    x
    [HL2] GeForce 4mx 4000
    <BarA|DinDins> Operating System: [WinXP Professional 5.1 (Build #2600)] | Uptime: [1h 40m 11s] | Record: [1d 7h 15m 13s set on Mon Dec 27 20:56:36 2004]
    <BarA|DinDins> Memory Usage: [Usage: 343/576MB (59.55%) | [||||||||||||||||||------------]] | Display Info: [1280x1024 32bit 60Hz] | Monitor: [COMPAQ V700 Color Monitor]
    <BarA|DinDins> CPU Info: [1 CPU - AMD Athlon XP (T-Bred), 1.82 GHz, L1: 64KB L2: 256KB (11% Load)] | Temperature: [Deactivated by user]
    <BarA|DinDins> Hard Disks: [Total/Free: 115.03/9.4GB | Total/Free space on: C: 115.03/9.4GB]
    <BarA|DinDins> Connection/Network Interfaces: [#1 (WAN (PPP/SLIP) Interface (576Kb/s) 3.74MB In, 1.16MB Out)]
    <BarA|DinDins> Personal Statistics Addon By OverDrive Version 4.0
    <BarA|DinDins> -- I am using Windows XP Professional (5.1 - 2600) on Dialup.
    <BarA|DinDins> -- My computer is running 1-AMD , 1819MHz, 256KB (27% Load).
    <BarA|DinDins> -- Running with 341/576MB (59.20%) of memory.
    <BarA|DinDins> -- My graphics card is a NVIDIA GeForce4 MX 4000 displaying at 1280x1024 32bit 60Hz
    <BarA|DinDins> -- Last restart: 1*Hour 41*Minutes 11*Seconds. Record uptime: 1*Day 22*Hours 51*Minutes 12*Seconds.
    Nu beweert die kerel dat hij hl2 kan draaie op high settings met die kaart...
    is daar iets van waar of is die mij voor de zot aant houde wank geloof er ni veel van.
    gStar's Avatar
    Grobbendonk
    71 (95%)
    Op high kan maar dan heeft hem hele lage FPS , ....
    NE maat van mij speelt me een MX 440 alles op Medium
    ~Desktop~ AMD Ryzen 3700x - MPG X570 Gaming Plus - MSI GTX 1080 Aero OC 8GB GDDR5X - Corsair 650Watt - 32GB Corsair Vengeance LPX Black DDR4 - HDD : WD 1 TB SSD + Samsung 850 EVO 250GB SSD + PNY 480GB SSD + 2TB HDD - ASUS MG279 144HZ IPS Monitor
    ~Gear~ Steelseries Siberia Elite Prism - Razer Basilisk - Razer Huntsman KB - Razer Goliathus - LG IPS LED 27EA33
    ~Phone~ iPhone 11 Pro - 256 GB
    Acra's Avatar
    gebruik de FAQ
    kheb er ni voor niks mijne tijd in gestoken.
    hoeveel keer gaan we nog van die threads krijgen met pc specs.
    Ps3 : Noulet
    Grayfox's Avatar
    Knokke
    kzie niet direct in hoe die FAQ een antwoord geeft op zijn vraag tbh
    Anyway, volgens mij kan hem wel gelijk hebben maar echt 'high' kan je dat niet noemen, want ik ben er vrij zeker van dat die GF4MX400 heleboel shader functies enzo helemaal niet ondersteunt.
    [Rasta]Grayfox
    Teknoman's Avatar
    Een mx4000 is directx7, dus die kan directx 8 en 9 effecten niet renderen. Dus geen pixelshaded water, bumpmaps dacht ik ook niet, geen normal maps enzo. Doordat die kaart dat allemaal niet moet berekenen kan dat wel zijn dat die dat zo tamelijk goed kan draaien, maar of de beeldkwaliteit er ook naar is is een andere zaak.
    Smokey_3800's Avatar
    Sint-Truiden
    ik heb thuis ne mx440, zal straks eens proberen alles op high te zetten ... I'll keep you posted
    COOLKILLer's Avatar
    ik heb hier ene en da gaat dus poke slecht, maar da zal wrs wel liggen aan de rest van systeem (zie sig)
    ik draai da zo aan 14 fps...
    cs: s gaat wel veel beter rond de 45 fps (wa ook nie echt veel is maja)
    Teknoman's Avatar
    Van gij is het een geforce 2 mx 400, dat is wel wat anders dan een geforce 4 mx 4000.
    En van gij zal het wel aan uw systeem liggen denk ik datniet al te denderend is.
    deathsythe's Avatar
    Rstad
    16 (100%)
    kheb geforce2 mx440
    Gear: Denon X1100 | 2 x Sync Xtrm 1 | 2 x Reloop RMP1 | NI F1 | NI X1 | NI S2 |NI Maschine MKII | NI Audio 8 DJ | Sennheiser HD25
    ik zit vast int spel, ik zit op da veerbootje en ben nu op een plaats waar zo 2 dikke ( auto's of vrachtwagens???) rakketten afschieten, die heb ik kunnen kapot schieten , maar nu weet ik niet waarhene, er staan 2 gestrande schepen op die plaats. Als ik over zo een ramp probeer te springen, val ik terug int water, ik kan te voet doorgaan, maar ik denk niet dat dit de bedoeling is. (daarachter komt weer zo ene helikopter die ge moet afschieten )
    plz help
    zwevegem
    met Gforce 4 MX 440 draai ik alles perfect op low, en meestal ook op medium.
    Maar kset et op low, kdraai et perfect, moestek 512 ram ebben ( nu : 256 ), ton gingek et op medium spelen.
    Teknoman's Avatar
    Quote Originally Posted by wouterjacobs7
    plz help
