Thread: überdringend!! THUG
30-03-2005, 22:34 #1Member
- 10/03/03
- Diepenbeek
- 3,571
- 14 (100%)
- 0/7
überdringend!! THUG
Hey peeps... Ik heb gehoord dat het level hangar unlockable is bij thug.... WAAR KAN JE HET HALEN?? plz heeeeeeelp
Ich schiese op konijnen met maine 9 milimeteh met leezeh jaah?
ZD&V ftw!no votes
30-03-2005, 23:46 #2
Tis idd unlockable,heb het spel ook,
maar weet niet echt meer waar het is,
zoek eens op google,daar heb ik het gevonde,
der zijn trouwens nog 2lvl's unlockable.
Edit: 5sec gezocht op google,eerste pg:
Unlockable Levels
Hotter Than Hell:
Beat story mode
School II (THPS2):
This Old Skool Icon is found in New Jersey. First things first, cross the bridge, and follow the street until you can't go any further. The icon is on a ledge of the building directly in front of you. Get air off the quarter pipes, and grind your way to the right to find the icon.
Information provided by The Offspring
Venice (THPS2):
You can find this Icon in Hawaii. From where you begin, follow the road until you find a large tiki head. When you jump inside the tiki's mouth, you'll emerge in a tunnel. Skate all the the way down and ollie at the right moment to grab the Venice Icon.
Hanger (THPS2):
The Hanger icon is located in Moscow. To get it go through the archway ahead of you and turn right and you should see a brown building. Go to the side of the building with the writing on it. It says 'aehnh'. Get off your board and climb up and face the red building in front of you. Grind along the dark brown ledge and jump through the window straight ahead of you. You should be in a small room. Go up the ramp on the right and the icon is there at the top.
Information provided by bomb agentLast edited by cooly; 31-03-2005 at 00:01.
31-03-2005, 00:36 #3
waar je begint hé , waar je dan iets door moet rijden waar aan je rechter kant tanks zijn
rij helemaal terug waar je door die boog kunt , naar links, er staan allemaal ramen onder afdak, ik denk het 5 raam kun je breken en loop dan naar boven..voila
gewoon langs die ramen lopenThe Age Of Men Is Over , The time Of The Orcs Has Come!no votes
31-03-2005, 00:44 #4
Dus eigenlijk hetzelfde wat ierboven ong al staat maar dan int nederlands.
31-03-2005, 11:20 #5Member
- 10/03/03
- Diepenbeek
- 3,571
- 14 (100%)
- 0/7
jama ik had da gevonde ma die legde da heel ingewikkeld uit... bedankt swws probere...
ZD&V ftw!no votes
31-03-2005, 11:23 #6
ahja,en edde die andere 2 al gevonde?
tis idd ingewikkeld uitgelegd.no votes
31-03-2005, 11:41 #7Member
- 10/03/03
- Diepenbeek
- 3,571
- 14 (100%)
- 0/7
nog een vraagske hoe kunt ge die opdracht in manhattan doen met die bowl combo's ? da is toch onmogelijk....
ZD&V ftw!no votes
31-03-2005, 16:34 #8
Bowl Combo's?
31-03-2005, 18:00 #9Member
- 10/03/03
- Diepenbeek
- 3,571
- 14 (100%)
- 0/7
tis al gebeuert.
ZD&V ftw!no votes
