    oya's Avatar
    San Andreas
    rate the build: PVE Frost Mage
    Arcane Talents (20 points)
    # Arcane Subtlety - 3/3 points
    Reduces the threat generated by your offensive arcane spells by 40%.
    # Arcane Focus - 4/5 points
    Reduces the chance that the opponent can resist your arcane spells by 8%.
    # Improved Arcane Missiles - 2/5 points
    Gives you a 40% chance to avoid interruption caused by damage while channeling Arcane Missiles.
    # Arcane Concentration - 5/5 points
    Gives you a 10% chance of entering a Clearcasting state after any damage spell hits a target. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
    # Evocation - 1/1 point
    While channeling this spell, your mana regeneration is active and increased by 1500%. Lasts 8 seconds.
    # Arcane Meditation - 5/5 points
    Allows 15% of your Mana regeneration to continue while casting.
    Frost Talents (31 points)
    # Improved Frostbolt - 5/5 points
    Reduces the casting time of your Frostbolt spell by 0.5 seconds.
    # Ice Shards - 5/5 points
    Increases the critical strike damage bonus of your Frost spells by 100%.
    # Winter's Chill - 1/3 point
    Increases the power of your chill effects by slowing the target's movement by an additional 4%.
    # Cold Snap - 1/1 point
    When activated, this spell finishes the cooldown on all of your cold spells.
    # Piercing Ice - 3/3 points
    Increases the damage done by your frost spells by 6%.
    # Improved Frost Ward - 1/1 point
    50% of the damage absorbed by your Frost Ward is added to your mana.
    # Frost Channeling - 3/3 points
    Reduces the mana cost of your frost spells by 15%.
    # Arctic Reach - 2/2 points
    Increases the range of your Frostbolt spell and the radius of your Frost Nova and Cone of Cold spells by 20%.
    # Ice Block - 1/1 point
    You become encased in a block of ice, protecting you from all physical attacks and spells for 10 seconds, but during that time you cannot attack, move, or cast spells.
    # Improved Cone of Cold - 3/3 points
    Increases the damage dealt by your Cone of Cold spell by 35%.
    # Frostbite - 5/5 points
    Gives your chill effects a 15% chance to freeze the target for 5 seconds.
    # Ice Barrier - 1/1 point
    Instantly shields you, absorbing 455 damage. Lasts 1 minute. While the shield holds, spells will not be interrupted.
    Fire Talents (0 points)
    # None
    Tailoring - Skinning
    Later: Tailor - Enchant
    comments plz
    DaV!DoF's Avatar
    baseQ3
    ben zelf geen mage mor kan er wel het 1 en het ander van mee spreken aangezien mijn maat altijd met mage speelde.
    Frost mage is zowat DE moeilijkste vijand van een hunter (ik dus)
    Ik denk trouwens dat hunters geen uitzondering zijn, frostmages zijn de moeilijkste vijanden in het algemeen... voor alles is een oplossing natuurlijk mor alleen ge moet weten wat die oplossing is e.(kheb er zo al een paar gevonden door gewoon te lezen en te denken.)
    wat ge wel nog kunt doen is daarbij in combinatie van fire...1 magic is genoeg zo lang ge maar een bom kunt laten vallen op een player kwa health damage wanneer hij der ergens zit vast gevroren.
    -To punish and enslave-
    crazy_soy's Avatar
    herk-de-stad
    en de build tread die telt nie meer?
    fuze's Avatar
    Scherpenheuvel
    Build thread.
