    2 vraagjes over NFS:U2
    1. Wat is het verschil tussen de races afleggen in explore mode en de races afleggen in world map?
    2. Welke techniek moet je aanwenden om te winnen bij street X? Vol gas de ganse tijd werkt niet. Moet je met de handrem werken of zo? Enige tips welkom, want dit vind ik een moeilijk onderdeel
    Life Is Music.
    Genius's Avatar
    Brasschaat
    1. No idea
    2. Ik schakel altijd terug als ik aan een bocht kom en dan in de bocht gas geven.
    Quote Originally Posted by GeneH
    Ik rij op automatisch.
    Life Is Music.
    Genius's Avatar
    Brasschaat
    En?
    Drukt gewoon op u achteruitpijltje... Dan schakelt ge ook terug hoor
    Blackstone's Avatar
    As you finish the game, you'll receive an SMS message from Rachel Teller,
    telling you (well, that's normally what tellers do =) that you finished the
    game, and that by acessing the option "World Map" from you garage, you can
    re-race any event. And that's where the remaining 34% of the game can be
    completed:
    In any moment while you're in exploration mode, hit Esc and then choose
    "Jump to Garage". In there, press right once then select "World Map". By the
    new window that appears, press the left or right arrow keys to select one of
    the 5 game stages. Then, press up and down to select an event. Select the
    ones marked as "Not Completed", then enter them.
    And this is how you race the remaining 34%! However, you may notice that
    just by doing what was mentioned above will not award you with points or
    cash after the end of a race. But I noticed something pretty strange, and
    somewhat quite useful: if you hit Esc when inside a race, then choose to
    restart and win, you'll get the cash! It was something that happened to me,
    but then I confirmed with other fellow players. I wasn't really trying to
    discover this; I think I just restarted because I messed up some race and
    then noticed this occurance.
    2. Als er een scherpe bocht aankomt: breed aankomen, remmen, vroeg insturen zodat je juist niet de muur raakt, ergens op het einde van de bocht vol gas geven.
    Let er wel op dat je niet te breed gaat als er tegenstanders vlak achter je rijden, want dan komen zij langs binnen en plak jij tegen de buitenkant
    Bij minder scherpe bochten gewoon wat gas lossen (remmen moet niet altijd).
    str0ntj3's Avatar
    Sint-Kruis-Winkel/Gent
    En?
    dan zijde gij vast den enigste die die functie heeft;..
    :: SHARPimages.be - FotoGear: Nikon D4, Nikon D700, Nikon 16-35 F4 VR, Nikon 24-70 F2.8 VR, Nikon 50 F1.4, Nikon 70-200 F2.8 VRII, Nikon SB-910 & Some more ::
    :: My Computer System - Laptop:
    Apple MacBook Air 11,6" i5 1.6Ghz, 500Gb SSD, 4Gb DDR3 ::
    Blackstone's Avatar
    Quote Originally Posted by str0ntj3
    euhm
    remmen (=pijlke achteruit duwen) --> snelheid minderen --> (automatisch) terugschakelen.
    Wat klopt er dan volgens u niet in deze redenering?
    the maniak's Avatar
    as ge zelf terug schakelt dan remt ge op de motor
    als ge remt, dan remt ge met de remmen en nie op de motor
    groot verschil in weg gedrag tss die 2
    --<< Enjoy life. There's plenty of time to be dead >>--
    Sergiow's Avatar
    + big nfsu2 topic
    str0ntj3's Avatar
    ale kijk, als kik rem dan gaat em idd trg schakelen...
    maar em bedoeld dus wel dat em met automatische versnelling manueel kunt trg schakelen. Die functie heb ik dus nie.
    P2K-'s Avatar
    ds
    ik heb nfsu2 uitgespeeld (juist nog de overblijvende %en in de world map), ma ik heb dus vroeger nooit die outrun's gedaan voor die unique parts. Kan ik die nu op mijne buik schrijven ?
    str0ntj3's Avatar
    jup, kheb hetzelfde voor gehad.
    Silent Thunder's Avatar
    hier
    Dit moet in de NFSU2 Big Thread... *zucht*
    CLOSED
    Pieter Fret | Photography x Copywriting
