    Question Serieuze hulp gevraagd
    ik denk dat het hier ergens staat maar ik vind het niet.
    ik heb ET gedownload en geinstalleerd maar als ik het opstart krijg ik het volgende
    ET 2.60 win-x86 Mar 10 2005
    ----- FS_Startup -----
    Current search path:
    C:\PROGRA~1\WOLFEN~1\etmain\pak2.pk3 (22 files)
    C:\PROGRA~1\WOLFEN~1\etmain\pak1.pk3 (10 files)
    C:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files)
    C:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (6 files)
    C:\PROGRA~1\WOLFEN~1/etmain
    3763 files in pk3 files
    execing default.cfg
    couldn't exec language.cfg
    couldn't exec autoexec.cfg
    Hunk_Clear: reset the hunk ok
    ...detecting CPU, found Intel Pentium III
    Bypassing CD checks
    ----- Client Initialization -----
    ----- Initializing Renderer ----
    ----- Client Initialization Complete -----
    ----- R_Init -----
    Initializing OpenGL subsystem
    ...initializing QGL
    ...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
    ...setting mode 4: 800 600 FS
    ...using desktop display depth of 32
    ...calling CDS: ok
    ...registered window class
    ...created window@0,0 (800x600)
    Initializing OpenGL driver
    ...getting DC: succeeded
    ...GLW_ChoosePFD( 32, 24, 0 )
    ...35 PFDs found
    ...GLW_ChoosePFD failed
    ...35 PFDs found
    ...failed to find an appropriate PIXELFORMAT
    ...restoring display settings
    ...WARNING: could not set the given mode (4)
    ...using colorsbits of 16
    ...calling CDS: ok
    ...GLW_ChoosePFD( 16, 16, 0 )
    ...35 PFDs found
    ...35 PFDs found
    ...WARNING: could not set the given mode (3)
    ...shutting down QGL
    ...unloading OpenGL DLL
    ...assuming '3dfxvgl' is a standalone driver
    ...initializing QGL
    ...WARNING: missing Glide installation, assuming no 3Dfx available
    ----- CL_Shutdown -----
    RE_Shutdown( 1 )
    GLW_StartOpenGL() - could not load OpenGL subsystem
    Wat moet ik doen om dit spel te doen draaien??
    nieuwste video kaart drivers en patch geinstalleerd
    Dvas'Shifty's Avatar
    Dilsen-Stokkem
    hmz geen idee
    SHFTdkTrp : ]
    <3 Caps, Bana,Urki, Trutje, Fubro en Exorikos!
    ersg
    hebt get geïnstalleert zoals dat in de Sticky staat? anders weet ik het ook niet."assuming no 3Dfx available" is het dat niet
    bartichello's Avatar
    uw vid card drivers updaten als ge al een goed genoege vidcard hebt...
    sharkie's Avatar
    Waregem
    Quote Originally Posted by den_jeffe
    kweet er nie veel van, maar zou het aan dat kunnen liggen?
    maak een autoexec
    cless :<
    Geluwe
    Aha gevonden. De resolutie of je colourdepth die je hebt ingesteld is te hoog voor uw monitor/videokaart => je moet je config.cfg aanpassen en die values wat verlagen.
    ReMinDer_of_Me's Avatar
    Boskoop
    Nee hij moet zijn videokaart drivers updaten...
    lezen is moeilijk:
    bartichello ownt!
    P-M 730 @ 2.674 | 2*512 Mb PC3200 Dual channel| Asus P4C800E-Deluxe| Point of view 6800GT@ultra 256Mb watercooled | Mijn systeem
    DeepKick's Avatar
    Quote Originally Posted by ReMinDer_of_Me
    lezen is moeilijk:
    bartichello ownt!
    hij zegt dat hij het al gedaan heeft
    Messi no es nada sin Xavi e Iniesta?
    Nada más le hizo goles por lote al Mallorca y al Viktoria y solito se fabricó un golazo contra el Madrid en Champions. Es el mejor y punto.
    Geluwe
    Nope, dat is de globale error, wordt gegeven wanneer er ook maar iets fout gaat. Als je dan echt wil weten wat er nu fout gegaan is moet je kijken naar de logs van tijdens het proces zelf.
    zaj's Avatar
    Oosterzele
    zo te zien niet een al te straf systeem... zeg uw video kaart is miss support ze geen open gl
    kristofisback's Avatar
    roeselare
    van mij zegt die da ook wel ik heb ne p4
    ElemenTiM's Avatar
    Herentals
    idd, hier ook.
    Installeer uw oude drivers eens!
    2*Technics SL1200, SynQ SMX-1, Denon S-1000, Serato Scratch Live, S-Logic HFI500 Headphone
    Slaxz's Avatar
    Deerlijk
    Quote Originally Posted by shadow77566
    hij zegt da altijd ook al hebt ge ne P4.
    dat heeft hier al es gestaan en als ik me goed herrinner was dat omdat de P4 nog maar net uit was en er nog geen volledige P4 support ingebouwd was.
    maw daar moet je niet naar kijken
    "Computer games don't affect kids, I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
