Thread: Mage build
    m0x's Avatar
    Gaverland
    Mage build
    KHeb een vraagsken over mijn build, onderstaande build zou de mijne worden op lvl 60, isda een goede keuze? Of zou ik beter 31/20 Arcane/fire pakken?
    Ik zou dus graag redelijk veel dmg willen dealen in redelijk korte tijd.
    Arcane Talents (20 points)
    # Improved Arcane Missiles - 5/5 points
    Gives you a 100% chance to avoid interruption caused by damage while channeling Arcane Missiles.
    # Arcane Concentration - 5/5 points
    Gives you a 10% chance of entering a Clearcasting state after any damage spell hits a target. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
    # Evocation - 1/1 point
    While channeling this spell, your mana regeneration is active and increased by 1500%. Lasts 8 seconds.
    # Improved Arcane Explosion - 4/5 points
    Reduces the casting time of your Arcane Explosion by 1.2 seconds.
    # Arcane Meditation - 5/5 points
    Allows 15% of your Mana regeneration to continue while casting.
    Frost Talents (0 points)
    # None
    Fire Talents (31 points)
    # Improved Fireball - 5/5 points
    Reduces the casting time of your Fireball by 0.5 seconds.
    # Ignite - 5/5 points
    Your critical strikes from fire damage spells cause the target to burn for an additional 40% of your spell's damage over 4 seconds.
    # Flame Throwing - 2/2 points
    Increases the range of your fire spells by 6 yards.
    # Incinerate - 2/2 points
    Increases the critical strike chance of your Fire Blast and Scorch spells by 4%.
    # Pyroblast - 1/1 point
    Hurls an immense fiery boulder that causes 148 to 195 fire damage and an additional 56 damage over 12 seconds.
    # Burning Soul - 3/3 points
    Gives your fire spells a 65% chance to not lose casting time when you take damage.
    # Improved Flamestrike - 3/3 points
    Increases the critical strike chance of your Flamestrike spell by 15%.
    # Critical Mass - 3/3 points
    Increases the critical strike chance of your fire spells by 6%.
    # Blast Wave - 1/1 point
    A wave of flame radiates outward from the caster, damaging all enemies caught within the blast for 160 to 192 fire damage, and dazing them for 6 seconds.
    # Fire Power - 5/5 points
    Increases the damage done by your fire spells by 10%.
    # Combustion - 1/1 point
    When activated, this spell gives your next fire damage spell a 100% critical strike chance.
    2 x Synq X-trm 1's (2x Ortofon Concordes Pro's) + Ecler Nuo 4 + Traktor Scratch
    CBA's Avatar
    Ik zou één punt van arcane meditation in arcane explosion steken, dan heb je instant AE
    En combustion of Precense of Mind dat blijft iedereen z'n keuze
    dee's Avatar
    Of arcane meditation laten vallen en dat 1 puntje gebruiken voor IAE en de rest weet ik veel waar.
    Arcane meditation kan heel nuttig zijn maar er zijn wel een paar bedenkingen.
    - Geldt enkel voor spells die worden gecast. Channelen en de rest valt al uit de boot.
    - In principe moet je u ook toeleggen op +spirit om de mana/tick the maximaliseren.
    Ieder zijn zin natuurlijk, ik heb er persoonlijk geen 5 punten voor over.
    ( \_/ )
    (")_(")*
    BaNoRaC's Avatar
    weg met arcane meditation imo
    little_guy9's Avatar
    idd, weg met die meditation,
    Beter spenderen aan improved counterspell (beste spell tegen een priest of druid, kans op silence ownz ^^) en mana shield, aangezien ge geen frost shield hebt.
    Dan heb je nog 1 talentje over en kun je arcane expolosion vervolledigen
    en zoals gezegd: combustion Vs Precense of Mind is moeilijke keuze
    _____________________________
    under a pale grey sky the undead shall Arise
