te doen
    Ik had 't dus verkeerd begrepen en zat steeds met 't gedacht da ik al die dingen in m'n mapje PSP moest steken ma ni dus, alles moet gewoon op de MS gezet worden en nergens in een map...
    heb nog ni alles getest maar 't ziet er echt wel iet tofs uit, nu es naar ne maat en zien of 't lukt om mail te bekijken en die emessenger toestanden
    PSN: teknohol1c
    sirich's Avatar
    Eeklo
    Bij mij lukket nog steeds niet ... Extract via winamp al die files gwn naar mijn verwisselbare schijf in mijn geval G:/ en dan komt er daar die verschillende mapjes : PSP, MP ROOT en index.html normaal zit die homebrew toch goed ? Dus ik probeer homepage file:/index.html en komt op zoals bij stony eerst ''De inhoud kan niet worden weergegeven" pff ksnappet niet !! Uitleg gevraagd aub ?
    alvast bedankt
    cs:s 'er's Avatar
    kan je er ook een bijposten of je voor dit een vorige homebrew nodgi hebt + installatie begrijp ik niet echt...
    Teknohol1c's Avatar
    gentbrugge
    30 (100%)
    Quote Originally Posted by sirich
    alvast bedankt
    Kijk, 't is echt niet moeilijk hoor (eens je 't weet )
    Ja download da mapje van webportal. Da's dan 'n zipfile die je bvb op je bureaublad staan hebt. Dan doe je gewoon rechtermuisknop/alles uitpakken. Je pakt alles uit op je bureaublad en der komt een mapje PORTAL genoemd op je bureaublad. Vervolgens sluit je je psp aan op de pc en ga naar deze computer. Je ziet je verwisselbare (of hoe noemt 't ook weer) schijf staan. dan OPEN je 't mapje PORTAL en je sleept de INHOUD van dat mapje gewoon naar je verwisselbare schijf zodat die inhoud op je memorysick komt te staan BIJ/NAAST (niet erin!!!) DE 2 ANDERE MAPJES (PSP/MP-ROOT).
    Dan ga je naar je webbrowser en bij adres typ je: file:/index.html
    als het je nu niet lukt weet ik 't ook niet hoor...
    Je hebt toch de 2.0 hoop ik???
    PSN: teknohol1c
