    Cryp's Avatar
    Knokke
    Welke tweaks mogen en welke niet (gfx tweaks)
    kheb mijn et config wa getweakt maar zou graag wille wete of tot hoe ver je mag veranderde aan gfx
    hier 3 screens:
    http://members.lycos.nl/gertjancalis...CW:ET%20tweak/
    greets
    Cryp
    breez's Avatar
    17 (100%)
    kijken naar de pb cvars é
    Pyke's Avatar
    Lichtervelde
    join tnserver of clanserver en kijk of ge niet gekickt wordt
    Raanº³'s Avatar
    Drongen
    Quote Originally Posted by Cryp
    hier 3 screens:
    greets
    Cryp
    imho gaat dit kick opgeven
    k denk da al uw picmip te hoog gaat staan
    Code:
    pb_sv_cvar cl_freelook in 1
    pb_sv_cvar cl_maxpackets in 30 100
    pb_sv_cvar cl_timenudge in -20 0
    pb_sv_cvar rate in 7000 25000
    pb_sv_cvar snaps in 20 40
    pb_sv_cvar cg_bobup in 0 0.005
    pb_sv_cvar cg_fov in 90 120
    pb_sv_cvar cg_shadows in 0 1
    pb_sv_cvar cg_thirdperson in 0
    pb_sv_cvar com_maxfps out 0.00001 40
    pb_sv_cvar m_pitch out -0.015 0.015
    pb_sv_cvar m_yaw in 0.022
    pb_sv_cvar r_allowextensions in 1
    pb_sv_cvar r_ati_fsaa_samples in 0
    pb_sv_cvar r_ati_truform_tess in 0
    pb_sv_cvar r_drawentities in 1
    pb_sv_cvar r_drawfoliage in 0 1
    pb_sv_cvar r_ext_ATI_pntriangles in 0
    pb_sv_cvar r_ext_NV_fog_dist in 0
    pb_sv_cvar r_ext_texture_filter_anisotropic in 0
    pb_sv_cvar r_flares in 0 1
    pb_sv_cvar r_gamma in 1 3
    pb_sv_cvar r_intensity in 1 1.5
    pb_sv_cvar r_lightmap in 0 1
    pb_sv_cvar r_mapoverbrightbits in 0 3
    pb_sv_cvar r_overbrightbits in 0 1
    pb_sv_cvar r_picmip in 0 3
    pb_sv_cvar r_showtris in 0
    pb_sv_cvar r_showmodelbounds in 0
    pb_sv_cvar r_shownormals in 0
    pb_sv_cvar r_uifullscreen in 0
    pb_sv_cvar r_wolffog in 1
    pb_sv_task 300 600 pb_sv_cvarsrch com_maxfps
    pb_sv_task 600 600 pb_sv_bindsrch com_maxfps
    pb_sv_guidrelax 0
    PB waarden voor Telenet Server (die de competitiesettings zoveel mogelijk probeert na te streven dus dit zal ook "ongeveer" de competitiesettings zijn
    [ Momenteel geen signature ]
    DeadBull's Avatar
    Hever
    Quote Originally Posted by Raanº³
    r_picmip kan ni hoger dan 3 gaan door engine zelf
    this aint rtcw
    Cryp's Avatar
    Knokke
    kicked van skynet server
    r_rmse 250
    damn
    idd te vee lgetweaked
    oeveel zou die max mogen
    Lexirium's Avatar
    Zonhoven
    Gewoon ingeven zonder getal dan
    geeft de console max waarde wel.
    lexy
    Cryp's Avatar
    Knokke
    Quote Originally Posted by Lexirium
    lexy
    thx m8
    *edit*
    heb alles weer stanaard gezet bij maar gekicked worde
