- Connection to ubi.com through HTTP proxy is now properly supported. If you are using an HTTP proxy, you must edit the
SplinterCell3.ini file usually located (depending on your system) in:
C:\Documents and Settings\All Users\Application Data\Ubisoft\Tom Clancy's Splinter Cell Chaos Theory\SplinterCell3.ini
Then, add the following lines in your splintercell3.ini under the [UBI.COM] section with your web proxy settings:
[UBI.COM]
ProxyAddress=
ProxyPort=
Note: By default, this folder is hidden by Windows. To browse it, you must do the following in Explorer:
Select Tools->Folder options->View and check the "Show hidden files and folders" radio button.
