HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: Unable to compile class for JSP
org.apache.jasper.compiler.DefaultErrorHandler.jav acError(DefaultErrorHandler.java:97)
org.apache.jasper.compiler.ErrorDispatcher.javacEr ror(ErrorDispatcher.java:346)
org.apache.jasper.compiler.Compiler.generateClass( Compiler.java:414)
org.apache.jasper.compiler.Compiler.compile(Compil er.java:472)
org.apache.jasper.compiler.Compiler.compile(Compil er.java:451)
org.apache.jasper.compiler.Compiler.compile(Compil er.java:439)
org.apache.jasper.JspCompilationContext.compile(Js pCompilationContext.java:511)
org.apache.jasper.servlet.JspServletWrapper.servic e(JspServletWrapper.java:295)
org.apache.jasper.servlet.JspServlet.serviceJspFil e(JspServlet.java:292)
org.apache.jasper.servlet.JspServlet.service(JspSe rvlet.java:236)
javax.servlet.http.HttpServlet.service(HttpServlet .java:802)
edu.yale.its.tp.cas.client.filter.CASFilter.doFilt er(CASFilter.java:419)
org.springframework.web.filter.CharacterEncodingFi lter.doFilterInternal(CharacterEncodingFilter.java :73)
org.springframework.web.filter.OncePerRequestFilte r.doFilter(OncePerRequestFilter.java:73)
root cause
Error running /usr/local/java/bin/javac compiler
org.apache.tools.ant.taskdefs.compilers.DefaultCom pilerAdapter.executeExternalCompile(DefaultCompile rAdapter.java:452)
org.apache.tools.ant.taskdefs.compilers.JavacExter nal.execute(JavacExternal.java:44)
org.apache.tools.ant.taskdefs.Javac.compile(Javac. java:942)
org.apache.tools.ant.taskdefs.Javac.execute(Javac. java:764)
org.apache.jasper.compiler.Compiler.generateClass( Compiler.java:379)
note The full stack trace of the root cause is available in the Apache Tomcat/5.0.27 logs.
