    -2 (25%)
    druid talent points voor pvp
    hallo
    ik wil graag met een druid starten vooral omdat ze pvp vrij goed zijn, maar waar kan ik dan best men talent points in steken (in healen zodat ik me kan healen of in spreuken) ? Ik wil vooral pvp sterk zijn.
    Aangezien ik nog een noob ben ken ik er nog niet veel van.
    alvast bedankt
    oya's Avatar
    San Andreas
    restoration met feral charge zeker?
    das de meest gebruikte
    balance druids no idea mor kem goort da da nie zo pwn is
    edit:
    Balance Talents (5 points)
    # Nature's Grasp - 1/1 point
    While active, any time an enemy strikes the caster, they have a 35% chance to become afflicted by Entangling Roots (Rank 1). Only usable outdoors. 1 charge. Lasts 45 seconds.
    # Improved Nature's Grasp - 4/4 points
    Increases the chance for your Nature's Grasp to entangle an enemy by 65%.
    Feral Combat Talents (11 points)
    # Ferocity - 5/5 points
    Reduces the cost of your Maul, Swipe, Claw, and Rake abilities by 5 Rage or Energy.
    # Sharpened Claws - 3/5 points
    Increases your critical strike chance while in Bear or Cat form by 3%.
    # Improved Bash - 2/2 points
    Increases the stun duration of your Bash ability by 1 second.
    # Feral Charge - 1/1 point
    Causes you to charge an enemy, stopping its movement and interrupting any spell being cast for 4 seconds.
    Restoration Talents (35 points)
    # Improved Mark of the Wild - 5/5 points
    Increases the effects of your Mark of the Wild spell by 35%.
    # Nature's Focus - 5/5 points
    Gives you a 60% chance to avoid interruption caused by damage while casting the Healing Touch or Regrowth spells.
    # Improved Healing Touch - 5/5 points
    Reduces the mana cost of your Healing Touch spell by 15%.
    # Gift of Nature - 1/1 point
    Increases the effect of your Healing Touch, Rejuvenation, Regrowth, and Tranquility spells by 5%.
    # Reflection - 5/5 points
    Allows 15% of your Mana regeneration to continue while casting.
    # Improved Rejuvenation - 5/5 points
    Increases the effect of your Rejuvenation spell by 15%.
    # Nature's Swiftness - 1/1 point
    When activated, your next Nature spell becomes an instant cast spell.
    # Improved Tranquility - 2/2 points
    Gives you a 80% chance to avoid interruption caused by damage while casting your Tranquility spell.
    # Improved Regrowth - 5/5 points
    Increases the critical effect chance of your Regrowth spell by 50%.
    # Innervate - 1/1 point
    Increases the target's Mana regeneration by 400% and allows 100% of the target's Mana regeneration to continue while casting. Lasts 20 seconds.
    zoiets ongeveer
    Wolfmeister's Avatar
    ik ga voor den deze,
    Balance Talents (9 points)
    # Nature's Reach - 1/2 point
    Increases the range of your Wrath, Entangling Roots, Faerie Fire (caster form only), Moonfire, and Starfire spells by 10%.
    # Swiftshifting - 3/3 points
    After leaving a shapeshift form, reduces the casting cost of the next shapeshift by 60% if used with 6 seconds.
    # Sharpened Claws - 5/5 points
    Increases your critical strike chance while in Bear or Cat form by 5%.
    Restoration Talents (31 points)
    # Furor - 4/5 points
    Gives you a 80% chance to gain 10 Rage when you shapeshift into Bear form.
    # Combat Endurance - 5/5 points
    Allows 10% of your Health regeneration to work while in combat.
    # Improved Regrowth - 4/5 points
    Increases the critical effect chance of your Regrowth spell by 40%.
    <div align="center"> Grand Theft Auto <br /> </div>
    Maugan Ra's Avatar
    Daar was ik dus al bang voor hé...
    Dat mijn post meteen in het onbekende valt en niet gelezen wordt door dit soort volk.
    http://games.telenet.be/forum/showthread.php?t=321354
    PS: met dit soort volk bedoel ik het "ik-ken-er-niets-van-maar-zeg-mij-hoe-de-beste-te-zijn"-volk
    "When there is no other way, the perilous path is the only road to salvation."
    - Eldrad Ulthran, Farseer of Ulthwé -
    KoningDanny's Avatar
    Quote Originally Posted by Frustos
    hallo
    alvast bedankt
    not again .... aaargh the horror, make it stop
    Undead Rogue - horde
    allistair's Avatar
    Arcadia
    zorg zeker da ge natures swiftness hebt, heeft men vel al veel gered (vooral tegen rogues)
    Karex's Avatar
    Quote Originally Posted by Wolfmeister
    ikke ook zot goe ...
    AMD Athlon64 3200+ // Sapphire Radeon 9800PRO@XT // Corsair TwinX 2*512Mb // Asus K8N-E Deluxe // Enermax NoiseTaker 470 Watt // Maxtor Hdd 160 gb // Western Digital Hdd 40 gb //// Tevens trotse bezitter van een iPOD /
    Karex 60 NE druid , Lutgart 60 human warlock Dragonmaw-->Frostmane (migrated); Servaas 51 Tauren Shaman, Zenedar
    Fuzetsu's Avatar
    Overpelt
    2 (75%)
    Combat Endurance is CRAP...
    Mijn HP regen out of combat is denk ik 40 / tick ofzo, maximum...
    Daar 10% van is 4 / tick...
    Das nada, noppes,...
    En ff terzijde: hoera voor de miljardste thread over hetzelfde onderwerp!
    ///Corsair R500 Black Case - Corsair TX750M PSU - Gigabyte Z68XP-UD4 - Intel i5 2500k – Corsair Vengeance 2 x 4 GB DDR3 - Gigabyte GeForce 560 Ti - 120 GB OCZ Vertex 2 SSD – 3 TB HDD
    EternalSilence's Avatar
    allemaal zo weinig feral combat
    bij mij zit alles daarin
    kzal later wel eens mijne build posten
    madawc's Avatar
    nefst badstopke
    Quote Originally Posted by Doom Dragon
    ²
    alleen een 2 puntjes in improved wrath +1tje in nature's grasp
    (die 2 puntjes in wrath zouden normaal erges in feral moeten zitten^^)
    plauZ's Avatar
    Soul Society
    gl dan in endgame instances
    tjekenneth's Avatar
    Berlare
    Ik heb mijne gereset en heb innervate en nature's swiftness ma ik heb ook ne nieuwe spell waar da geen een schild activeert die u tegne schade 20% beschermd , en cast time me 1s vergroot , is da normaal?
    Fuzetsu's Avatar
    Overpelt
    2 (75%)
    Quote Originally Posted by tjekenneth
    Lol?
    Da zat er al sinds vorige major update in (nog VOOR de honor patch)...
    Iemand leest dus blijkbaar niet de patchnotes...
    Sffs ga je nog zeggen dat je Ferocious bite en Frenzied Regeneration ook niet hebt? :O
    oilsjt
    me da schild moede die 2 punten in improved tranquility nie gebruiken
    want dan is er geen interrupt mogelijk
    Bad Company Skullcrusher EU
    Zagamoth lvl 60 Druid
    Ruthless lvl 60 Warlock
    Arohk's Avatar
    go with wolfmeister, imo de betere build...
    Kopieer deze signature en maak kans op een hetze. Klik hier voor meer info!
