Thread: fout bij CoD
    Cuth's Avatar
    bleirgh
    fout bij CoD
    hmmm ik wou daarjuist cod spele en opeens krijg ik een foutmelding(aangezien ik geen webspace ofzo heb copy+paste ik het maar) de foutmelding is de volgende:COD MP 1.5 build win-x86 Nov 10 2004
    ----- FS_Startup -----
    Current language: english
    Current search path:
    C:\PROGRA~1\CALLOF~2\main\Z_Nuenen.pk3 (9 files)
    C:\PROGRA~1\CALLOF~2\main\vikings_omaha_1.pk3 (24 files)
    C:\PROGRA~1\CALLOF~2\main\pakb.pk3 (60 files)
    C:\PROGRA~1\CALLOF~2\main\paka.pk3 (41 files)
    C:\PROGRA~1\CALLOF~2\main\pak9.pk3 (149 files)
    C:\PROGRA~1\CALLOF~2\main\pak8.pk3 (235 files)
    C:\PROGRA~1\CALLOF~2\main\pak6.pk3 (3 files)
    C:\PROGRA~1\CALLOF~2\main\pak5.pk3 (4858 files)
    C:\PROGRA~1\CALLOF~2\main\pak4.pk3 (1668 files)
    C:\PROGRA~1\CALLOF~2\main\pak3.pk3 (1992 files)
    C:\PROGRA~1\CALLOF~2\main\pak2.pk3 (694 files)
    C:\PROGRA~1\CALLOF~2\main\pak1.pk3 (2642 files)
    C:\PROGRA~1\CALLOF~2\main\pak0.pk3 (12816 files)
    C:\PROGRA~1\CALLOF~2\main\german_town.pk3 (31 files)
    C:\PROGRA~1\CALLOF~2/main
    C:\PROGRA~1\CALLOF~2\main\localized_english_pak5.p k3 (46 files)
    localized assets pak file for english
    C:\PROGRA~1\CALLOF~2\main\localized_english_pak3.p k3 (7 files)
    C:\PROGRA~1\CALLOF~2\main\localized_english_pak2.p k3 (9 files)
    C:\PROGRA~1\CALLOF~2\main\localized_english_pak1.p k3 (3736 files)
    C:\PROGRA~1\CALLOF~2\main\localized_english_pak0.p k3 (1204 files)
    File Handles:
    30224 files in pk3 files
    execing default_mp.cfg
    couldn't exec language.cfg
    execing config_mp.cfg
    couldn't exec autoexec_mp.cfg
    Hunk_Clear: reset the hunk ok
    ...detecting CPU, found Intel Pentium III
    Measured CPU speed is 2.41 GHz
    System memory is 512 MB (capped at 1 GB)
    Video card memory is 64 MB
    Streaming SIMD Extensions (SSE) supported
    Winsock Initialized
    Opening IP socket: localhost:28960
    Hostname: vermeire-1ntbnb
    IP: 192.168.2.101
    ----- Client Initialization -----
    ----- Initializing Renderer ----
    ----- Client Initialization Complete -----
    ----- R_Init -----
    Initializing OpenGL subsystem
    ...initializing QGL
    ...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): failed
    ...shutting down QGL
    Forcing 640x480 resolution to allow OpenGL to run in fullscreen
    ...initializing QGL
    ----- CL_Shutdown -----
    RE_Shutdown( 1 )
    Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site.
    waar het eigenlijk op neerkomt is dit:Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site. nu vraag ik mij af wat ik moet doen om da probleem op te lossen.
    AhReNd's Avatar
    Opwijk
    download de laatste nieuwe drivers ??
    Cuth's Avatar
    bleirgh
    en waar kan ik die dan wel vinden?
    Maldegem
    op de site van de fabrikant van uw grafische kaart
    Cuth's Avatar
    bleirgh
    ok ty shib ecu
    Bad Religion's Avatar
    Merksplas
    h4x!1!1!1
    Anyone Can Dig a Hole But it Takes a Real Man to Call it Home
    Cuth's Avatar
    bleirgh
    errrr wat???? khebbem ni:<
    devilknight's Avatar
    oilsjt
    oO
    byter's Avatar
    pc specs ffs
    Service guarantees citizenship.
