Page 1 of 3 123 Last
Thread: Rogue Build
    phxclan's Avatar
    Rogue Build
    Ik was juist wat aan het talentcalculaten en kwam ineens op de volgende build:
    21/17/13
    Laat de comments vliegen en zijn er mensen met + - dezelfde build?
    Assassination Talents (21 points)
    Improved Eviscerate - 3/3 points
    Increases the damage done by your Eviscerate ability by 15%.
    Malice - 5/5 points
    Increases your critical strike chance by 5%.
    Ruthlessness - 3/3 points
    Gives your finishing moves a 60% chance to add a combo point to your target.
    Murder - 1/2 point
    Increases your chance to hit while using your Sap, Ambush, Garrote, or Cheap Shot abilities by 3%.
    Relentless Strikes - 1/1 point
    Your finishing moves have a 20% chance per combo point to restore 25 energy.
    Improved Expose Armor - 2/3 points
    Increases the armor reduced by your Expose Armor ability by 30%.
    Lethality - 5/5 points
    Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ghostly Strike, or Hemorrhage abilities by 30%.
    Cold Blood - 1/1 point
    When activated, increases the critical strike chance of your next Sinister Strike, Backstab, Ambush, or Eviscerate by 100%.
    Combat Talents (17 points)
    Improved Gouge - 3/3 points
    Increases the effect duration of your Gouge ability by 1.5 seconds.
    Improved Sinister Strike - 2/2 points
    Reduces the Energy cost of your Sinister Strike ability by 5 Energy.
    Improved Backstab - 3/3 points
    Increases the critical strike chance of your Backstab ability by 30%.
    Deflection - 5/5 points
    Increases your Parry chance by 5%.
    Precision - 1/5 point
    Increases your chance to hit with melee weapons by 1%.
    Riposte - 1/1 point
    A strike that becomes active after parrying an opponent's attack. This attack deals 150% weapon damage and disarms the target for 6 seconds.
    Dagger Specialization - 2/5 points
    Increases your chance to get a critical strike with Daggers by 2%.
    Subtlety Talents (13 points)
    Master of Deception - 5/5 points
    Reduces the chance enemies have to detect you while in Stealth mode. More effective than Master of Deception (Rank 4)
    Opportunity - 5/5 points
    Increases the damage dealt when striking from behind with your Backstab, Garrote, or Ambush abilities by 20%.
    Improved Ambush - 3/3 points
    Increases the critical strike chance of your Ambush ability by 40%.
    ^^pathfinder^^'s Avatar
    Zonhoven
    kben nog nie volledig uit mn build, kben nog maar lvl 33, maar ik ga veel punten steken in assasination en subtlety.
    Nookiedog's Avatar
    Herzele
    21 vo colb blood is goe ma wa ge dan doet verstaak nie goe... 17 punten in combat voor riposte? totaal nie waar ik zou daar zoals ik doe 8ptn insteken dan imp gouge/ss/bs
    en de rest in uw sub voor preperation. als ge dan toch nen dagger amb/bs built wilt
    TheEvilTomato's Avatar
    Nijlen
    wel op het eerste gezicht niet slecht maar murder en improved expose armor kun je best in betere posions ofzo steken.
    Murder is imo niet zo nuttig en expose armor word bijna nooit gebruikt.
    Expose armor is imo ook nutteloze skill.
    Als ge voor CB gaat dan kunde beter ook in een keer voor Seal fate (5) gaan. als ge crit 2cp in plaats van 1 is nice in pvp. Heb zelf een 30/8/13. Denk dak zowa alles al heb gehad. De meeste weirde combo's... mijn respec kost tegenwoordig al 40gold
    SLX's Avatar
    destelbergen
    is die talent om sneller te lopen in stealth niet handiger dan master of deception?
    kdacht dat es gehoord te hebben
    [edit] typo
    oya's Avatar
    San Andreas
    neen
    stealth zijde zowieso te traag als ge achter iemand aan loopt
    MOD is gewoon must have
    phxclan's Avatar
    Quote Originally Posted by Nookiedog
    Elk talent dat ik in Combat heb gestoken heeft zijn nut ! Riposte betekent dat elke slag naar je rogue 10% kans heeft om een vijand 6 seconden te ontwapenen... dit betekent dat je een vijand 6 seconden kan stunnen +- elk gevecht dat je tegenkomt. 2% in dagger spec = ...dat weet je wel...
    Laat ons eerst even terugblikken op mijn vorige build:
    Assassination Talents (30 points)
    Malice - 5/5 points
    Murder - 1/2 point
    Improved Expose Armor - 3/3 points
    Increases the armor reduced by your Expose Armor ability by 45%.
    Improved Kidney Shot - 3/3 points
    Reduces the cooldown of your Kidney Shot ability by 5 seconds.
    Seal Fate - 5/5 points
    Your critical strikes from abilities that add combo points have a 100% chance to add an additional combo point.
    Combat Talents (21 points)
    Lightning Reflexes - 2/5 points
    Increases your Dodge chance by 2%.
    Precision - 2/5 points
    Increases your chance to hit with melee weapons by 2%.
    Riposte - 1/1 point
    Dagger Specialization - 5/5 points
    Increases your chance to get a critical strike with Daggers by 5%.
    Subtlety Talents (0 points)
    None
    Wat ik nu dus eigenlijk doe is mijn Backstab, Ambush, etc verstevingen en 40% crit erbij voor ambush in ruil voor 3% Critical met daggers (wat dus elke treffer betekent)
    Ook geef ik 1 belangrijk punt weg: Improved expose armor...wat ons op de volgende post brengt:
    Quote Originally Posted by TheEvilTomato
    In de build zoals hierboven betekent betekent Improved Expose Armor eigenlijk:
    - Met 3/3 IEA zal elke keer dat je aanvalt, voor de volgende 30seconden, 25% meer schade doen, wat echt wel Uber is tegen een goede warrior, priest, pally
    - Combineer dit nu met een CB Eviscrate, en de totale toegevoegde damage is véél hoger dan eender welke zet die je maakt
    - Met 2/3 wordt er minder armor geexposed, maar ik heb wel 20% dmg meer op mijn backstabs, dus verstevig ik mijn backstabs ten koste van een beetje minder dmg bij eviscrate
    Ik ben daarom ook zeker aan het twijfelen over die Murder/IEA zaak, maar ik denk als ik deze zou nemen, dat ik het da toch in IEA zou steken
    Ik hoop enkele degelijke reacties te horen waarom ik dan voor een diepe Assassination/Subtlety zou gaan?
    Zou de Seal Fate de improved Ambush, MoD (andere rogues, met MoD, openen niet meer eerst) en Oppertunity waard zijn? Dat vraag ik me af...
    Dank bij voorbaat voor deze post te lezen hij kan een beetje afschrikken
    EDIT: afkortingen:
    IEA: Improved Expose Armor
    Crit: Critical
    MoD: Master of Deception
    dmg: damage
    Kiddy's Avatar
    Ik vind het zeker een build de moeite waard om uit te proberen. Met deze build heb je alles wat je nodig hebt om veel damage te doen met ambush/backstab, maar heb je toch nog de voordelen van de combat tree. En met een 21/8/22 build die ik momenteel bezit mis is soms wel die combat tree.
    Preperation opgeven is niet zo erg, ik ben geen voorstander van skills die je maar eens om de 10 min kan gebruiken. Natuurlijk is preperation handig, maar door de 10 min cooldown ga je het meestal enkel gebruiken in noodgevallen.
    Het enige echt nadeel dat ik zie is geen impr sap. Alhoewel impr sap geen must is stelling vele dat wel op prijs in high lvl instances. Maar zonder gaat ook met een goede groep
    I'm on a whisky diet. I've lost three days already!
    ?therapy?'s Avatar
    Rio De Janeiro
    Malice - 5/5 points
    Remorseless Attacks - 1/5 point
    Murder - 2/2 points
    Combat Talents (5 points)
    Subtlety Talents (25 points)
    Camouflage - 5/5 points
    Elusiveness - 1/5 point
    Initiative - 5/5 points
    Improved Sap - 3/3 points
    Improved Rupture - 3/3 points
    Preparation - 1/1 point
    Improved Cheap Shot - 2/2 points
    Improved sap is belangrijk. 2 vijanden zijn der. ge sapped ene en dan begint ge met een cheap shot om te beginnen enzo veel handiger :P
    Judasspriest's Avatar
    Quote Originally Posted by ?therapy?
    Malice - 5/5 points
    Murder - 2/2 points
    Das zon beetje de standaard rogue build en de beste imo
    gebruik ik ook
    Nookiedog's Avatar
    Herzele
    mja ik ong, +3 points vo imp bs en 3 minder in subt.
    en als gij uw talents uw talents toch ana dieje useless riposte wilt geve doe ma... kheb liever iets nuttigs
    Zonhoven
    Quote Originally Posted by Lunitun
    naar deze build ga ik ook werken denkik.
    maar wel beetje meer in subtlety steken
    Nijlen
    @phxclan: imo is da nutteloos omdat ge veel beter uw cp beter kunnen gebruiken voor evi, rupture of KS. Want als ge EA erin begin gaat smijten gaat ge ofwel ni genoeg damage doen of ni genoeg stunnen.
    Maar bij nader inzien kan zoiets wel lukken tegen warriors of andere high armor-mannekes.
    Maar onderschat sub zeker niet, das zeer goed in PvP en dingen zoals MoD en Cam voor betere stealth. Impv ambush is excellent om cloths en andere low HP-mannekes.
    Dees is mijn build, een normale pvp-build
    Malice - 5/5 points
    Improved Instant Poison - 3/5 points
    Increases the chance to apply Instant Poison to your target by 6%.
    Combat Talents (8 points)
    Subtlety Talents (22 points)
    Increases your speed while stealthed by 15%.
    Gives you a 75% chance to add an additional combo point to your target when using your Ambush, Garrote, or Cheap Shot ability.
    Adds a 90% chance to return to stealth mode after using your Sap ability.
    When activated, this ability immediately finishes the cooldown on your other Rogue abilities.
    Kwou eerst voor premed gaan maar kvon dak teveel moest opgeven om het te hebben.
    Kga wss later mezelf respeccen naar wat anders, zodak weet welke build dak exact wil, voor nu deze.
    phxclan's Avatar
    Hier wil ik niet erg op in gaan, want ik denk dat jij het effect van Riposte niet kent...
    Als je het dan toch wil leren kennen, kijk dan eens bovenaan de post. Ben je daar te lui voor, dan even in het kort:
    - ongeveer elk gevecht heb je een kans om een vijand 6 seconden te 'stunnen', wat voor mij genoeg is om iemand serieus te verminken.
    Ik heb hierboven al gepost over IEA. Iedereen die denkt dat IEA nutteloos is, is fout. IEA is echt imo dé beste finishing move tegen defense warriors, priests en pallys. De gegevens heb ik boven in de post gestuurd...
    Ik onderschat Sub zeker niet, maar is het het waard om daarvoor Sealfate, Improved KS en 3% crit met daggers op te geven?
    Bedankt voor de vlugge reacties...
