Thread: 1.18 !
    Musk's Avatar
    22 Post(s)
    1.18 !
    WARCRAFT III: THE FROZEN THRONE VERSION HISTORY
    - PATCH 1.18
    FEATURES
    - 6 maps from our Bonus Map program including (4)Excavation Site, (2)Echo
    Isle, (6)Hinterland Raid, (6)Ruins of Stratholme, (8)Azeroth Grand Prix,
    (8)Extreme Candy Wars 2004.
    FIXES
    - Fixed a problem that prevented selection sounds from playing when
    units were drag-selected.
    - Fixed a problem that caused Gargoyles to become stuck in Stone Form.
    - Fixed a problem with Dark Ritual or Death Pact leaving an unusable
    corpse.
    - Fixed a problem that caused a player's units to continue to harvest
    resources after they were dropped and no one has control of them.
    - Fixed a problem that allowed Ethereal units to take Physical damage from
    missiles that were in flight as they became Ethereal.
    - Fixed a problem that allowed Magic Immune units to take Magical damage
    from missiles that were in flight as they became Magic Immune.
    - Fixed a problem that allowed Unstable Concoction to kill the casting
    Batrider even after its target became Ethereal.
    - Fixed the visibility of the Flamestrike de-buff icon.
    - Fixed a problem with Defend not absorbing Piercing splash damage.
    - Fixed a problem with melee units with Incinerate not damaging any units
    that they would Incinerate.
    - Fixed a problem that caused Heroes holding items that increase their
    primary attribute to display an increase in their base damage on the
    info panel. Their actual damage was not affected.
    - Fixed a problem that allowed morphing units in their alternate form to
    retain their alternate form bonuses when killed by a Mana Flare when
    activating their alternate form.
    - Fixed a problem that allowed Destroyers to use Devour Magic on Watcher
    Wards.
    - Fixed a problem that prevented Watcher Wards from being revealed by the
    Dust of Appearance.
    - Fixed a problem that removed the Summoned state from Carrion Beetles
    when they burrow.
    - Fixed a problem with Metamorphosis and Chemical Rage that allowed the
    timer to remain active after the Hero had died.
    - Fixed a problem with Goblin Zeppelins being considered Undead instead of
    Mechanical in custom Reign of Chaos maps.
    MAPS
    - (6)River of Souls - Changes to allow AMM play.
    - (8)Crossroads - Fixed a grammatical error.
    BALANCE CHANGES
    Undead
    - Banshee build time has been reduced to 28 seconds from 35 seconds.
    Neutral
    - Drunken Haze movement reduction has been changed to increase by level.
    The new ranks are: 15% / 30% / 50% from the previous 50% / 50% / 50%.
    - Breath of Fire initial damage reduced to 65/125/170 from 65/130/175.
    - Tornado mana cost has been reduced to 200 mana from 250 mana.
    - Incinerate can now be turned on or off. When turned on, it
    consumes 6 mana per attack. It is otherwise unchanged.
    - Lava Spawns now require 15 attacks to replicate, up from 14.
    - Summon Quilbeast cooldown increased to 25 seconds from 20 seconds.
    - Summon Hawk mana cost increased to 50 mana from 35 mana.
    - Pocket factory hit points increased to 300/450/600 by level from
    300/400/500.
    - Healing Spray effect per wave increased to 40/55/70 from 35/50/65
    Items
    - Staff of Teleportation gold cost has been increased to 150 gold from 100
    gold.
    WORLD EDITOR FEATURES
    Trigger Editor
    - Added new functions:
    - Environment: Terrain Pathability
    - Environment: Terrain Tile Type
    - Environment: Terrain Tile Variance
    - Floating Text: Permanent/Expires
    - Floating Text: Suspend/Resume
    - Floating Text: Change Position to Point
    - Floating Text: Change Position to Unit
    - Floating Text: Change Age
    - Floating Text: Change Lifespan
    - Floating Text: Change Fadepoint
    - Floating Text: Change Text
    - Game: Enable/Disable Selection (Functionality and/or UI)
    - Game: Enable/Disable Pre-Selection (Functionality and/or UI)
    - Game: Enable/Disable Drag-Selection (Functionality and/or UI)
    - Trigger: Get Trigger Name
    - Added new unit states:
    - Plagued
    - Snared
    - Stunned
    - Poisoned
    - Polymorphed
    - Sleeping
    - Resistant
    - Ethereal
    - Magic Immune
    - Lightning triggers now have their own category.
    - Lightning triggers now use the Z coordinate of the specified Location.
    - Custom Lightning triggers can now use an explicit Z coordinate.
    WORLD EDITOR FIXES
    - Fixed custom buff support for Black Arrow, Cloud of Fog, Inferno, Aerial
    Shackles, and Tornado.
    - Fixed multiple-level support for Shadowmeld.
    - Fixed Rain of Chaos' order id.
    ChfZ | Hanky's Avatar
    Zoersel
    Zieter nice uit
    kArA's Avatar
    Helemaal niet slecht alleen wel wat mager...
    Ne werd heel de tijd als imba genoemd door de tavern heroes (zal nu eindelijk verandering in brengen) maar voor de rest?? vind ik ze wat mager ma ja wie ben ik
    Grtz kArA
    Musk's Avatar
    22 Post(s)
    tis ook maar een kleine fix vind ik, ze hadden het ook 17b kunne noemen ;o
    kdenk niet dat er in de toekomst nog zware changes zullen komen.. nogal logisch.
    Starrk's Avatar
    33 (97%)
    klein maar dapper!
    Ginyu's Avatar
    A'pen-Braschaat
    al goed dat ze der geennieuwe heroes meer bijpropten heel die balancing weer naar de knoppen en kijveel abuse
    Justchill's Avatar
    Sint-Andries Brugge
    25 (100%)
    *downloading update*
    My Bitcoin Faucet rotator : http://best-faucet-rotator.tk
    Zoersel
    Quote Originally Posted by Justchill
    Gij't precies wel nen trage pc da ge nog altijd den patch aan't downen zijn eh
    Tesla's Avatar
    Boortmeerbeek
    humor van de bovenste plank
    A man doesn't automatically get my respect. He has to get down in the dirt and beg for it.
    Musk's Avatar
    22 Post(s)
    OM VANONDER TE BEGINNEN EH !!! HAHAAHHA LOLOLOLOLLOLOL !!111ONEONE!!!!!!11....
    vet.
    Zoersel
    Quote Originally Posted by Tesla
    FLAME ME PLZ! AND GET SOME BACKUP!
    @ musk: Grappig
    Justchill's Avatar
    Sint-Andries Brugge
    25 (100%)
    Wel om eigenlijk iets meer te vertellen... dit is wat er gebeurde:
    Ik had tijdje OS partitie geformatteerd, warcraft 1.17 laten staan op E:\
    Draaide nog steeds perfect, tot gisteren tot je moest patchen naar 1.18
    Na 't downloaden vond hij het installpath niet... Heb hem dus opnieuw moeten installeren :-( + alle updates...
    Duurde wel 'n tijdje
    greetz
    ubernurd's Avatar
    Eeklo
    hehe, ik heb net zelfde probleem gehad
    Musk's Avatar
    22 Post(s)
    greetz
    ge moest eigelijk gewoon booten vanuit uw E:\ schijf, maar bon...
    N3O's Avatar
    Tielt
    of in registry aanpassen
