Thread: mage build
    crazy_soy's Avatar
    herk-de-stad
    mage build
    vooral fire en frost mss wa inzicht van andere mensen
    Class: Mage
    Level: 60
    Arcane Talents (0 points)
    None
    Frost Talents (32 points)
    Improved Frostbolt - 5/5 points
    Reduces the casting time of your Frostbolt spell by 0.5 seconds.
    Permafrost - 5/5 points
    Increases the duration of your chill effects by 3 seconds.
    Improved Frost Nova - 2/2 points
    Reduces the cooldown of your Frost Nova spell by ?.
    Winter's Chill - 3/3 points
    Increases the power of your chill effects by slowing the target's movement by an
    additional 10%.
    Ice Shards - 5/5 points
    Increases the critical strike damage bonus of your Frost spells by 100%.
    Piercing Ice - 3/3 points
    Increases the damage done by your frost spells by 6%.
    Improved Blizzard - 1/3 point
    Adds a chill effect to your Blizzard spell. This effect lowers the target's
    movement speed to 60% of normal. Lasts 8.50 seconds.
    Arctic Reach - 2/2 points
    Increases the range of your Frostbolt spell and the radius of your Frost Nova
    and Cone of Cold spells by 20%.
    Improved Frost Ward - 1/1 point
    50% of the damage absorbed by your Frost Ward is added to your mana.
    Shatter - 1/5 point
    Increases the critical strike chance of your frost spells against frozen targets
    by 10%.
    Ice Block - 1/1 point
    You become encased in a block of ice, protecting you from all physical attacks
    and spells for 10 seconds, but during that time you cannot attack, move, or cast
    spells.
    Improved Cone of Cold - 1/3 point
    Increases the damage dealt by your Cone of Cold spell by 15%.
    Frostbite - 1/5 point
    Gives your chill effects a 3% chance to freeze the target for 5 seconds.
    Ice Barrier - 1/1 point
    Instantly shields you, absorbing 455 damage. Lasts 1 minute. While the shield
    holds, spells will not be interrupted.
    Fire Talents (19 points)
    Improved Fireball - 5/5 points
    Reduces the casting time of your Fireball by 0.5 seconds.
    Impact - 5/5 points
    Gives your fire spells a 10% chance to stun the taget for 2 seconds.
    Ignite - 3/5 points
    Your critical strikes from fire damage spells cause the target to burn for an
    additional 24% of your spell's damage over 4 seconds.
    Flame Throwing - 1/2 point
    Increases the range of your fire spells by 3 yards.
    Pyroblast - 1/1 point
    Hurls an immense fiery boulder that causes 148 to 195 fire damage and an
    additional 56 damage over 12 seconds.
    Burning Soul - 1/3 point
    Gives your fire spells a 25% chance to not lose casting time when you take
    damage.
    Incinerate - 1/2 point
    Increases the critical strike chance of your Fire Blast and Scorch spells by 2%.
    Improved Fire Ward - 2/2 points
    Causes your fire ward to reflect 35% of the damage absorbed back to the caster.
    merci op voorhand
    Raukaris's Avatar
    Denderleeuw/Gent
    29 (97%)
    iedereen is hier zijn builds aan het posten laten we gewoon de grote post your build thread maken!!
    Greenie's Avatar
    Must Haves
    Arcane Talents (18 points)
    # Improved Arcane Missiles - 5/5 points
    Gives you a 100% chance to avoid interruption caused by damage while channeling Arcane Missiles.
    # Arcane Concentration - 5/5 points
    Gives you a 10% chance of entering a Clearcasting state after any damage spell hits a target. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
    # Evocation - 1/1 point
    While channeling this spell, your mana regeneration is active and increased by 1500%. Lasts 8 seconds.
    # Improved Arcane Explosion - 5/5 points
    Reduces the casting time of your Arcane Explosion by 1.5 seconds.
    # Improved Counterspell - 2/2 points
    Gives your Counterspell a 100% chance to silence the target for 4 seconds.
    van een lvl60 mage
    robbY's Avatar
    Lokeren
    ni iedereen moet zijn arcane skills trainen he (imo)
    crazy_soy's Avatar
    herk-de-stad
    is vooral voor pve
    Greenie's Avatar
    pve en pvp zei ie, mja je kiest wat je wilt, en lukt het ni, kan je altijd voor gold resetten
    al spelend zulde ook wel zien wa het waard is en welke spel je ni wilt verbeteren
    fuze's Avatar
    Scherpenheuvel
    PvP = Frost mage
    Raukaris's Avatar
    Denderleeuw/Gent
    29 (97%)
    Quote Originally Posted by fuze
    PvP = Frost mage
    kdacht arcane
    Caretaker's Avatar
    Kontich
    Ik ga een shadow priest rollen:
    http://www.classesofwarcraft.com/?m=...00000000000000
    Btw, als ge ne meer visuele link wilt voor uw template:
    http://www.classesofwarcraft.com/?m=...53230120111111
    Archangelus's Avatar
    Berchem
    Quote Originally Posted by Raukaris
    kdacht arcane
    Pff, alles werkt in PvP zolang ge een goeie groep/guild hebt die weet wat ze doen en zolang ge zelf weet wa ge doet.
    What a difference indifference can make.
    UndeadKing's Avatar
    Sint-Joris-Winge
    PvP built:
    33 Frost/18 Arcane
    Frost Talents (33 Points)
    Improved Frostbolt
    Rank: 5/5
    Ice Shards
    Rank: 5/5
    Increases the damage done by your frost spell critical strikes by 100%.
    Improved Frost Nova
    Rank: 2/2
    Reduces the cooldown of your Frost Nova spell by 4 seconds.
    Piercing Ice
    Rank: 3/3
    Cold Snap
    Rank: 1/1
    When activated, this spell finishes the cooldown on all your cold spells.
    Arctic Reach
    Rank: 2/2
    Increases the range of your Frostbolt spell and the radius of your Frost Nova and Cone of Cold spells by 20%.
    Frost Channeling
    Rank: 3/3
    Reduces the mana cost of your Frost spells by 15%.
    Shatter
    Rank: 5/5
    Increases the critical strike chance of your frost spells against frozen targets by 50%.
    Ice Block
    Rank: 1/1
    You become encased in a block of ice, protecting you from all physical attacks and spells for 10 seconds, but during that time you cannot attack, move or cast spells.
    Frostbite
    Rank: 5/5
    Gives your chill effects a 15% chance to freeze the target for 5 seconds.
    Ice Barrier
    Rank: 1/1
    Instantly shields you, absorbing 455 damage. Lasts 1 min. While the shield holds, spells will not be interrupted.
    Arcane Talents (18 Points)
    Rank: 5/5
    Rank: 5/5
    Rank: 5/5
    Evocation
    Rank: 1/1
    Rank: 2/2
    PvP/PvE built
    20 Fire/31 Arcane
    Fire talents (20)
    Impr Fireball : 5/5
    Impact : 5/5
    Ignite : 5/5
    Flame trowing : 2/2
    Incinerate : 2/2
    Pyroblast : 1/1
    Arcane talents (31)
    Improved AM : 5/5
    Arcane Conc : 5/5
    Impr Dampen magic : 2/2
    Impr Arc Expl : 5/5
    Evocation : 1/1
    Impr Mana shield : 2/2
    Impr Counterspell : 2/2
    Presence of mind : 1/1
    Arc Mind : 4/4
    Arc instab. : 3/3
    Arc Power : 1/1
    My 2 cents
    --- Diablo III: LV 60 Monk Tzusam (Farming Act III Inferno) ---
    ---"...Death is swift and effortless..."---
    Harlequin's Avatar
    Quote Originally Posted by crazy_soy
    is vooral voor pve
    Dan wil je zeker en vast een pak meer points in arcane steken.
    Want met die build ga je meer op je reet zitten (eating+drinking) dan mobs killen.
    Is mss geen slecht idee om een sticky voor builds te maken.
    Greenie's Avatar
    mja, dan toch minstens per class want anders wordt het een rotzooi hoor
    voor de rest :
    fire/arcana => damage gericht
    frost/arcana => controle gericht (en schijnt nogal goe door melee te vreten , daarentegen wel minder vs casters)
