    tekoop's Avatar
    Admin MOD installeren
    Welke ADMIN MODS zijn er beschikbaar voor CS:Source ?
    ik heb in de UK een 100Mbit servertje draaien, en zou graag een beetje meer veranderen, dan de standaard config.
    bedankt
    Najdo's Avatar
    torhout baby !
    http://www.adminmod.org/
    As most of you will have noticed, Valve did finally release Half-Life 2. And some of you might habe noticed that the Steam Games window lists the SDK for the Source Engine, or might remember that Valve once said it would be released before/at the same time/shortly after HL2. "So", you might be asking, "where is Admin Mod for my CS:Source server then already?!"
    Well, it ain't done yet. To be honest, we didn't even start writing it yet. That is because we still don't have the necessary information we need. So far only parts of the Source SDK have been released, which are those parts needed to build maps and models. But no source code is available and that is what we at Admin Mod live from. So you'll have to wait a little longer until the rest of the Source SDK, especially the sources, has been released. Which should be the case anytime now.
    Even though, I'll still have to ask you to hold your horses. Valve said that the Source Engine will include something like Metamod in the future so that we will not need Metamod for Source servers to load plugins. Instead, the server has its own interface for that, the Source Engine Plugin Interface (SEPI). So we will need some time to see how that works and rewrite Admin Mod to be a SEPI plugin instead of a Metamod plugin.
    Well, okay, that's maybe not the real reason. In reality we're still busy playing Half-Life 2. =)
    Times you will always remember with the friends you'll never forget
    krisiboy's Avatar
    belgium
    ik heb ook 1 die staat op mijn server en ik zeg dat em goed is
    www.cs-suck.com
    en dan forums
    dan anima admin mod
    My sig Have's Turn he"s Back on Me
    krisiboy's Avatar
    belgium
