Thread: prob met pb
22-05-2005, 15:10 #1
prob met pb
probleem met pb
als ik (sommige, niet allemaal) server wil joinen, laadt hij de map, en dan komt er een error : PB GUID AUTH:UNKW of zo iets,
das nogal ambetant als ge da op een war-server voor hebt...Last edited by H00der; 22-05-2005 at 15:14.
Gifted Unlimited Rhimes Universal...
Y'All Cats Know I Always Play To Win...no votes
22-05-2005, 17:20 #2Member
- 20/12/03
- Kuurne City
- 3,330
cd-key es opnieuw invoeren.
Simulation Racing: GTR²/Evo - nK-Pro - Ferrari Virtual Academy - iRacing
iRacing footage: Untitled Movie - GT2 Race Battle - Defending the Lead on the Last Lap
iPhone 4S/iPad 1&2/iPod Touch 4thG: The Simpsons Tapped Out - (add me: iJkW)
F1 Driver: Robert Kubica - Renaultno votes
28-05-2005, 13:01 #3
Why am I getting kicked for PB Guid Auth: UNKN?
The "PB GUID AUTH: UNKN" kicking means that your Game client is not sending a valid cdkey to id's cdkey auth server. Usually this is due to a problem with your cdkey entry. Exit Quake3 and then use your Windows explorer program to find the baseq3 folder where Quake3 is installed on your system and delete the file called q3key. Launch Quake3 directly and before you get to the game's main menu, it should ask you to enter your cdkey. Be sure to enter the 16 character cdkey from your Quake3 cd-case in all lower case letters. NOTE: If your cdkey has 18 characters, then you are not finding the right key. Team Arena keys have 18 characters, Quake3 keys have 16. If this does not fix the problem, then perhaps there is some type of firewall or security software blocking your game's communication to id's cdkey auth server. Be sure that UDP port 27952 is open for clear communication if you have a firewall or some type of security software.
Note: A cdkey is only valid if you bought the game and have a cdkey on your cd-case! Using a cdkey generator will allow you to overcome the checksum check within Quake3, stating that your cdkey is valid - it is only valid for single player though and will not allow you to play on the internet.no votes
