    Overburner67's Avatar
    Lier
    CS - Connect Server error
    Als ik connect naar server krijg ik dit = ************************************************** *
    You are joining a server that implements Valve's anti-cheat system (VAC).
    Please note that the use of Cheats is a violation of your End User License
    Agreement for the software and/or your Steam Subscriber Agreement.
    If Valve or the game host detects your use of Cheats on an VAC-enabled
    server, your Steam Subscription and/or your product key for the software
    will be banned from playing on VAC-enabled servers for one (1) year.
    models/player/urban/urban.mdl
    SC: The Server does not allow custom models! Please reinstall!
    Dus CS reinstalle ?
    Fraggie's Avatar
    of de custom model deleten
    Lier
    Hebbet al gereinstalled ff kijke of et nu trug normaal is
    Lier
    Heb die Urban gedelete ma hij geeft nog altijd dezelfde error
    Fraggie's Avatar
    steam opnieuw downloaden, mss ligt het daaraan (corrupt model)
