26-03-2005, 13:53 #1Member
- Aantwaarepe
- 101
Wat is er mis met mijn AutoExec???
Kan iemand mijn AutoExec eens nakijken, want die wil niet opstarten en als ik manueel /exec autoexec intyp, dan krijg ik de melding "Unknown command u". Hij staat zowel in ETmain als in mijn profiel.
Thanx a lot!Code:unbindall echo "^'Loading ^&AutoExec" //Movement Binds //-------------- bind a "+leanleft" bind d "+leanright" bind SPACE "+movedown" bind q "+moveleft" bind e "+moveright" bind w "+forward" bind s "+back" bind ALT "+sprint" bind CTRL "+prone" bind SHIFT "+speed" bind MOUSE2 "+moveup" //Weapon Binds //------------ bind MWHEELDOWN "zoomout" bind MWHEELUP "zoomin" bind b "+zoom" bind c "weapnext" bind x "weapprev" bind v "+reload" bind MOUSE1 "+attack" bind MOUSE4 "+zoom" bind MOUSE5 "weapalt" //Banks bind 0 "weaponbank 10" bind 1 "weaponbank 1" bind 2 "weaponbank 2" bind 3 "weaponbank 3" bind 4 "weaponbank 4" bind 5 "weaponbank 5" bind 6 "weaponbank 6" bind 7 "weaponbank 7" bind 8 "weaponbank 8" bind 9 "weaponbank 9" //Chat Binds //---------- bind . "messagemode" bind r "messagemode2" bind z "mp_fireteammsg" //Messages: Team bind HOME "wm_sayplayerclass" bind PGUP "vsay_team EnemyDisguised" bind UPARROW "vsay_team ReinforceOffence" bind DOWNARROW "vsay_team ReinforceDefence" bind y "vsay_team Affirmative" bind n "vsay_team Negative" bind h "vsay_team NeedBackup" bind i "vsay_team Medic" bind k "vsay_team Sorry" bind l "vsay_team Thanks" //Messages: All bind INS "vsay Hi" bind DEL "vsay bye" bind p "vsay GreatShot" bind 0 "vsay Cheer" //Fire Team bind KP_LEFTARROW "selectbuddy 3" bind KP_5 "selectbuddy 4" bind KP_RIGHTARROW "selectbuddy 5" bind KP_END "selectbuddy 0" bind KP_DOWNARROW "selectbuddy 1" bind KP_PGDN "selectbuddy 2" bind KP_ENTER "mp_fireteamadmin" bind KP_INS "selectbuddy -2" bind KP_DEL "selectbuddy -1" //General Settings //---------------- bind TAB "+scores" bind ESCAPE "togglemenu" bind ` "toggleconsole" bind ~ "toggleconsole" bind , "mapzoomout" bind g "+mapexpand" bind l "openlimbomenu" bind m "mvactivate" bind f "+activate" bind F1 "vote yes" bind F2 "vote no" bind F3 "ready" bind F4 "notready" bind F11 "autoscreenshot" bind F12 "autorecord" //Available Keys //-------------- //bind t "messagemode" //bind u "messagemode3" //bind CAPSLOCK "+speed" //bind - "zoomout" //bind = "zoomin" echo "^&AutoExec ^'loaded
26-03-2005, 14:09 #2Approved 9-lifer
- 05/08/02
- Ingelmunster
- 1,876
- 13 (100%)
"unbind all"
met een spatie tussen volgens mij
26-03-2005, 14:29 #3
mss werkt je autoexex generated by et die tegen ...
of heb je een serieuze tijpfout elke keer
probeer die ook eens in etpro te steken en load hem dan pas als je in een etpro server bent soms zijn die configs andersHeXno votes
26-03-2005, 16:02 #4Member
- Aantwaarepe
- 101
'k heb nog geen ETpro staan... wachten tot die compatibel is met de 2.60 patch...
26-03-2005, 19:56 #5
Download etpro en oude versie draaien imo
Sile#bangelijkno votes
26-03-2005, 22:07 #6no votes
26-03-2005, 22:08 #7no votes
26-03-2005, 22:15 #8no votes
26-03-2005, 22:34 #9
Well whadda you know, you're right...
Kheb da altijd al met gedaan...
btw: nog een muggezift dingetje: echo "^&AutoExec ^'loaded (uw tweede " vergeten, maar da zal wel met copy-paste zijn gebeurd denkek, maar kvermeld het toch maar in geval dit nie zo zou zijn
Terreurkipno votes
29-03-2005, 15:11 #10Member
- Aantwaarepe
- 101
idd, was weggevallem net copy-paste
Ik heb geen oplossing gevonden, dus heb dan maar mijn ETconfigs aangepast...
de enige die op de één of andere reden niet willen werken zijn die ARROW toetsen...no votes
29-03-2005, 15:57 #11Member
- 10/01/03
- Olen
- 1,934
zeker dat 't bestand autoexec noemt en de extensie .CFG heeft?
“The revolution is not an apple that falls when it is ripe. You have to make it fall.”no votes
29-03-2005, 18:26 #12
Als ge da nu is vanaf het begin had gezegd é (khad geen goesting om heel die cfg na te kijken weet ge, maar nu ge zegt dat het alleen over arrows gaat)
Defense wordt (voornamelijk) met een 's' geschreven en niet met 'c' (officieel kunnen ze allebei, maar meestal wordt defense geschreven, hier dus ook)bind UPARROW "vsay_team ReinforceOffence"
Dus
bind UPARROW "vsay_team ReinforceOffense"
bind DOWNARROW "vsay_team ReinforceDefense"
Bitte sehr.
Edit: same for offense... vergeten vermelden
Terreurkipno votes
31-03-2005, 08:59 #13Member
- Aantwaarepe
- 101
Ja...
Het ging niet alleen over die pijltjes, de gehele autoexec wou niet werken... vandaar dat ik nu die gehele lijst in de twee ETconfigs heb geplaatst (die in ETmain en in mijn Profile)
Tnx voor de verbetering, ik zal ze vanavond eens toepassen...
31-03-2005, 19:51 #14
Kheb em int geheel ook wel ne keer vlug nagekeken (en nu net nog eens) een kzie geen enkele zwaar verkeerde command waardoor uw autoexec niet executed zou kunnen worden.
Btw: kdenk nie da ge da echt in die 2 configs moet plakken, alleen een autoexec maken en die executen en dan ET deftig afsluiten. Dan update die da automatisch... normaal gezien toch.
Anyway: als het nu wel werkt: des te beter!
Moest het nog nie werken, moogde altijd iets laten weten.Terreurkipno votes
#urbanterror.be on Quakenet
