    Insano's Avatar
    The Matrix
    [HL2] SDK Update
    Een Source SDK update is beschikbaar en zal automatisch gedownload worden als je Steam herstart. De veranderingen zijn:
    • Simplified directory structure.
    • Face Poser application added.
    • VConfig added, new tool to select game configurations.
    • A "Reset Game Configurations" option has been added to the SDK Launcher.
    • The Hammer Options dialog now reflects the selected Current Game.
    • Added default Expert compile settings in Hammer.
    • Viewmodel sources for Half-Life 2 included.
    • Simplified debugging under Steam - no need to copy steam.dll and make steamapp.cfg.
    • Added sdk.fgd, containing the entities in the programming tutorial.
    • SDK Launcher startup time is much faster.
    Deze problemen zijn opgelost:
    • Fixed issue with Hammer not copying .bsp to game directory.
    • The buildcubemaps console command should now function correctly.
    • The impulse 81 command to check cubemap placement should now function correctly.
    • Fixed for various cases of path environment variables not working.
    • Fixed detail props not being generated by vbsp.exe.
    De vorige SDK release bevatte deze nieuwe features:
    • The ability to edit Half-Life 2 levels and custom MODs.
    • Includes all the game source code for Half-Life 2 and a sample multiplayer mod (Create a Mod).
    • Source code for the compile tools.
    • Documentation on programming for the Source Engine.
    • Additional documentation on content creation.
    • A number of additional sample maps.
    • Sample models.
    • A Source Engine model exporter for Maya.
    "At the beginning of the Portal development process, we sat down as a group to decide what philosopher or school of philosophy our game would be based on. That was followed by about fifteen minutes of silence and then someone mentioned that a lot of people like cake."
    - Valve
    omfg!
    ownage!
    ma duur wel lang voor update
    jah zo ownage was het niet
    zebben der weer ne goeie bug in gestoken
    nu gaat niemeer.. ik zweer het als ik mijn map niemeer kan verder maken knal ik ze de kop in
    naabs
    voor mensen die nog moeten updaten
    niet doen!
    Insano's Avatar
    The Matrix
    Quote Originally Posted by Super SiN
    naabs
    niet doen!
    Je moet de update wel doen
    Zeg eens welke bug je hebt?
    - Valve
    sebastos's Avatar
    Beerse
    Quote Originally Posted by Captain Insano
    inderdaad
    bij mij werkt alles perfect dusja
    You either surf or you fight.
    mars
      fuck
      yay
      Pfft, goe vo mense da geen .txt files kunnen aanpassen
      nooit probs gehad met debugging
      werd verdomme tijd, ik zat gemiddeld 5 min. op die launcher te zien
    bah is al fixed, de dirs waren veranderd
    gewoon ff alle maps verwijderd, ernieuw laten kweken en dan ging het :/
    kakature's Avatar
    Ja
    WTF wa is da met die configurations, kmoet da helemaal weer instellen of zo ?
