Thread: Custom Backgrounds
20-06-2005, 16:53 #1
Custom Backgrounds
PSPersonalize is a PSP program that lets you replace the background images in your PSP menu. On the PSP, there are 12 backgrounds, one for every month. This program lets you replace any image you want with your own custom made images.
Read everything before taking any steps. We are not responsible for any damages in result of this application. Use at your own risk.
Here’s how it works:
There are 12 images in your PSP:
01.BMP - January
02.BMP - February
03.BMP - March
04.BMP - April
05.BMP - May
06.BMP - June
07.BMP - July
08.BMP - August
09.BMP - September
10.BMP - October
11.BMP - November
12.BMP – December
To insert your own images, simply put your own 24-bit BMP file in the root directory of your second memory stick. The filename should match the number of the month you want to replace. (Ex: I want to replace November so I would create a .BMP called 11.BMP and place it in my 2nd memory stick)
Do NOT put these images in any of the directories in your memory stick, the software won’t find them in this case.
Ok, now that we know how to replace the images, we have to know the rules. First, images can’t be any larger than 150k. That’s a resolution of about 300x170. The reason for this is that anything larger causes your PSP to not load icons properly. Second rule, these images must be 24bit. Do NOT use images that are 16bit or 8bit color.
Download hier:
http://files.psphacker.com/cgi-bin/c...0,0,0,0,38,433
Finally, van dat pink vanaf enzo...XboX Specialist....no votes
20-06-2005, 16:57 #2Approved 9liver
- 11/11/03
- Oudenaarde
- 7,085
- 37 (100%)
- 3/36
PSN: tgc_9012no votes
20-06-2005, 17:14 #3
Ze blijven er wel permanent opstaan he! Word via de flash geschreven. Voorzichtig zijn dus als ge t gebruikt.
20-06-2005, 19:05 #4Approved 9liver
- 11/11/03
- Oudenaarde
- 7,085
- 37 (100%)
- 3/36
Ah, toch handig
Er is ook een .zip file met alle originele backgrounds beschikbaar op www.psphacker.comPSN: tgc_9012no votes
20-06-2005, 19:25 #5
Dit is bvb februari bij mij
http://img.photobucket.com/albums/v235/mrphunkee/02.bmp...XboX Specialist....no votes
20-06-2005, 19:44 #6Approved 9liver
- 11/11/03
- Oudenaarde
- 7,085
- 37 (100%)
- 3/36
Kheb nu een stoere Kenshin background
21-06-2005, 04:26 #7
Men tatoo met naam en menu afwerking..
http://img.photobucket.com/albums/v2...nkee/marl2.bmp
http://img.photobucket.com/albums/v235/mrphunkee/03.bmp...XboX Specialist....no votes
