Thread: [HL2] ladders in hammer
03-02-2005, 18:01 #1
ik heb tutorials gedownload, ik heb de search fuction gebruikt (een unicum in de geschiedenis van dit forum), ik heb gebeden, maar het hielp niks.
hoe maak ik ladders in hammer?
voila...no votes
03-02-2005, 19:03 #2Member
- 14/10/02
- The Matrix
- 7,303
- 8/20
Counter-Strike: Source: Een brush met de "ladder" texture
Half-Life 2: DM: func_usableladder en info_ladderdismount
Over de laatste methode:Video tuturials vind je hier.Create your prop/brush/whatever you want to climb, place that in your desired location. Then create another brush parrallel to the entity/brush you just created, space it out as close as you can get it to the brush/entity, but try not to let them touch. Also make it the exact (or as close as you can get it to) length and width of your entity/brush. Apply the toolsnodraw texture to the brush that you just created and then hit ctrl + T (while selecting) and where it says "func_***" rename it func_ladder. Compile and test.
What this does is creates an invisible surface that is the actual climbing material. The closer you create this brush to the "ladder", the better it will look."At the beginning of the Portal development process, we sat down as a group to decide what philosopher or school of philosophy our game would be based on. That was followed by about fifteen minutes of silence and then someone mentioned that a lot of people like cake."
- Valveno votes
03-02-2005, 20:02 #3
duizend maal dank.
nu nog 2 minuutjes werk, dan een halfuur compilen, en mijn 2de echte lvezl is af
