    city of heroes beta key tzijn echte
    Welcome to the City of Heroes European Beta test! Your Beta serial code is:
    6GK2-Q4SR-T7VC-6HXW-JQR8
    In order to enter Paragon City and start bringing criminals to justice, you need
    to perform the following steps:
    1. Sign into your PlayNC Master Account at http://www.plaync.com
    2. Using the 'Add Game' link, use your Beta serial code to create a European
    Beta game account.
    3. Register on the City of Heroes European Message Boards at
    https://uk.boards.cityofheroes.com
    4. Download the European Beta Updater from https://uk.boards.cityofheroes.com/
    5. Uncompress the Updater.
    6. & 7. Run the Updater to install and download the City of Heroes European Beta
    client.
    8. Create a shortcut to start the game in future.
    These steps are explained in detail below:
    1. Go to the PlayNC website and sign-in to your PlayNC Master Account:
    Click below, or cut and paste this link into your browser:
    https://secure.plaync.com/cgi-bin/plaync_manage.pl
    2. On the ‘Manage PlayNC Acount’ page, click the ‘Add Game’ link and enter your
    City of Heroes European Beta serial code.
    On the next screen, you can choose whether to make your European Beta account
    name and password the same as for your PlayNC Master Account. If you choose
    ‘Yes’, you will be taken to a confirmation screen. If you choose ‘No’, you can
    choose a different account name and password for the Beta – we recommend you do
    this for additional security.
    3. Before you can download the updater and install the game, you must register
    on the City of Heroes European Message Boards. Go to the boards at:
    Click on the ‘New User’ link in the top right. On the next screen, enter your
    Beta account name and password (selected at Step 3, above). On the following
    screen, choose your Board Display Name (the name that other board readers will
    see), your password (we recommend that you make this different to your game
    password for security) and your email address. Click on ‘Submit’ to register
    your message board account.
    4. You can now download the European Beta Updater from:
    https://uk.boards.cityofheroes.com/coh_updater.zip
    If you are not logged into the boards, a pop-up window will prompt you for your
    City of Heroes European Message Boards login name and password. Remember that
    your login will be the same as your European Beta account name (chosen at Step
    2, above) and your password will be the one you selected for the message board
    (Step 3, above).
    We recommend you download the file to your Windows desktop.
    5. Once the coh_updater.zip file has downloaded, you need to uncompress the
    file.
    If you have WinZip, WinRAR or some other compression program installed, you can
    use those as usual. If you have Windows XP, you can uncompress the file by
    right-clicking on it and selecting ‘Extract All…’ and following the prompts,
    which will result in the uncompressed file being placed in a folder on your
    desktop called coh_updater.
    6. IMPORTANT: If you have a previous version of City of Heroes installed, you
    must install the City of Heroes European Beta client to a different folder than
    your existing install. For instructions, see below. If you do not have a
    previous version of City of Heroes installed, go to Step 7, below.
    To install the City of Heroes European Beta client to a different folder than
    your existing City of Heroes installation, double-click on the CohUpdater.EU.exe
    file to start the updater. When the dialogue box opens to tell you that City of
    Heroes will be installed to C:\Program Files\City of Heroes, click ‘No’ and
    choose a different folder from your existing installation. For example, if your
    existing version of City of Heroes is installed to C:\Program Files\City of
    Heroes, we would recommend creating a new folder in C:\Program Files called
    Europe, and installing the game there (which would install the game to
    C:\Program Files\Europe\City of Heroes, as the updater always creates a City of
    Heroes folder in the chosen location). Once the updater has downloaded all the
    files, go to Step 8, below.
    7. To install the City of Heroes European Beta client, double-click on
    CohUpdater.EU.exe to start the updater. A pop-up window will tell you that City
    of Heroes will be installed to C:\Program Files\City of Heroes. You can click
    ‘Yes’ to accept, or ‘No’ to select a different location. Please bear in mind
    that the updater will create a ‘City of Heroes’ folder in the location you
    choose – so if you choose to install to C:\Games, for example, the City of
    Heroes European Beta client will be installed to C:\Games\City of Heroes.
    8. Once the updater has downloaded all the files required to play, you will be
    able to enter the game for the first time. To start the game again in future,
    you can simply double-click the CohUpdater.EU.exe file as before.
    We would recommend, though, that you move the CohUpdater.EU.exe to the folder
    where you installed the game (C:\Program Files\City of Heroes by default), then
    create a shortcut to it on your desktop.
    To do this, move the CohUpdater.EU.exe file to the game folder, then right click
    and select ‘Create Shortcut’. This will create a shortcut called ‘Shortcut to
    CohUpdater.EU.exe’. Move this shortcut to your desktop, then right-click it and
    select ‘Rename’ and call it something like ‘City of Heroes European Beta’. You
    can then just double-click this icon to start the game whenever you want to
    play.
    We hope you enjoy the City of Heroes European Beta!
    Regards,
    NCsoft Europe
    Please note, this is an automated email. Please do not reply to this address. If
    you need further assistance please email eu_cohbeta@plaync.com.
    nog eene
    U83D-LCXP-X9CA-7BXW-5QA8
    Beta game account.
    client.
    (Step 3, above).
    file.
    play.
    Regards,
    NCsoft Europe
    xReAVeRx's Avatar
    brugge
    5 (86%)
    je kan miss gewoon de key posten lol
    tis da of tis niets
    coap's Avatar
    Keerbergen
    jezus hoe wete nu welk al gebruikt is? vraag pm's ofzo
    #TOF#TOF#TOF#TOF#TOF#TOF
    Scourge's Avatar
    kheb just die laatste gebruikt
    sk8ing maniak's Avatar
    ik heb hier ook ne dubbele wie der ene wil pm me
    geen reclame in sig
    mauron's Avatar
    Oostende
    11 (100%)
    Quote Originally Posted by coap
    Just be happy
    Hij is zo vriendelijk om hier 2 betakeys te posten en dan nog commentaar geven. Wees niet lui en probeer ze gewoon, je zal wel zien welke niet werken.
    als er nog iemand een key heeft , kan hij mij gelieve pmeke sturen dank bij voorbaat
    N3m3s1s's Avatar
    Kontich
    Quote Originally Posted by Adeken
    tzelfde
    Drop acid, not bombs.
    plauZ's Avatar
    Soul Society
    tzelfde
    Jerrox's Avatar
    Merelbeke
    Kzoek ook nog een key
    skebamba's Avatar
    heb ook nog key nodig
    Reward it found
