Thread: CS:S - hulp bij FPS?
26-11-2004, 16:23 #1Member
- 25/11/04
- 8
yupse iedereen en welkom vo te beginnen zal ik maar zeggen dat ik een volledige noob ben met css nooit van mijn leven gegamed maar nu wel.
ik ben wel enorm actief met E.T.(clan) dus weet ik toch wel iets van ftp games en die commands!!
gegevens van mijn pc--->(dxdiag)
system Information
Time of this report: 11/26/2004, 11:56:48
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: ASUSTeK Computer INC.
System Model: A7N8X2.0
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 2200+, MMX, 3DNow, ~1.8GHz
Memory: 768MB RAM
Page File: 275MB used, 1603MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9600 SERIES
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9600 XT AGP (0x4152)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4152&SUBSYS_024218BC&REV_00
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug en Play-monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6490 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/26/2004 20:35:58, 214528 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n.v.t.
Mini VDD: ati2mtag.sys
Mini VDD Date: 10/26/2004 20:35:38, 820224 bytes
Device Identifier: {D7B71EE2-0212-11CF-5662-4822A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4152
SubSys ID: 0x024218BC
Revision ID: 0x0000
Revision ID: 0x0000
Sound Devices
Description: Creative SB Audigy LS
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0007&SUBSYS_10021102&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: P17.sys
Driver Version: 5.12.0001.0024 (English)
WHQL Logo'd: n/a
Date and Size: 8/5/2003 03:22:32, 651264 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: NVIDIA(R) nForce(TM) Audio
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: *NFORCE
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: nvapu.sys
Driver Version: 5.10.2917.0000 (English)
WHQL Logo'd: n/a
Date and Size: 12/5/2002 05:01:00, 241664 bytes
Other Files:
Driver Provider: NVIDIA Corporation
Cap Flags: 0x0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
Registry: OK
Drive: F:
Model: PLEXTOR DVDR PX-712A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Dutch), 8/4/2004 06:59:52, 49536 bytes
wat mijn probleem is, die fuucking fps het max. da ik daaruit haal is maar 35 à 40fps en soms zakt die zelfs tot 15fps
wie kan er mss helpen??
mag me ook steeds toevoegen op msn frecornet@hot...
greetzzzzz freLast edited by fluggel; 26-11-2004 at 17:07.
26-11-2004, 17:22 #2
check anders faq?
+ thread name was slechtLast edited by Fraggie; 26-11-2004 at 19:32.
26-11-2004, 17:25 #3Approved 9-lifer
- 30/09/02
- Kasterlee
- 6,160
- 11 (100%)
- 8/25
normaal meer als voldoende, vroeger speelde ik cs zonder probs op een 600 mhz met een geforce 1 32MB en 128 mb ram. daar zal het dus niet aan liggen. probeer eens de nieuwste drivers van videokaart te installeren. en uw directx of zo updaten.
PSN: Daedieno votes
26-11-2004, 18:22 #4Member
- 28/04/04
- torhout baby !
- 1,009
- 0/5
we hebben het toch over source he
Times you will always remember with the friends you'll never forgetno votes
28-11-2004, 03:56 #5Member
- 25/11/04
- 8
lol, waarom slecht?
tuurlijk ga da ier over source
het is toch nie normaal da ik steeds unknow cmd's krijg als ik dit ingeef??
gl_playermic 3
gl_picmic 2 (word ook gebruik in E.T. en daar lukt da wel)
?? hoe kom dano votes
