Thread: hunter build
    Herr_Kaiser's Avatar
    Jabbeke
    hunter build
    kzag hier iets verder een rogue build, dacht bij mezelf kzal mijn hunter build ook eens posten misschien dat er iemand er goeie commentaar kan op geven
    hier is het :
    Beast Mastery Talents (0 points)
    None
    Marksmanship Talents (30 points)
    Improved Concussive Shot - 5/5 points
    Gives your Concussive Shot a 20% chance to stun the target for 3 seconds.
    Improved Hunter's Mark - 5/5 points
    Increases the Ranged Attack Power bonus of your Hunter's Mark spell by 15%.
    Lethal Shots - 5/5 points
    Increases your critical strike chance with ranged weapons by 5%.
    Aimed Shot - 1/1 point
    An aimed shot that increases ranged damage by 70.
    Mortal Shots - 5/5 points
    Increases your ranged weapon critical strike damage bonus by 50%.
    Scatter Shot - 1/1 point
    A short-range shot that deals 50% weapon damage and confuses the target for 4 seconds. Any damage caused will remove the effect.
    Hawk Eye - 3/3 points
    Increases the range of your ranged weapons by 6 yards.
    Ranged Weapon Specialization - 5/5 points
    Increases the damage you deal with ranged weapons by 5%.
    Survival Talents (21 points)
    Precision - 5/5 points
    Increases your chance to hit with melee weapons by 5%.
    Lightning Reflexes - 3/3 points
    Increases your Dodge chance by 3%.
    Improved Wing Clip - 5/5 points
    Gives your Wing Clip ability a 20% chance to immobilize the target for 5 seconds.
    Deterrence - 1/1 point
    When activated, increases your Dodge and Parry chance by 25% for 10 seconds.
    Improved Mongoose Bite - 1/5 point
    Increases the damage done by your Mongoose Bite ability by 4%.
    Deflection - 5/5 points
    Increases your Parry chance by 5%.
    Counterattack - 1/1 point
    A strike that becomes active after parrying an opponent's attack. This attack deals 40 damage and immobilizes the target for 5 seconds. Counterattack cannot be blocked, dodged, or parried.
    kwil eigenlijk best mogelijke pvp build
    kweet eigenlijk niet goed of dit vesstandig is om 0 punten in beast mastery te steken
    we live in a world of nerds ! ! !
    2-Gman's Avatar
    Dendermode
    None
    Waarom none? je pet is belangrijk OOK in pvp... ze worden meestal genegeert maar in de BG zijn ze zeer handig als je alli bent omdat ze totem killers zijn + ze doen dmg waar de meeste mensen toch niet op letten. Dus ik zou dit zeker niet helemaal links laten liggen zoals je nu wel doet?
    + je aspects worden hier ook beter uit... aspect of the hawk etc...
    True shot aura?...
    Nja paar punten zijn wel ok!
    maar we zijn nog altijd range class dus waarom zou je zoveel punten in melee steken? ik geeftoe de beste hunters zijn die die geen schrik hebben om in melee iemand een raptor strike op z'n oog te geven maar toch dit is over dreven naar mijn mening!
    but who am I nway
    ([19:34:31]) <ZeRoX|ION> ik wer hie bekan zwanger wete
    ([18:06:43]) <[1up\Physixius]> die balle van de napoleon zijn toch lekker ze kerel
    www.TeK-9.net
    Catscratch's Avatar
    Gavere
    De beste PVP build alleszins .... in combinatie met deterrence snarede direct uwen tegenstander (ipv 500x te wingclippen). Nadeel is wel dat ge aanzienlijk in DPS verliest daar ge wapen spec, spec AoTH & trueshot mist.
    Btw gisteren Bloodseeker gekozen als BG-reward .... in de handen van de ork is da precies nen uitgebouwde tandenstoker, en de animatie gaat al helemaal de mist in. Toch even het vermelden waard
    Frank
    Bolteh's Avatar
    Kluizen
    kheb klak dezelfde build als u kaiser, en ik kan effectief mijn mannetje staan in pvp
    ben trouwens blij dat je je niet hebt later verleiden door het endtalent van marksmanship.. trueshot is echt een nutteloos talent die maar een luttele 2dps meer geeft op ranged en zo'n 3-4 op melee.. uw keuze daar om counterattack te nemen ipv trueshot kan ik enkel maar toejuichen.. is een extra mogelijkheid om de vijand op afstand te houden (deterrance en counterattack = ranged madness)
    HATE}_____contemno
    [DIGITAL] playground___
    Jabbeke
    trueshot auro is toch wel compleet nutteloos niet ?
    en aspect of the hawk speccen lijkt me ook zinloos ?
    btw survival heb ik niet zo zeer gespecced om goed te zijn in melee want hunters zijn slecht in melee
    eerder om zo weinig moelijk damage te krijgen en de mogelijkheid om weer weg te geraken (weer op afstand te geraken van tegenstander)
    ===> Improved Wing Clip - 5/5 points
    ===> Deterrence - 1/1 point
    ===> Lightning Reflexes - 3/3 points
    ===> Deflection - 5/5 point
    ===> Counterattack - 1/1 point
    ben van mening net zoals Bolteh dat dit vrij goeie build is voor pvp
    alleen twijfel ik nu of beast mastery de moeite is om te speccen ik ben van mening van niet
    lone.wolf's Avatar
    hoog en droog
    in 1v1 pvp is spiritbond en beastmaster talents nog niet zo slecht, maar in mass/zerg pvp vergete beast master best maar aangezien ou pet in no time dood is.
    must have voor pvp
    not worth it (tenzij voor pve build waar je je ranged damage wilt maximalizeren , maar dan ga je ook in beastmaster in aspect of the hawk tp steken)
    geen discussie over . aimed is perfect opener. 50% meer damage op crit is sweet, en wie wil er niet meer crit chance. scatter is je enige 100% guaranteed skill om de controle over gevecht terug in handen te krijgen. hawk eye is must have voor mass pvp.
    geen 5 points waard, drop it. steek dan liever 5 points in het verminderen van je arcane shot cooldown (dat dankzij laatste patch eindelijk werkt \o/)
    goed, niks is pijnlijker dan je wing clip te missen.
    aangezien je je naar counterattack aan het toewerken bent, mooi talent.
    so sweet if it procs.
    deterrence+ monkey owns rogues
    drop it . goose bite is ridicuul. waar dan wel in? mja, entrapment i guess :/
    nodig voor counterattack.
    lifesaver
    de 5 punten die je in improved hunters mark gestoken hebt zou ik in barage en in improved freezing trap steken. 21 sec freezed is heeel lang.
    dit is de mijne (nee niet de beste, gewoon de beste voor mijn speelstijl)
    # None
    Marksmanship Talents (27 points)
    # Improved Concussive Shot - 5/5 points
    # Lethal Shots - 5/5 points
    # Aimed Shot - 1/1 point
    # Improved Arcane Shot - 5/5 points
    Reduces the cooldown of your Arcane Shot by 1 second.
    # Barrage - 2/2 points
    Increases the damage done by your Multi-Shot and Volley spells by 10%.
    # Mortal Shots - 5/5 points
    # Hawk Eye - 3/3 points
    # Scatter Shot - 1/1 point
    Survival Talents (24 points)
    # Precision - 5/5 points
    # Lightning Reflexes - 3/3 points
    # Entrapment - 1/5 point
    Gives your Immolation Trap, Frost Trap, and Explosive Trap a 5% chance to entrap the target, preventing them from moving for 5 seconds.
    # Improved Wing Clip - 5/5 points
    # Deterrence - 1/1 point
    # Improved Freezing Trap - 3/3 points
    Increases the duration of your Freezing Trap by 6 seconds.
    # Deflection - 5/5 points
    # Counterattack - 1/1 point
    -=[MgC]=- a Be/Nl CSS/MoH:AA clan || #mgc @ quakenet
    [Grim Batol (BB Mk2) 60 dorf Hunter || 58 gnome Rogue || 36 dorf Priest || 43 nelf Druid ]
    [Defias Brotherhood 60 undead Priest || 60 troll Shaman || 49 undead Mage || 35 undead Rogue ]
    snoob's Avatar
    Deinze
    Quote Originally Posted by Herr_Kaiser
    dom?
    Being strongest pound-for-pound just means you can kick ass in kindergarten.
    Squat: 240kg // Bench: 155kg // Deadlift: 300kg // Totaal: 695kg RAW
    Snoob: seizoen 2009 log // National Strongman Belgium
    lone.wolf's Avatar
    hoog en droog
    Quote Originally Posted by 2-Gman
    but who am I nway
    u bent iemand die weinig pvp'ed als u denkt dat u veel ranged zult vechten in pvp. ik ben al blij als ik voor 70% van de tijd uit melee kan blijven. bovendien maakt u de fout om survival gelijk te stellen aan melee. survival is wat het zegt te zijn, overleven ..
    lone.wolf's Avatar
    hoog en droog
    Quote Originally Posted by snoob
    dom?
    nope, hij heeft gelijk. trueshot + hawk verbeteren is enkel goed in pve omgeving.
    snoob's Avatar
    Deinze
    nja kzit dan ook in pve guild
    op pvp server
    Rage's Avatar
    Gemeente
    vraagje, ik heb zelf ook hunter, (nog vrij "laag" lvl)
    Als ik het goed begrijp, wordt die skill beschikbaar na een parry, maar gebeurt dit automatisch of moet ik daarvoor op de skill klikken? heb ik daar dan wel genoeg tijd voor?
    Sprits's Avatar
    Reet
    81 (100%)
    Ik vind dees ne goeien Build
    Beast Mastery Talents (8 points)
    Improved Aspect of the Hawk - 5/5 points
    Increases the Ranged Attack Power bonus of your Aspect of the Hawk by 20%.
    Improved Aspect of the Monkey - 3/3 points
    Increases the Dodge bonus of your Aspect of the Monkey by 3%.
    Marksmanship Talents (33 points)
    Efficiency - 5/5 points
    Reduces the Mana cost of your Shots and Stings by 10%.
    Trueshot Aura - 1/1 point
    Increases the Ranged and Melee Attack Power of party members within 30 yards by 30.
    Survival Talents (10 points)
    Improved Raptor Strike - 5/5 points
    Reduces the cooldown of your Raptor Strike by 1 second.
    Rumil^'s Avatar
    Wel, hier wil ik ook wel eens mijn talent build posten;
    Marksmanship Talents (22 points)
    Improved Hunter's Mark - 2/5 points
    Increases the Ranged Attack Power bonus of your Hunter's Mark spell by 6%.
    Hawk Eye - 1/3 point
    Increases the range of your ranged weapons by 2 yards.
    seconds.
    Catscratch's Avatar
    Gavere
    Heb voor de leut eens gerespecced naar nen build waar ik ranged spec, trueshot & improved aoth heb ... van 136 dps naar 147 gegaan ... toch nie slecht eerlijk gezegd.
    Enigste wat ik doe PVP gewijs is BG .... mass PVP dus waar ge als hunter bijna nooit melee tegenkomt. Ik crit nu al met aimed rond de 2800 - 2900 op clothusers ... ben eens benieuwd wat het nu gaat zijn
    Ff testen of ik mijnen counterattack niet te hard mis
    Frank
    lone.wolf's Avatar
    hoog en droog
    Quote Originally Posted by Minimum Rage
    zelf klikken, ge hebt wel paar sec tijd
