    dr. penguin's Avatar
    fout bij rtcw et install
    hoi
    heb rtcw et install gedaan maar als ik het opstart krijg
    ik een foutmelding (onderaan)
    kan iemand mij helpen wat ik eraan kan doen?
    thx
    ET 2.56 win-x86 Sep 5 2003
    ----- FS_Startup -----
    Current search path:
    C:\PROGRA~1\WOLFEN~1\etmain\pak1.pk3 (10 files)
    C:\PROGRA~1\WOLFEN~1\etmain\pak0.pk3 (3725 files)
    C:\PROGRA~1\WOLFEN~1\etmain\mp_bin.pk3 (4 files)
    C:\PROGRA~1\WOLFEN~1/etmain
    3739 files in pk3 files
    execing default.cfg
    couldn't exec language.cfg
    couldn't exec autoexec.cfg
    Hunk_Clear: reset the hunk ok
    ...detecting CPU, found AMD w/ 3DNow!
    Bypassing CD checks
    ----- Client Initialization -----
    ----- Initializing Renderer ----
    ----- Client Initialization Complete -----
    ----- R_Init -----
    Initializing OpenGL subsystem
    ...initializing QGL
    ...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
    ...setting mode 4: 800 600 FS
    ...using desktop display depth of 32
    ...calling CDS: ok
    ...registered window class
    ...created window@0,0 (800x600)
    Initializing OpenGL driver
    ...getting DC: succeeded
    ...GLW_ChoosePFD( 32, 24, 0 )
    ...35 PFDs found
    ...GLW_ChoosePFD failed
    ...35 PFDs found
    ...failed to find an appropriate PIXELFORMAT
    ...restoring display settings
    ...WARNING: could not set the given mode (4)
    ...using colorsbits of 16
    ...calling CDS: ok
    ...GLW_ChoosePFD( 16, 16, 0 )
    ...35 PFDs found
    ...35 PFDs found
    ...WARNING: could not set the given mode (3)
    ...shutting down QGL
    ...unloading OpenGL DLL
    ...assuming '3dfxvgl' is a standalone driver
    ...initializing QGL
    ...WARNING: missing Glide installation, assuming no 3Dfx available
    ----- CL_Shutdown -----
    RE_Shutdown( 1 )
    GLW_StartOpenGL() - could not load OpenGL subsystem
    We are Microsoft. Resistance Is Futile. You Will Be Assimulated
    Mordholion's Avatar
    Welke videokaart heb je?
    Ex-clans: Dark Alliance, Illuminated, Elite, Ferocious, AngelDust, Oceans6
    Status : Uninstalled ET
    nvidia riva tnt2
    Brock's Avatar
    Bristol club -
    gewoon de laatste drivers installeren.
    Deze kan je hier vinden:
    http://games.telenet.be/files.php
    (opgelet, neem die van nvidia en niet van ati !)
    Raanº³'s Avatar
    Drongen
    Deze zijn recenter
    [ Momenteel geen signature ]
    Quote Originally Posted by Raanº³
    Deze zijn recenter
    en goan !
    strax uittesten nu dll
    heb laatste driver nvidia international 66.93 install gedaan maar nog steeds hetzelfde prob
    iemand een idee?
    Dr. P
